AL-KO Steadies on a Bush Lapa
Results 1 to 20 of 28
    Wartburg.
    Thanked: 527
    Default AL-KO Steadies on a Bush Lapa
    Has anyone fitted AL-KO drop down steadies to their Lapa?
    I find that the front jockey wheel only is not good enough for me.
    1. The shaft moves, slides through the clamp.
    2. With front steadies it will be so much more steady.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Dec 2006
    Thanked: 113
    Default Re: AL-KO Steadies on a Bush Lapa
    Hi
    Look at Bush Lapa Miskruier Review thread, posts 11648 & 11652. Can vouch that it works
    Wartburg.
    Thanked: 527
    Dankie Sebastiaan
  4. The Following User Says Thank You to Chris8d For This Useful Post:
    Plett/Paulshof
    Thanked: 832
    Yip, fitted to mine.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
    Thanked: 2254
    Fitted a set to mine also - works perfectly.
    Jul 2017
    Dundee
    Thanked: 29
    Hi
    Yes Going to fit to my Kewer as well, Had issues with the Jockey wheel on my last Camp.
    Dave
    Dave
    BL1942 - The Bug
    Jan 2011
    Thanked: 42
    A friend suggested a 6ton jack stand just behind the coupler....works like a bomb and was only R250 as my friend bought the other jack in the box
    https://www.adendorff.co.za/product/...l-jack-stands/
    Much easier than jacking up two additional steadies to the correct level, less weight and much cheaper
    2017 Toyota Fortuner 2.8 GD6 4x4 iMT
    2016 Hyundai Tucson 1.6 T-GDi
    2019 Bush Lapa Miskruier BL1861
  9. The Following User Says Thank You to observer For This Useful Post:
    Jan 2009
    Thanked: 41
    Willem Louw
    Toyota Hilux D/C 3.0 D-4D 4x4, Full OME suspension, African Outback Alu-Top, Dual Battery, DIY Drawer System, National Luna 50L
    Venter Offroader Trailer
    Clanwilliam
    Thanked: 15
    Do anybody know where you can buy al-ko steadies online? Preferably in Western cape to lower courier costs?
    Jan 2011
    Thanked: 42
    They have a shop in Montague Gardens. Check their website
  13. #11
    Thanked: 2254
    Direk by Alko in Montaque Gardens. So rofweg R1200 vir die twee.
  14. #12
    Thanked: 50
    Fitted mine before December's 2 week camp and it works great. Little effort for great impact. Fitted mine on the outer side and they fold (just) in towards the A-frame.
    Jannie
    2007 Fortuner D4D 4x4
    2017 Fortuner GD6 4x4 MT
    Bush Lapa Miskruier
  15. #13
    Thanked: 2254
    Just frequently check the mounting point for damage as there where you mounted it is not as strong as at the T.
  16. #14
    Jhb
    Thanked: 39
    Quote Originally Posted by observer View Post
    I like this idea, no modifications and simple
    Bruce
    2010 Toyota Hilux 4x4 3.0D4D
    Bushlapa Miskruier BL15
  17. #15
    Thanked: 2254
    This will definitely cover the possible issue of the jockey sliding down, but won't increase the stability of the caravan.
  18. #16
    Jan 2011
    Thanked: 42
    Makes a massive difference to stability Try it
  19. #17
    Wartburg.
    Thanked: 527
    Thank you to everyone that replied.
    I have ordered a set of AL-KO steadies and will fit them when they arrive.
    The thinking behind it was not just the jockey wheel sliding through the clamp but also for better stability. I'm sure that they won't disappoint.
    Pictures to follow when fitted.
  20. #18
    Thanked: 92
    +1
    Ps 16:5
  21. #19
    Thanked: 92
    Jack stand also handy to keep the A- frame in the air if you want to ajust the nose height by losening the Jockey wheel bracket.
    Ps 16:5
  22. #20
    Jan 2011
    Thanked: 42
    Can also be used to stabilise your towing vehicle when changing a wheel instead of relying only on the OEM bottle jack
