Flush mount tie down anchors
Results 1 to 20 of 22
    stellenberg
    Thanked: 7
    Default Flush mount tie down anchors
    Hi All
    Iíve been trying to find flush mount tie down anchors similar to the ones in the pictures. The ones in the pictures are from my bus, but I want to install two more to be used as tie down anchors for my fridge. I have been to all the major outdoor outlets in the Northern suburbs of Cape Town and none have them. I Have been referred to places I have been to already. Can anyone here point me in the right direction please?
    Kind regards
    Hennie
Name:	Tie down anchor.jpg
ID:	558346   Click image for larger version.
Name:	Anchor Point.jpg
    Thanked: 363
    Default Re: Flush mount tie down anchors
    Not quite the same, but McNaughtans have similar:
    https://mcnaughtans.co.za/product/ri...g-zinc-plated/
    HOWIE-WP,
    RoadCar: 2008 VW Golf5 .:R32
    OffRoad Car: 2006 VW Touareg 4.2 v8
    "Settle for nothing less than the object of your desire"-Bjork
    stellenberg
    Thanked: 7
    Quote Originally Posted by Howie-WP View Post
    Thank you Howie. I was there. Those are to big. More suited to a flatbed.
    Sasolburg
    Thanked: 493
    https://m.takealot.com/tauro-alumium...B&gclsrc=aw.ds
    Is it for a bakkie loadbin?
    These I have and it sits flush with the top of the grooves in the loadbin and the hooks can be removed or placed wherever on the rail.
    I have them at different locations for different configurations.
    Have seen them at Outdoor warehouse too
    If Force is not the solution, not enough of it was applied....
    stellenberg
    Thanked: 7
    Quote Originally Posted by Pietsweis View Post
    Thank you Pietsweis. It is for the inside of my t5 kombi. Two fixed points that I can tie my fridge to. They are available online for a price. There has got to be a local supplier.
    Wartburg.
    Thanked: 536
    I use these.
    Not completely flush but close enough.
    https://4x4direct.co.za/cargo-tracks...hor-point.html
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Thanked: 302
    Why not buy some from vw, or try a scrap yard for a t5 wreck.
    The NP200 also have some liftup hooks in the loadbin - have a look at them and if you like it go to Nissan.
    Neil
    Mar 2019
    Carrigaline
    Thanked: 93
    They look very similar to the ones in audi avant. If you're stuck a visit to breakers might yield a few. I'm guessing VW passat estates also have them.
    stellenberg
    Thanked: 7
    Good idea. Guess I'll visit some scrap yards. Thank you, guys. Strange that it is not so readily available.
    Langebaan
    Thanked: 16
    I got these from BG Boats in Knysna - purchase online and next day delivery at Postnet.
    Made from 316 Stainless.
    www.bgboats.co.za
    Tshwanetoria
    Thanked: 679
    Why not install a rivnut of your chosen size, with a large washer at the back. You get extra long ones from Rivco to ensure a proper grip when using the thick material (body plus washer)
    Then you can install/remove any fixing point when and as required. When not in use, I close it with a SS mushroom Allen bolt.
    I did this in the Amarok and it really is a practical arrangement.
    stellenberg
    Thanked: 7
    Is it possible to post some photos. Sounds interesting.
    stellenberg
    Thanked: 7
    Quote Originally Posted by rian skip View Post
    www.bgboats.co.za
    Thank you "rian skip" The fridge will not be an permanent instal. I am worried about the rings rattling when not in use. Need spring loaded ones.
    Tshwanetoria
    Thanked: 679
    Quote Originally Posted by rattle&hum View Post
    Here you go: I rust treated the holes and also used some Sikaflex during the installation. This sort of waterproofs it. The brown color you see is not rust, but coppa slip, to prevent the fixture from seizing int he thread.
    I used M8 riv nut, in combination with a lifting ring. The SS mushroom allen nut is used in between "trips" to keep dust and water out.
ID:	558490Click image for larger version.
ID:	558491Click image for larger version.
    Thanked: 210
    ROADQUE, Have what you want.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    stellenberg
    Thanked: 7
    Hatjohan that is a very good idea. Something to keep in mind.
    Thank you
    Robbief could you post some photos please.
    I have someone local that still needs to come back to me.
    If not, Iíll contact you. Thank you.
    stellenberg
    Thanked: 7
    Thank you guys. I found what I was looking for, locally at a second hand dealer and will be collecting tomorrow. All the help and suggestions are much appreciated.
    Hennie
  18. The Following 2 Users Say Thank You to rattle&hum For This Useful Post:
  19. #18
    Thanked: 363
    Hennie
    Price? (for interest sake)
    HOWIE-WP,
  20. #19
    Tshwanetoria
    Thanked: 679
    How do you fix it to the floor?
  21. #20
    stellenberg
    Thanked: 7
    Price is R350 for two. Fixing it to the floor I stil have t figue out.
