BorgWarner electrical shift Transfer Case
Results 1 to 9 of 9
    Apr 2019
    Howick
    Question BorgWarner electrical shift Transfer Case
    Has anyone tried running the BW TC electrical shift on the Mahindra Scorpio with out the ECU? If you power the shift moter directly trough switches and relays, can it be done?
    Apr 2019
    Howick
    Default Re: BorgWarner electrical shift Transfer Case
    Pictures of the manual shifter fitted to BW TC electrical shifter
    Has anyone install this and what is your comments
    Name:  Screenshot 2020-02-15 at 11.03.35.png
Size:  16.2 KB Click image for larger version.
Name:	Screenshot 2020-02-15 at 11.02.37.png
ID:	558233 Click image for larger version.
Name:	Screenshot 2020-02-15 at 10.52.21.png
    Jul 2017
    Louis Trichardt
    Thanked: 205
    I would love to make mine manual shift. I hate the electronic shifting with a passion. I like old school stick shifts. When I want automatic 4x4 selection. It will be with an auto gearbox as well
    My Life Loving It
    Jan 2017
    Rustenburg
    Thanked: 975
    Like I said on the other thread, the 4x4 button simply powers a solenoid that either engages or disengages the manual bits on the transfer case. It’s an electric motor that pushes a lever. On pushes the lever one way, off pulls it’s the other way (or it may be always on, and the switch changes the polarity), but the concept stays the same.
    there is no algorithms or coding or wizardry involved. If the control is no longer engaging the 4x4, either the solenoid is seized, or there is a loose connection.
    Jan 2017
    Rustenburg
    Thanked: 975
    Not sure on the mahindra specifically, but I’d the main engine ECU needs to know what mode the TC is in, then you just need to make sure the hi/low switch on the TC is still sending a signal back to the engine control unit.
    on many cars this is important as they have different fuel maps etc for high and low range.
    Apr 2019
    Howick
    The diagram for the electric shift actuator
Name:	Screenshot 2020-02-15 at 20.07.49.png
    Apr 2019
    Howick
    Quote Originally Posted by Chris G View Post
    Have a look at this link
    https://www.youtube.com/watch?v=RV60...ature=youtu.be
  8. The Following User Says Thank You to Plasie_Fourie For This Useful Post:
    Sep 2018
    Thanked: 107
    4wd selection is not automatic, you have to manually select 4wd using the rotary dial (instead of the old school stick shift). Does the same thing, just in a different way.
    A question for the OP - why?
  10. The Following User Says Thank You to Lxv For This Useful Post:
    Jan 2017
    Rustenburg
    Thanked: 975
    Quote Originally Posted by Lxv View Post
    I suspect the OP is having issues using the selector switch, and has been quoted some absurd amount of money to fix the “4x4 ECU”. when all it is a simple rotary switch that activates a solenoid via a relay. Any decent sparky should be able to at best, fix the existing switchgear to work as it should, or at worst, replace with simple aftermarket switches that achieve the same result, and it shouldn’t cost more than an hour or twos labor, and some consumables.
