Zinc or nickel suppliers
Results 1 to 20 of 22
    Jul 2010
    Modders
    Thanked: 254
    Default Zinc or nickel suppliers
    I'm planning to do some home DIY electro plating, any ideas where I can source some zinc or nickel pieces?
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
    durban
    Thanked: 1119
    Default Re: Zinc or nickel suppliers
    Would love to know the process
    Richardsbay, KZN
    Thanked: 14244
    Quote Originally Posted by Hamtheman View Post
    Ham, I can't help with a source but wanted to mention the electroless nickel plating process. Kits were available many years ago and I plated quite a bit of stuff, mostly firearm related. Simple and straightforward process it was.
    Walker Evans, Photographer
    Jul 2010
    Modders
    Thanked: 254
    Yup Riaan, I have been researching and set up two kits, one for electrolytic rust removal and the second will be for plating, really simple, I just need to find the zinc now
    Boksburg
    Phone Dean 082 770 6389 . He supplies all that kind of stuff . I dealt with him recently and it was rather pleasant .
    Apr 2014
    Richards Bay
    Thanked: 100
    you should be able to get your hands on some zinc anodes at any decent marine supplier. Bolted under the water line to protect steel hulls, props shatfs etc.
    1985 Land Rover 110 - 300tdi conversion
    It's always more fun on the road less travelled
    Jul 2010
    Modders
    Thanked: 254
    Thanks all, sorted. My little electrolysis rust removal plant works 100%, now for the platingClick image for larger version.
ID:	557843Click image for larger version.
    durban
    Thanked: 1119
    What solution are you using and what amperage and sacrificial anode are you using?
    Jul 2010
    Modders
    Thanked: 254
    And success, first plating doneClick image for larger version.
    Jul 2010
    Modders
    Thanked: 254
    Plunger I am using water with some soda ash, the anode is a piece of rebar, power source is an old charger, 9v 2A
    Jul 2010
    Modders
    Thanked: 254
    The de rusting set upClick image for larger version.
    durban
    Thanked: 1119
    Nice its such a simple process. I use bicarb or sodium bicarbonate, must check . I did a potje and it worked well. I think it also works better if you can get the anode a similer distance from the workpiece so its sorrounded by a curtain of anode on akward shapes but in truth i havent noticed any difference.
    Please tell us the zinc process.
    Jul 2010
    Modders
    Thanked: 254
    So the plating is just as simple, you can make a zinc solution, but it's easier to buy from a plating business, attach a zinc anode to the positive supply and the piece you want plated to the negative. Submerge in the solution and watch it happen . Make sure the piece to be plated is properly clean, I dip it into pool acid first, rinse off then start.
    Jul 2010
    Modders
    Thanked: 254
    Btw, soda ash is sodium bicarbonate.....
    Centurion, Pretoria, SA
    Thanked: 369
    Thanks for the info. Often wondered about this. Def going to give it a go. How long does the process take? ie - derusting & then plating?
    SOMETIMES I WAKE UP GRUMPY,
    Jun 2012
    Thanked: 1178
    Nice! Just watch out for hydrogen embrittlement if those bolts are going to be used in load bearing applications
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Jul 2010
    Modders
    Thanked: 254
    It's a light coating , essentially just for cosmetic purposes so around 15 minutes, have to say it's a really satisfying process
    Randpark Ridge
    Thanked: 291
    Would this work on old (vintage) rusted sheers and tools?
    Discovery 3 TDV6 S G4 No 29 - Mine
    Discovery 4 TDV6 SE - SWAMBO's
    Jul 2010
    Modders
    Thanked: 254
    Absolutely
    Thanked: 369
    That is fantastic. I was thinking like maybe a half or full day process. That makes all the difference.
