Battery/hella plug /fridge issue
Results 1 to 10 of 10
    Dec 2019
    Woodmead
    Default Battery/hella plug /fridge issue
    Hi all
    Please can someone help me problem solve this issue.
    I have a 105 dual battery setup in my hilux running from front to a hella plug in the back.
    I am running a 74 liter national Luna fridge freezer.
    run it at 2 degrees and -3 respectively.
    when Iím driving the fridge seems to run fine , however when I stop for more than an hour the fridge basically stops working.
    1. New battery installed
    2. fridge recently serviced
    3. green run light stays on
    4. NO flashing fault light
    this weekend I ran the fridge using my same 12 v cable on a camping trailer and the fridge/freezer worked perfectly.
    im now lost for ideas ? Perhaps cable running from battery to hella to small ?
    why would it then run fine while driving ?
    thanks in advance
    Cape Town - RSA
    Thanked: 335
    Default Re: Battery/hella plug /fridge issue
    Presume the second battery is in the engine bay?
    Does the fridge have a low power cut off and what is it on? If its on high, then it will cut fairly early to protect that battery. Change it to medium or even low so long as that second battery is oslated from starter.
    Ex - 2005 Cherokee CRD
    Thanked: 128
    Check the Hella plug female connection. With vibration, the little 'jaws' on the inside lose their grip.
    Be careful, don't stick a screwdriver in there while it is powered up.
    Then, replace with Brad Harrison plugs.
    ORRA Callsign: X130
  4. The Following User Says Thank You to Subok For This Useful Post:
    Apr 2016
    Roodekrans/Of die groot sand van die Kalahari
    Thanked: 11
    The system can loose quite a bit of power on bad connections and one thing to remember with dc is wires to be as thick as possible and short as possible.
    Apr 2016
    Thanked: 11
    When engine is on your system volts is higher than on engine off and battery alone.
    Aug 2017
    Durban or Centurion
    Thanked: 1230
    Can you measure the supply when engine is running, and when the fridge stops working?
    Dec 2019
    Woodmead
    Thanks. Yes I have tried medium and low settings to no avail
    Dec 2019
    Woodmead
    Quote Originally Posted by K2l2h2r1 View Post
    Thank you
    Dec 2019
    Woodmead
    Thank you
    Dec 2019
    Woodmead
    Quote Originally Posted by Subok View Post
    Thanks.
