Cheapest load-shedding battery solution
Results 1 to 20 of 25
    Default Cheapest load-shedding battery solution
    Ok, I am now finally getting gatvol re this load-shedding....
    My budget is seriously strained, but this needs to be resolved.
    I found this inverter: https://doodah.co.za/inverters/33809...er_ouput-5000w
    With 2 of those Ecco 120ah deep cycle batteries, it should be enough to keep a few essentials on, right?
    I spent a long time looking, and this is the only inverter I saw that has an AC input.
    This solution appears to offer nearly double the Watts that these of the shelf solutions from Ellies, and a Mecer one I saw as well(battery box on wheels with inverter on top). They are only about 1200 to 1440 watts.
    Too little to run a few laptops, a few extra screens, and the entertainment for several hours.
    Your thoughts?
    durban
    Thanked: 1068
    Default Re: Cheapest load-shedding battery solution
    Sorry for my ignorance but what would an ac input be used for?
    Krugersdorp
    Thanked: 121
    Quote Originally Posted by xsel7 View Post
    Your thoughts?
    Those high Watts inverter on 2x 105Ah batteries is not a good idea.
    105Ah x 2 = 210Ah
    210Ah x 12.8v = 2688Wh
    2688Wh ÷ 2 = 1344Wh usable on Lead-Acid batteries
    1344Wh ÷ 5000W = 16minutes (0.2688hrs) run time
    Rather get a 800W to 1000W inverter/charger to run essentials like internet & LED lights. Will also be cheaper than the 5000W
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2019 Toyota Hilux Extracab 2.8GD6 4x4
    2016 Bush Lapa Miskruier (Kampwa)
    Thanked: 19
    I can’t see that it has a ac input. Looks more like 2 ac outputs. If there was an ac input that would be used charge the batteries. Can’t see anything about it being able to charge batteries.
    are you looking for an inverter charger combined solution?
    Hilux 3.0 D4D 4x4; Stofpad Bashplate; LR tank; Racor
    Thanked: 1033
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    There is an IEC kettle plug input on the same side as the fans. It would appear to be a UPS type setup, instead of just a simple inverter.
    durban
    Thanked: 1068
    Does this mean it has a built in charger?
    Friemersheim, Southern Cape
    Thanked: 3127
    Quote Originally Posted by Monkey-D View Post
    105Ah x 2 = 210Ah
    Argument only holds true if you pull the full 5000W all the time continuously
    Thanked: 19
    Thanks for pointing out - couldn't see it on my phone.
    Still the price for a 5000 watt pure sine wave with built in charger less than R4k. I wouldn't plug my equipment into that
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    It would appear so. So it functions as a UPS.
    I would advise to check with the supplier before purchase though
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by Brand2011 View Post
    Keep in mind that the 5000W may be peak rating, and not continuous. One would need to look at the spec sheet for more details.
    Well, looking at the typical inline computer etc. UPS units, this is not far off.
    But, keeping 5000W going would require some serious battery bank.
    I believe people are too focused on the high watts of inverters, forgetting the batteries one would need behind it to keep that beast going for any significant period of time
    Thanked: 19
    From the website:
    Specifications
    Output Power: 2000W / 3000W / 4000W / 5000W
    Surge Power: Output Power x 2 (Double the output power rating)
    Input Voltage 12V or 24V
    Output Voltage 220- 240V AC
    Efficiency 90%
    Working Temperature 0 to 40 Degrees Celsius
    That would imply a surge output of 10 000 watt - probably kill the batteries
    B-gowrie Randburg
    Thanked: 295
    ... as I see it ...
    ... inverter will be only say 80% efficient AND only plan to rely on 80% of its rating :
    eg for 1000w inverter assume it will only be used to deliver 800w and furthermore will only be 80% efficient ie continuous net yield 640w ...
    Fully charged Battery bank needs be matched to deliver sufficient power to inverter for at least 4 night hours , being typical load shed duration... and ideally , dont want to discharge that battery bank more than about 20% before recharging so that cycle life of batteries is near maximum.
    ie plan for integrated , matched system.
    expensive esp batteries ...
    (only plan on basis of drawing 80% of inverters advertised rating (and still having to allow for efficiency loss !) for similar reason you wouldnt drive car continuously foot-flat ...)
    2002 Defender 130 DC HCPU. : Own the road...Any road
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    ‘1975 Series3 88 PUP... Simply Classic...
    ‘2017 Metalian Mini ... A Home from Home
    Apr 2016
    Thanked: 62
    Your thoughts?
    What are you needing to keep running?
    (Please don't include a 'plug point' in your list!)
    Mar 2011
    Walker Bay
    Thanked: 1068
    Can one DIY this at less than R13 000?
    Strand
    Thanked: 114
    Your thoughts?
    Why don't you look at the ecco inverter, think there's a supplier in Cape Town, I've got a 3500 watt ecco inverter charger ups solar ready for the past 11 months, no issues whatsoever
    Thanked: 1033
    This?
    https://www.geewiz.co.za/long-run-up...kit-1440w.html
    I use this one, but bought the inverter/charger separately (no box underneath it) and used my own two Deep Cycle batteries. I think the Inverter/charger was about R2k 18 months ago. It works for us. It has a 10 amp and a 20 amp charging option (switch) and we have put it on a timeswitch, so we turn it off for 1 hour a day. I do not think it is an intelligent charger.
    It runs for the 4 or a bit more hours and then it has drained less than 25%. Runs 8 x 5w Leds in and around the house, plus the HiFi, TV, Router and 4 lights are permanently plugged into it, so when the timer turns it off every night, those devices run on it for one hour daily.
    There is also this:
    https://www.geewiz.co.za/long-run-up...-kit-720w.html
    Quote Originally Posted by toppie4x4 View Post
    Yes, I am looking into that. Where did you get yours as I have not yet found a cpt supplier.
    Krugersdorp
    Thanked: 121
    Yes, but my point is that one should not pull as high as 5000W on a small battery bank. Lead acid lasts longer if you:
    - Charge over 8-10hours
    - Do a full charge when starting to charge
    - Discharge in 8-10hrs (or longer) - 170W on that bank
    5000W on 12V is almost 400A! You will need very thick wires and big fuses and a bank of a MUCH larger size.
    Increase the battery bank size, go with lithium or go with a smaller inverter. Your batteries will not last.
    Riaan
    Ok Guys, thanks for the input.
    I am now looking at a hybrid 3kva.
    I can probably get my hands on a RCT-axpert 3kva.
    Next up. A battery box like the ellies one.
