Defender Td5 clutch chirping noise
Results 1 to 13 of 13
    Oct 2014
    JHB
    Thanked: 20
    Default Defender Td5 clutch chirping noise
    Howzit guys
    About two weeks ago when driving out my driveway a chirping noise was coming from somewhere between the gearbox and the engine, I pushed the clutch in and stopped - the noise went away. I thought it was a bearing on one of the pulleys on it way out or the sound of a turbo failing. The noise occoured at 10 km/h so I ruled out turbo.
    This noise has returned now intermitently at speeds under 60 km\h, but louder and more frequent. It goes away when I press the clutch pedal, and the tune changes when I accelerate. It disappears when I take my foot off the accelerator pedal.
    Because the noise goes away when I press the clutch pedal I suspect it has something to do with the clutch.
    Has anybody experiences something similar? I'd like to troubleshoot other things before having the gearbox pulled.
    Gearbox, transfer box and diff oil changed 1k km ago so don't think its that.
    There is no slipping clutch, no shudder and no noise when the pedal is pressed or released.
    Currently on 237k. Unsure if clutch has been changed before.
    Apr 2018
    Fraserburg
    Thanked: 754
    Default Re: Defender Td5 clutch chirping noise
    Release bearing on it's way. Sort it as soon as possible because you will find your clutch will have difficulty in releasing soon and gear changes will become difficult. If it goes in traffic you will be the cause of the jam and will require a tow in.
    Oct 2014
    JHB
    Thanked: 20
    Thanks, I'll start looking for a clutch kit.
    Valeo seems to be what most guys use, what about other kits like LUK, Borg & Beck etc?
    Apr 2014
    Richards Bay
    Thanked: 100
    while you at it get a reinforced clutch fork
    1985 Land Rover 110 - 300tdi conversion
    It's always more fun on the road less travelled
    Oct 2014
    JHB
    Thanked: 20
    Will start collecting parts
    Oct 2014
    JHB
    Thanked: 20
    Just to confirm diagnosis, will the release bearing make a noise once the clutch is engaged? This is the only time the chirping noise occurs.
    Mar 2016
    Thanked: 2067
    Quote Originally Posted by miks. View Post
    Yes
    Mar 2015
    New Germany
    Thanked: 479
    Just fitted my LOF clutch kit today, solid flywheel not the duel mass one it is the TD5 SMF Power speck Bundle seems to be very quiet and working well
ID:	557417   Click image for larger version.
    2005 Defender TD5
    Oct 2014
    JHB
    Thanked: 20
    I've seen these guys online, seem to be the next 'thing' for Land Rovers. Found that kit on their website, it seems well priced since it included the flywheel.
    Everything I've read about the TD5 clutch replacement says the flywheel should not be converted to a solid one as it can bugger the crank. If they are selling it I'm sure they have done their research though
    Mar 2015
    New Germany
    Thanked: 479
    I read up on it and did not find anything about buggering up the crank, I found that Others tried diffrant solid mass from other company’s and they were nosy and had vibration, and all good stuff about there guys, and they are selling more solid then duel mass
    2005 Defender TD5
    Ruimsig
    Thanked: 9956
    Yes. It only engages when you use the clutch. You should do the clutch plate while you are at it and check the condition of the pressure plate.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Dec 2014
    Thanked: 1831
    Having just been through a failed release bearing and the associated nausea on my Disco, I can only agree with this.
    Replace everything that is replaceable inside the bellhousing.
    Flywheel, clutch plate, pressure plate, rear main seal, spigot bush, the plastic liner in the release fork, the plastic clip on the release bearing and the input seal of the box.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Jul 2015
    Thanked: 37
    One of my old D2 TD5s had the same symptom for years about 5 iirc before the clutch started slipping and obviously had to be changed. The flywheel was still fine.
    The release bearing is unlikely to fail catastrophically, just dont sit for long periods with the clutch pushed in.
