Results 1 to 18 of 18
    Jun 2016
    Default Gen 4 rear door strut
    Does anybody know where I can get this part other than the stealers ?
    Dec 2010
    Thanked: 168
    Default Re: Gen 4 rear door strut
    Quote Originally Posted by MrJuls View Post
    Order one on www.rockauto.com
    Select the 2018 Mexican Montero model - its the same as our Pajero.
    Teen die Berg langs die See
    Thanked: 298
    Masterparts maybe?
    Oct 2018
    Sandton
    Dieselectric has a huge variety.
    Nov 2012
    Thanked: 1597
    I bought one recently from Mitsubishi. R1800. Complete with mountings and lock. I don't think it's too bad. Remember it is not a normal gas strut that pushes a door open.
    Choose life
    Oct 2018
    Sandton
    Quote Originally Posted by Coenoes View Post
    I take back the Dieselectric reco based on the above. They have standard hatchback type lift struts.
    Richardsbay, KZN
    Thanked: 17188
    What is wrong with the strut to want replace it?
    Walker Evans, Photographer
    Barberton
    Thanked: 2609
    Quote Originally Posted by Riaan van Wyk View Post
    If this is a serious question, then you and I are the only Gen4 owners to have never broken that strut.
    Such a robust car, with a butter and plastic strut.
    JHB EASTRAND
    Thanked: 18
    I've had 5 Paj, never broken one !!
    ANY LANDING YOU CAN WALK AWAY FROM.....IS A GOOD LANDING
    ZSL580
    Richardsbay, KZN
    Thanked: 17188
    The one knuckle, attached to the door wore out and didn't want to stay in place. Had a local poly injection company redo both sides so no it didn't break.
    Centurion, Pretoria, SA
    Thanked: 623
    Having read on Aus Pajero Club forum how easily they break theirs, I have tried to be careful with mine. The biggest danger is some one closing the door when the strut is in locked position. They buy theirs online mostly.
    See thread here: https://www2.pajeroclub.com.au/forum...ad.php?t=19303
    Peter
    SOMETIMES I WAKE UP GRUMPY,
    Barberton
    Thanked: 2609
    Quote Originally Posted by KINGAIR200 View Post
    I'll make sure to add you to the list next time. But it looks as if I'll have to take Riaan off. I know cheating when I see it
    Feb 2019
    Thanked: 335
    Mine also broke a week or so ago. It made like mitosis and split . Leaked all the damping fluid on the pavement.
    Jun 2012
    secunda
    Update for those looking. Bought one from Mitsubishi today. Paid R1663. 00. Name:  IMG_20210519_174012.jpg
    Johannesburg/Prague
    Thanked: 120
    Mine still fine after 13 years of use but I have the SWB so one has to use it more than the LWB where its easy to put things in the rear seats , but a crap design , waiting for when it fails
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
    Feb 2017
    Potchefstroom
    Thanked: 80
    Has anybody fitted a Gen 3 unit?. They seems to be a lot more robust. My sons also broken after his friend tried closing the door when in locked position.
    Bellville
    Thanked: 212
    Quote Originally Posted by Cobus RDW View Post
    My guess is that most get broken this way (mine as well). Luckily it happened years ago when they still cost R 1000 and the family was made well aware of it, so no more "accidents" after that!
    As said, if they are treated correctly, should last the life of the vehicle, but it remains a vulnerable design. The rest of the vehicle is so perfect, they had to make a mistake SOMEWHERE ...
    2011 Pajero 3.8 GLS LWB
    Thanked: 298
    I replace mine with a 250 Newton trailer lid shock, works like a charm. initially had a 350 N one, but that pushes the door open to quickly and breaks the shock.
