Air Coupler Fittings
Results 1 to 11 of 11
    Gaborone, Botswana
    Thanked: 1203
    Default Air Coupler Fittings
    What is the most common fitting/coupler for the quick release?
    All my equipment has the left (in the image) fitting, but I have plenty of the other fittings in my archives. To make a change will not be a problem.
ID:	556889   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1203
    Default Re: Air Coupler Fittings
    Anyone?
    I just want to know what is the more popular (most used) one of the 2.
    Kobus
    Bellville
    Thanked: 34
    Depending on which quick coupler is used, they are often interchangeable. The one on the left(smaller diameter tip but longer) goes into the o-ring in the coupler. The other one (larger diamer, but shorter) pushes on the face of the o-ring in the coupler.
    In my experience I have seen the one on the left (smaller and longer) much more often
    Triton 3.2 DiD
    Gaborone, Botswana
    Thanked: 1203
    I got this. Everything fits nicely together.
    Kobus
    Gaborone, Botswana
    Thanked: 1203
    Not so good ending.
    I bought an 8mm x 20m "High Pressure Hose" (note the quotation marks) from Builders Warehouse. TradeAir 20 Bar rating printed on the hose and "Tested to 1750kPa" on the packaging. (17.5 Bar ?? )
    Attached the fittings, connect to compressor (@ 8 Bar) and BAM ! Hose popped.
    Will take it back tomorrow for a refund.
    Kobus
    Friemersheim, Southern Cape
    Thanked: 3253
    First off, the LHS fitting in pic is one to get.
    Secondly I would not buy specialised items from Builders aka Massmart aka Wallmart.
    Best to go to Rubber pipe/ Pressurised pipe supplier. Here in our area a few that are better priced than Builders. But I do not know situation in Gaborone
    Gaborone, Botswana
    Thanked: 1203
    Jip. My mistake. In my defence, it was rated 20Bar
    I have a hose that I got from a local hydraulic shop more the 15 years ago. It still in everyday use. I should have went back to them for the new hose.
    Kobus
    Gaborone, Botswana
    Thanked: 1203
    To finalise this:
    I got a refund from Builders (5 minutes in and out - well done ) and went to the hydraulic shop.
    Got a hose at 4 times the price as the Builders one.
    I found the spec. 20 Bar WP and 60 Bar burst pressure.
    Job done !
    Kobus
    durban
    Thanked: 1120
    I bought some blue hose from Adendorf.Its real [email protected] How much per meter does that hose go for.?
    Gaborone, Botswana
    Thanked: 1203
    The quote was BWP80-00/m
    After discount I payed BWP1100-00 for 20m. (55/m)
    In SA it would be much less.
    (Dynamische - It looks like a well known brand in the hydraulics industry. )
    Kobus
    Oppierotse
    Thanked: 262
    On my compressor I use the same hose that they put on gas bottles. Cant remember exactly how long ago I fitted it, but it is more than 15 years ago and still no cracks.
    The pipe is also soft and rolls up easily.
    98 Hilux 2.8D D/C 4x4
