Smart Battery Charger
Results 1 to 9 of 9
    Aug 2015
    Thanked: 125
    Default Smart Battery Charger
    In the market for a charger for my 105 Ah semi deep cycle battery.
    Short listed the following-
    Optimate 6 (5 Amp) - R1500
    Noco genius (7.5 Amp) - R2300
    Victron Blue Smart (15 Amp, has Bluetooth, Lithium compatible) - R2500
    Does the amperage matter? The higher the better?
    I really like the Victron as it's lithium compatible, but is 15 Amp bit of an overkill?
    What do you guys suggest?
    Default Re: Smart Battery Charger
    Hi Teryos..
    I have a 15A Victron with 2 x 102 AH batteries on charge all the time....no problems.
    The batteries run 1x 82L Snomaster, 1x 52L National Luna , all the caravan lights and the water pump.
    The Victron copes very well with the load.
    Consider the Victron with the option to add another battery.
    Louis
    Louis Pretorius
    Amarok Bitdi 4 motion ( myne )
    Suzuki Swift Sport ( vrou s'n )
    Jurgens Xcape
    Aug 2015
    Thanked: 125
    Quote Originally Posted by tierboskat View Post
    Hi Teryos..
    Louis
    Thanks Louis, I see Victron ticks few more important boxes than the other ones. Can you regulate the Amperage?
    Teryos
    As far as I know the charger regulate the amps needed to charge the batteries.....the lower the battery volts etc.
    the more amps it will supply.
    The app on my phone shows the current status of the batteries and you will see the Volts and Amps supply.
    When in storage mode it supplies 13.4 volt and 0 amps.
    Louis Pretorius
    Jurgens Xcape
    Nov 2017
    Thanked: 206
    The higher the amperage the better. The battery and charger will self regulate the amps going into the battery.
    With eskom's blackouts last year a lot of people were caught out with low batteries, despite having good chargers, there simply was not enough time for the smaller chargers to put back enough charge - the 5 to 7.5 amp chargers.
    With a 15A charger you will probably find it charging at about 8 to 10A depending on battery make/chemistry etc. That is enough to make a big difference, the other plus is if you connect a bigger capacity battery later on or have multiple batteries.
    Mossel Bay
    Thanked: 74
    I have the Optimate 6 (5 Amp) and its nothing special but maybe I expect to much from a smart charger. I want a charger that if I put a dead 10.2V battery on it it must be able to bring it back to life even if it must go through a 1000 cycles lol and the Optimate 6 cant do it.
    King Williams Town
    Thanked: 983
    Quote Originally Posted by Teryos View Post
    To explain it as I understand.
    If you buy a eg 15amp charger and the battery needs 30amps to charge full. Then the battery will take twice as long to charge. If you buy a 5amp charger then the battery will take 6 times longer and you won't be pushing the limit on your charger. As been mentioned, the battery will determine what current it needs to charge at. Bigger charger current delivered, less charge time of battery.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Aug 2015
    Thanked: 125
    Thanks guys for your input. One question. I understood these are AC to DC charger to charge battery at home when the battery is not being used. However, can these chargers be used in car? What's the use of the cigarette lighter connector that comes as an accessory?
    Plett/Paulshof
    Thanked: 840
    No they cannot. For this you need a dc/dc charger. The 12v accessory plug in cars is for low current drawing items.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
