Results 1 to 13 of 13
    Jan 2008
    Default Rear brake disc's on Jimny Gen3??
    Hi guys,Just out of interest, has anyone done this conversion?
    2017 PAJERO SPORT 4X4 / 2018 JIMNY GEN3 / EX - 2000 Pajero CK 3.5 V6 SWB GEN3
    JHB
    Thanked: 99
    Default Re: Rear brake disc's on Jimny Gen3??
    I have read about it, you can search here https://www.bigjimny.com/
    2012 Pajero Sport 3.2 A/T
    2020 Forester 2.0IS CVT
    EX: 2001 colt V6, 2010 jimny
    Jan 2015
    Thanked: 119
    You mean like this?
    Yes, I have.
    2009 Zook Jimny Sport - with too many extras to mention
    True fuel consumption is shown as FuellyData+7.4%
    Build Thread: http://www.4x4community.co.za/forum/...ead?highlight=
    Jan 2008
    Yes just like that. Anyone knows where to source the parts?
    Jan 2015
    Thanked: 119
    Quote Originally Posted by KPakkiri View Post
    You can get from either UK or Aus, but works out expensive.
    So I DIY’d.
    Calipers are Renault megane/scenic
    Brake lines custom made
    Disks are JIMNY front disk
    Backing plate cut for a spacer
    Bearing retainer from SJ is used to hold bearing in place
    Brackets are custom made
    Took me about 2 days including all the running around.
    May 2011
    Thanked: 946
    AFAIK the Jimny's parking brake is in the rear drums. Obviously with the disc conversion you lost your parking brake. How did you overcome that?
    Mike Nieuwoudt
    '89 LR 110 V8
    Jan 2015
    Thanked: 119
    Quote Originally Posted by Mike N View Post
    Correct. But the rear calipers are hand brake activated as well. So I still have a very functional handbrake
    May 2011
    Thanked: 946
    Ok, so the Scenic calipers are rears with handbreak levers. Great!
    Mike Nieuwoudt
    '89 LR 110 V8
    Jun 2016
    JHB
    Thanked: 101
    Rivar..... What did you use for a proportioning valve once you did the conversion?
    Jan 2015
    Thanked: 119
    Quote Originally Posted by Wooky View Post
    Nothing. Not necessary. I made a few adjustments on the brake pedal but otherwise not needed.
    Brakes like a champ and fronts lock up before the rears. Tested on the road and at road worthy center.
    Jun 2016
    JHB
    Thanked: 101
    Thanks Rivar....
    Thinking of doing this on my SJ
    Jan 2008
    Quote Originally Posted by Rivar View Post
    You can get from either UK or Aus, but works out expensive. So I DIY’d. Calipers are Renault megane/scenicBrake lines custom madeDisks are JIMNY front diskBacking plate cut for a spacerBearing retainer from SJ is used to hold bearing in placeBrackets are custom made Took me about 2 days including all the running around.
    Thanks Rivar,How much should one budget for this conversion?
    Jan 2015
    Thanked: 119
    Depends on how DIY pro you are.
    Cost me a few pennies
    Disk - R600
    Pads - R350
    Metal - R100
    Laser cutting - R300
    Odds and ends - R150
    Bearing retainers - R100
    And plenty of time.
