Defender Defender 90 - TerraFirma
Results 1 to 20 of 23
    Feb 2015
    Thanked: 90
    Default Defender 90 - TerraFirma
    My D90 is being loaded on the truck today and can't wait for arrival.
    I am planning a 2" lift, but want longer travel and better articulation for the more extreme off road bits.
    I have the below in mind as a combination? Any advice will be much appreciated.
    2000 Land Rover Defender 90 2.8i
    2016 Ford Everest 3.2Tdci XLT AWD A/T
    Always go for the deepest mud, muddy stories make the best memories!
    Forest Hills, KZN
    Thanked: 803
    Default Re: Defender 90 - TerraFirma
    Did you post this on Facebook?
    2003 LR Discovery 2 Td5 ES - mods list to be updated [Husky]
    Feb 2015
    Thanked: 90
    Haha I am posting everywhere!
    There is a alot of experience on this forum that is not on Facebook. Want to get ALL the info and make the decision.
    Forest Hills, KZN
    Thanked: 803
    Quote Originally Posted by Henko88 View Post
    Cool. I don't think you need the dislocation cones if you only doing a 2" lift.
    Feb 2015
    Thanked: 90
    The shocks are 5" long travel, hence me wondering about the dislocation cones?
    Can the coil flex that far?
    livingstone
    Thanked: 163
    I'm also considering Terrafirma for my 130.
    I'll be traveling to Kempton Park in early March, who would be the nearest supplier for me to contact?
    Feb 2015
    Thanked: 90
    Quote Originally Posted by tripodontour View Post
    From TerraFirma website
Name:	Annotation 2020-01-29 101210.jpg
    Thanked: 596
    Extend bumpstops to make sure shock does not internally act as bumpstop.
    Make sure front and rear universal joints does not bind on full axle drop with those long travel shocks.
    Learn to live with the inevitable front propshaft vibrations you wil have with lifting a Defender (that is if your actual running height will be lifted, and the "lift"is not just to compensate for extra permanent load).
    To be able to use articulation, remove anti roll bar/s.
    Drive slowly on the open road, Landies with a lot of articulation, lift, and no roll bars tend to roll over rather easily (go look at British 4x4 and other for the number of rolled Landies).
    '89 LR 110 V8
    Feb 2016
    Thanked: 772
    if you want the springs at a cheaper price, have a look at my ad: https://www.4x4community.co.za/class...ring-set/cat/5
    Melkbosstrand
    Thanked: 427
    You definitely need cones.
    My 90 has 2" longer coils and 2" longer shocks, so doesn't flex like yours will
    The tops of my coils are permanently mis-seated slightly outward of the seats. They don't touch my tyres but YMMV
    I can put them back but the first flex pops them out again so I never bother. I'll do cones one day when the rush is over.
    I have TF on my D2 and 90, and had them on 2 prior D2's. I like them
    Rob
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Forest Hills, KZN
    Thanked: 803
    Quote Originally Posted by Hagu13 View Post
    Ok, i'll stick to Discoveries then.. apologies @OP
    Thanked: 230
    2" lift on a 90 is looking for trouble, seen quite a few on their sides...
    I have the TF adjustable though, but std ride height, they are brilliant
    Feb 2015
    Thanked: 90
    Thanks for the input so far.
    As expected the info here is better than social media...
    I am going to check capabilities with the stock suspension for a while, and take it from there.
    I am pretty set on the adjustable though. I have heard the stories of the hard ride in the 90, so I am hoping the TF's sort that a bit too
    Melkbosstrand
    Thanked: 427
    Quote Originally Posted by D-tox View Post
    Nah
    My 90 has a 2" lift in, but it actually sits higher because I've added quite a lot of lightness. Cast iron diesel replaced with alloy V8, SW converted to PU with all jump seats, carpets, etc removed.
    I'm confident with one hand on the wheel up to 160km/h.
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Thanked: 596
    Nah
    I've been lucky so far with one hand on the wheel up to 160km/h.
    Fixed
    '89 LR 110 V8
    Melkbosstrand
    Thanked: 427
    Fixed
    Whatever, Mike.
    I don't drive like that all the time but I have tested it.
    And I have over 10 000 laps of various race tracks under my belt so I've probably picked up a little along the way.
    I know the difference between a vehicle working, and the driver working
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Feb 2015
    Thanked: 90
    Definitely not planning on speeding, or anything close to rallying.
    My reasoning for the lift and suspension travel is aimed at offroading and keeping the wheel on the ground.
    Hence the me looking at the adjustable option
    I received a quote for the Pro Sport 50mm kit too, and the price is amazing, so considering that too
    Thanked: 230
    remember to watch your prop angles on the 90
    Mar 2011
    swakopmund
    Also if your 90 is fairly standard with not many accessories that adds weight e.g Bullbar, winch, roof rack, drawer system etc, then rather go for Terrafirma soft than medium.
    I had Terrafirma medium 2" lift, Tf pro sport shocks in my 90 2.8. It handled tar roads like a racing car with little body roll, but off road wasn't good as the medium coils was too stiff and jeapordised articulation.
    '12 Defender 130 2.2tdci '00 Defender 90 2.8i SOLD (ex wife gets the blame) '99 Defender 110 td5 csw SOLDNamboyz
    Feb 2015
    Thanked: 90
    Quote Originally Posted by goody2shoes View Post
    Thanks, I have a bumper in front, but not planning to add more weight, so the light load will do the job there.
    I already have a roofrack, and will probably have some sort of drawer system fitted with jump seats.
    For the back when doing offroading, I will 9/10 have about a 100kg of weight (loaded fridge, recovery gear etc) and on overlanding trips even more, hence me looking at the medium load.
