BFG underinflating caused delamination of sidewalls?
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
    Thanked: 59
    Default BFG underinflating caused delamination of sidewalls?
    Recently back from Moremi which was wet and sandy, deflated my BFG AT KO2 to 1.7 bar, keeping a check on pressures with a tyre pressure monitor. Tyres were fully inflated before driving on hard dirt/tar.
    I took Hilux to Autowiel who sold me the tyres for wheel alignment etc only to find that the two rear tyre sidewalls had delaminated on the inside.
    They called the rep in who inspected the tyres and showed me a pic he had taken of the tyre pressure sticker on the door frame, said the tyres had been deflated below manufacturers spec and it was not their problem. He did say they were prepared to take the tyres and cut them open to see if there was a manufacturing fault... but I would loose the tyres unless there was a fault. The reps attitude in taking the pic of recommended pressures as evidence convinced me that would be a pointless exercise.
    This is nothing I have ever heard of as far as I know its standard practice to deflate in sandy conditions and have done so on so many occasions all over Africa.
    If that is so BFG and the tyre dealer should warn not to deflate!
    The tyre dealer was well aware of my mainly offroad use so should also not be recommending BFG that being the case.
    Autowiel has always given me good service but this is unacceptable IMO. Two tyres with less than 10k km gone!
    Also one small puncture in the front tyre... Disappointing compared to my old BFGs... not a problem in 100kkm with deflating or punctures.
    Cape Town, Plumstead/The Sea/Franskraal
    Thanked: 554
    Default Re: BFG underinflating caused delamination of sidewalls?
    Yay, one more person that won't buy BFG again!
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
  3. The Following User Says Thank You to ZuluCowboy For This Useful Post:
    Ellisras
    Thanked: 558
    Weird
    I have nothing short of really abused my KO2s. On very rocky terrain (hard not loose) I have gone as low as 1.3 Bar
    Did fairly long distances on bad dirt roads at 1.7 Bar to dampen the corrugations
    My Patrol 4.2D is heavy - laden in back with 136 litres of fridges FULL. + Towing Offroad trailer with everything including lots of water and batteries....
    No issues....
    Sep 2018
    Not too far from Pofadder
    Thanked: 416
    I do not thing I will be trying BFG any time soon. I would have taken him on on the cutting open offer as I would not use them like that in any case.
  6. The Following User Says Thank You to Bex For This Useful Post:
    Ruimsig
    Thanked: 10309
    With both of your rear tyres exhibiting the same failure I would investigate vehicle related causes. This is just my opinion.
    Had it been 1 front left and 1 rear right for instance, I would be less inclined to think vehicle. If it were just 1 tyre anywhere on the vehicle I would be more inclined to think tyre problem.
    Its a pity you cant put the fronts on the rear and replicate the load/journey you took to see if they deteriorate also
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Alicedale
    Thanked: 11
    I had severe splitting on Cooper ST MAX, 3 of 4 tyres. Also "under inflated" according to agents
    '18 Hilux 2.8 Auto 4wd
    '19 Fortuner 2.8 Auto 4wd
    Wartburg
    Thanked: 1558
    I had cracking of the inner wall on my third set of BFG AT at about 40k km. All 4 tyres. This was only discovered as we could not plug small air leaks on the shoulder of one of the tyres, and then taking it off the rim to fit a gater on the inside. The first set gave me 120k km, and the second only 80k km, but no cracks.
    The rep was not interested in any compensation after hearing that I had deflated the tyre for sand driving. This set saw about 95% tar road. I was told that when you deflate to less than recommended road pressures, you are on your own, even on off-road tyres. Needless to say, I never owned another set of BFGs
    Feb 2012
    Chintsa East
    Thanked: 471
    My Coopers did the same. I was told that I abused the tire, under inflation, overloading, driven flat, pothole blah blah blah. So over them on Good year adventurers now no problems.
    2013 Disco 4 XS Lifted
    Plett/Paulshof
    Thanked: 994
    I cannot find any info on any Tyre manufacturer site that you have to adhere to a minimum Tyre pressure. Has anyone seen this info before?
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
    Gauteng
    Thanked: 947
    Took me 3 minutes....
    https://www.bfgoodrich.co.za/auto/he...e/faq-4wd-tips
    At BFGoodrich Tires South Africa, we recommend that you carry a quality tyre pressure gauge and drop your tyre pressures by 0.3 Bar at a time until you reach your optimal footprint on the sand that you're driving in. We advise not to drop your tyre pressures to under 1.4 Bar. By dropping your tyre pressure, you're increasing the tyre's footprint on sand, increasing the area of contact between your vehicle and the road.
    Seems the dealer and rep gave the OP "Thee old rope-a-dope". Projected the problem onto the OP....
    I would have taken them on. I have been using BF's now for 9 years. KO, KM2 muds and now KO2. I have only had 2 tyres (KO2's) with balancing issues and dealer replaced them immediately. I do think BF has a quality control issue. My opinion though.
  13. #11
    Cape Town - RSA
    Thanked: 350
    well...one rep should not be the end of a good brand. So I would try another route, speak to head office or something.
    Still it sucks and no fun.
    Ex - 2005 Cherokee CRD
  14. #12
    Ruimsig
    Thanked: 10309
    I agree. The cost of 4 or 5 tyres is a small fortune and one should expect a good number of kliks/years out of them.
    Hummer H3 V8
    W.A.P Objectivist
  15. #13
    Okahandja, Windhoek
    Thanked: 852
    At 1.7 bar I would not leave it there.
    Thats the issue with these 3 ply sidewall tyres, heat build up at low pressure and if the rubber getting close to the end of its life span, older than 5 years or what ever, and using a stiffer rubber also. I lost a set of KM2's with lamination and cracks but they have done several dune trips at 0.8 bar and they were maybe 8 years old already.
    But will never go without my BFG , due to the above properties, which makes them less puncture prone.
    Johan Kriel
  16. #14
    Thanked: 128
    Been there, done that with BFG's. Using General Grabber, only lost one tyre due to stupid driving on my side, on a 5k km trip in Namibia. Much cheaper to replace.
    ORRA Callsign: X130
  17. #15
    Jan 2014
    Ezulwini Eswatini
    Thanked: 1994
    I had a similar issue with 1 grabber At on my old terg rep replaced it no questions.
    the other one got a side wall damage- was sent away and repaired.
    all from the conti partner- tyres originally bought at TWT
    2011 VW Touareg V.8 TDI
    2006 VW Touareg 3.0 TDi air suspension aka Pumba ( sold)
    2003 Pajero IO 2.0 aka Bosvark
  18. #16
    Oct 2015
    Thanked: 94
    Does this have something to do with the sidewall carry capacity strenth? My Dunlop AT3 is rated 112T which has a rated capacity of 1120kg per tyre.
    Does this have something to do with deflating and the wear of the sidewalls when running lower pressure?
    I dont know if Dunlop has a minimum pressure? I have run my Dunlops at liw pressures of 1 bar for many days in a row in the Moremi/Savuti and Namib desert.
    How can a reputable manufacturer have this kind of service with your BFs?
    ONE LIFE!
  19. #17
    Ellisras
    Thanked: 558
    Was the problem on fixed axles or independent suspension ....
  20. #18
    Ruimsig
    Thanked: 10309
    I would guess the Hilux is live axel rear and IFS front?
    What are you scheming? Torque and axel movement?
    Hummer H3 V8
    W.A.P Objectivist
  21. #19
    Plett/Paulshof
    Thanked: 994
    The other problem comes in where you see vehicles being overloaded. Bakkie loaded to brim, roof rack with tents etc. towing trailers. So maybe the Tyre guys have a point.
  22. #20
    Jun 2015
    Pretoria East
    Thanked: 663
    Last year I discovered the FJ we bought second hand with 54Kkm on had cracks inside the tread of 4 tires, KO2ís. They were less than 18 months old.
    I logged a call with Michelin HQ and promptly received feedback, the agent made an appointment, did the measurement and I was refunded the wear on the 4 tires, no questions asked. I walked away feeling satisfied, not knowing how the tires were treated.
    I will advise you do the same.
    Dirk Theron
    Land Cruiser FJ
    Hilux 2.8 GD-6 Auto 4x4
    BL865 Ratel4
    Lifeís a journey, enjoy the ride
