3kVa 24V Lithium Loadshedding Solution/UPS
Results 1 to 11 of 11
    Feb 2017
    Thanked: 32
    Default 3kVa 24V Lithium Loadshedding Solution/UPS
    AVAILABLE FIRST WEEK IN FEBRUARY 2020. NOW TAKING PRE-ORDERS.
    VIEW ONLINE
    • BlueNova Energy “Loadshedding Solution”/UPS….
    • Synapse 24V/3000VA (2400w @25 deg) Hybrid Inverter, (MECER if Synapse is not available)
    • 2 x BlueNova Energy BN13V-108-1.4K MPS LiFePO4 Batteties @ 108Ah =2.8kWh Storage.
    • Full electrical DB with Earthleakage and circuit breakers.
    • Two(2) 3-pin 230V AC outlets, both with dual USB charging ports.
    • 230V AC output can also be integrated into main electrical DB if needed. (Split DB required ) Electronic, shunt driven Intelligent Battery Monitor onboard
    • PRICE R 29 899 +VAT
    Gabriel Erasmus
    National Distributor of Premium Batteries & Accessories
    087 021 0505 / [email protected]
    www.batteriesonline.co.za / www.vartabatteries.co.za / www.truckbatteries.co.za / www.smartchargers.co.za
    Plett/Paulshof
    Thanked: 792
    Default Re: 3kVa 24V Lithium Loadshedding Solution/UPS
    Gabriel, how easy is it to connect this to an existing DB board with automatic changeover switch? Does the inverter have a solar mppt input?
    2016 LC 200 VX, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
    Thanked: 132
    Beware of BlueNova.
    I advise my father to consider their Impi with additional battery which he bought and had installed. The batteries stopped equalizing and other errors.
    Now, the installer is nowhere to be found, have contacted 5 of their other registered installers on their website with ONE reply, stating they do not install BlueNova equipment anymore, the other 4 no reply.
    Spoke to their "sales" manager, only to be told to bugger off, they don't deal with the public directly.
    Fair enough, but neither does 25% of their listed installers in Cape Town...
    So, choose your installer/supplier carefully.
    '00 Nissan D22 QD32Ti 4x4 D/C
    '10 Toyota LC150 4.0V6 VX
    Hillcrest, Malaysia
    Thanked: 6039
    Honestly, I think you have a winner there.
    Notwithstanding the above post, which may not be representative of your product which only uses the two 12V packs.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Jun 2019
    Thanked: 20
    This is very tempting.
    I had a 4000 W, or maybe 5000 W, 48V system installed 3 or so years ago. Sold the house, so kept the system in as a selling point as the house was in a dump of a small town in Northwest province.
    Big mistake! Running a gennie in Joburg in a complex, is not always the best neighbourly thing to do, so we are often just sitting out loadshedding or unplanned outages.
    Let me hear what the boss lady says....
    - Commander Hemi
    - Metalian Genie
    Plett/Paulshof
    Thanked: 792
    I would like this with a 5kva Synapse Hybrid. Maybe build my own.
    Thanked: 132
    Quote Originally Posted by fluffy View Post
    honestly, i think you have a winner there.
    Notwithstanding the above post, which may not be representative of your product which only uses the two 12v packs.
    24vdc
    https://bluenova.co.za/wp-content/up..._datasheet.pdf
    Regardless, still does not improve the bitter taste of supporting Proudly South African.
    Hillcrest, Malaysia
    Thanked: 6039
    Quote Originally Posted by batteriesonline View Post
    VIEW ONLINE
    What is the black housing made of.
    ZS5KAD
    3 V8's
    durban
    Thanked: 853
    What life expectancy can one look for in batteries like this and for a nooby to this how is the dod done.Does it have a built in set up so you cant drain the whole thing or is that programmed in the big white box.?
    Hillcrest, Malaysia
    Thanked: 6039
    The big white box looks after all that for you. The reason this unit uses the fancy Lithium batteries is to maximize life expectancy.
    Expect about 5 years if pushed hard every single day.
    Don’t forget this is a UPS / Loadshedding unit. Used like this the system should last almost indefinitely. Most likely failure modes are Durban cancer or theft.
    ZS5KAD
    3 V8's
    Plett/Paulshof
    Thanked: 792
    [QUOTE=Fluffy;4315910]The big white box looks after all that for you. The reason this unit uses the fancy Lithium batteries is to maximize life expectancy.
    Don’t forget this is a UPS / Loadshedding unit. Used like this the system should last almost indefinitely. Most likely failure modes are Durban cancer or theft.[/QUOTE
    "Durban cancer or theft". Love this!!!!
