New NL Battery Box - The All in One Solution??
Results 1 to 20 of 88
    Bethlehem
    Thanked: 3376
    Default New NL Battery Box - The All in One Solution??
    https://www.outdoorwarehouse.co.za/p...les-and-hardwa
    At R 8999. Lets get the Price out of the way first. Pricey yes, but look at what's included, and a 5 Year Guarantee to boot.
    Is this THE solution for me??
    1) Occasional Oztent camping, with the fridge/lights in or near the tent(s)
    2) The fridge is used in more than one car
    3) Occasional caravan camping, the van only has 220v
    I have 2 x 85w solar panels.
    So.…….isn't this the solution for, lets call it a "Beginner" that wants 12v in the 3 scenarios above?
    See also here...……….another Thread on this Product : https://www.4x4community.co.za/forum...C25-Power-Pack
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
    Pennington
    Thanked: 150
    Default Re: New NL Battery Box - The All in One Solution??
    If the unit is to be used in more than 1 vehicle then you would need to hard wire each vehicle for charging whilst travelling. This is the same for both units mentioned. The NL is a great product. I would go the 2nd option with the wrnd purely due to cost and do some DIY.
    Is your van eqioed with a battery for the water pump and lighting, using 220v for the fridge and power points?
    Ruimsig
    Thanked: 4543
    OW is not the cheapest, you could probably find it at a slightly lower cost somewhere else. But I think it is a very versatile and well specified solution.
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
    Okahandja, Windhoek
    Thanked: 763
    Nice, but the price. Just checked last night for someone else you. You can do a basic dual battery system for as less as R3500 yourselves, battery included.
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Forest Hills, KZN
    Thanked: 739
    Agreed. If that all in one solution included the battery and the NL charger I'd consider it.
    I have the V2 of the battery box and it works a treat - easy enough to do my self and cost way less.
    2004 LR Discovery 2 Td5 GS - mods in thread en route. (Ingwe)
    Plett/Paulshof
    Thanked: 794
    I bought this https://www.outdoorwarehouse.co.za/p...er-pack-1/6424
    and added my ctekd250s plus an inverter to it. Wired for both my vehicles. Much more reasonable especially if you add the wrnd option.
    2016 LC 200 VX, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
    Forest Hills, KZN
    Thanked: 739
    I did the following:
    https://4x4direct.co.za/battery-boxe...ttery-box.html
    https://4x4direct.co.za/dc-to-dc-cha...110661867.html
    https://4x4direct.co.za/home-charger...y-charger.html
    105AH Battery
    Cabling - R1000 approx - Wired myself (except the main cable from primary battery to boot) - I was too lazy
    Thanked: 541
    Is something like this not similar? Excuse my ignorance.
    https://www.kgalagadioutdoor.co.za/i...id=70&Itemid=3
    Plett/Paulshof
    Thanked: 794
    Limited on solar and inverter.
    Not dual battery system as NL with solenoid.
    Not bad though.
    Bethlehem
    Thanked: 3376
    Nice Bruce but remember I have nothing, no dc to dc or anything, so I'm starting with a blank page here.
    And yes, I'd like to have a portable power pack, definitely :
    1) Oztents……..nice to have a fridge with me, not in car
    2) Caravantjie - its 220v ONLY, so this is an easy(ish) 12v solution for off grid places
    3) Use in more than 1 car
    …........how to wire a vehicle here, just a cable from the battery through the chassis member to the back??
    Forest Hills, KZN
    Thanked: 739
    It's a good solution, but more costly when you can get the components separately and have a better system for cheaper.
    Bethlehem
    Thanked: 120
    Petri, you can build a nice box yourself for less
    I have the following:
    1 x High Lid Ammo Box
    2 x 105Ah Batteries, in the Box
    1 x 1000W pure Sine Wave Intverter
    1 x 20A WRND DC to DC Charger
    You an add various plugs and Options, like USB Chargers, etc. I would add 2 x Brad Harrison plug, 1 x small Hella plug, 1 x Large Hella plug and 1 x Dual USB Charger
    This gives you ultimate versatility, and with the inverter you can even use this as a mini loadshedding kitt to power PC, TV, etc.
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
    Plett/Paulshof
    Thanked: 794
    Hi Petri
    Yes, this one is the almost perfect solution. Wire to the rear cabin with fuse. Plug in to box for dual system. You can also charge via portable solar panel whilst camping.
    I added the ctek to mine(spare) so didn't need the fancy NL as per OP. I now have solar and DC-DC. I have a 90w fold up panel to charge as well. I did not want to add a second battery in engine bay of FJ so went this route. With addition of 4000W PSW Inverter I can also use it as emergency power back up limited by battery though. I can also run my nespresso machine
    Ellisras
    Thanked: 454
    That R9k is really expensive.....
    2000 Patrol GU 4.2D(onkey) old and wise at 844 000 km
    2014 Patrol GU 3.0CRD reaching puberty at 103 000 km
    Plett/Paulshof
    Thanked: 794
    Not really if you add up what the box has as standard. The DC-DC unit alone is pricey. Take that out and box is well priced.
    Ellisras
    Thanked: 454
    Correct - Replace that overpriced DC-DC with something else and it will be closer to the mark.....
    Jul 2014
    Thanked: 535
    Madness it doesnt even include a battery !
    Electronics are NOT expensive these days
    Platkar - Haaihoendaai i20 1.4]
    Ex'es
    KIA Sorento 2.5 Crdi 4x4 (diesel guzzler of note)
    Nissan Terrano II 2.7
    Mazda Drifter DC 2.5 4x4
    Toyota 60 series 5.7 V8
    Daihatsu Rocky 2.8
    Plett/Paulshof
    Thanked: 794
    Decent quality spec solar and DC-DC combo units are not cheap.
    Thanked: 133
    Bought a NL powerpack in 2009 ; bought as well a weekender NL fridge; took both to cahora bassa in moz ; no problems .
    Just had a ctek at the time and recharged the powerpack battery before or in between travels .
    At a later stage a friend gave me a kind of flat grey colour cable which we connected directly to the bakkie battery with terminals ;then put it across down the chassis and into the canopy space ; I then attached the red harrison plug of the grey cable to the red harrison of the power box and the NL fridge hella plug to the appropriate female hella of the power box ; works 100%.
    In 2017 I have attached a grey harrison to the back of the bakkie which I connect to the grey harrison plug of the power pack and to the grey harrison plug of the trailvan caravan ; it works 100%. If you need I will publish photos. Rgds.
    Bethlehem
    Thanked: 3376
    Hear what you saying Guys this isn't cheap, but:
    1) Im not even remotely a DIY guy
    2) 5 Year Guarantee means something, and NL has good aftersales service
    3) I like the compactness here,and everything is "tucked in", so it shouldn't be too prone to damage, its IS a portable unit after all and will get shifted a lot.
    So.………...
