New NL Battery Box - The All in One Solution?? - Page 5
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 81 to 88 of 88
  1. #81
    Aug 2015
    Thanked: 114
    Default Re: New NL Battery Box - The All in One Solution??
    Quote Originally Posted by dangermouse View Post
    How can the WRND DC to DC 20A charger be half the price (~R2000) vs HCDP DC to DC 20A (~R4000)?
    The only differences I can see is the HCDP is “waterproof”, but there’s nothing stopping me putting the WRND in a IP68 enclosure for much less than R2000?!
    I would love a side by side comparison of the following for brands/matching products:
    WRND
    HCDP
    NL
    CTEK
    Does anyone know if this has been done?
    There you go
    https://www.4x4community.co.za/forum...ger-Comparison
  2. The Following User Says Thank You to Teryos For This Useful Post:
  3. #82
    Mossel Bay
    Thanked: 67
    WRND
    HCDP
    NL
    CTEK
    I want to mount my WRND in a waterproof enclosure but is afraid of overheating,what do you think?
    2017 Hilux 2.4 SRX D/C 4x4 2012 Cross Polo [mamma s'n]
    http://travel.webshots.com/album/558867451ncpSPZ
  4. #83
    edenvale
    Thanked: 213
    Just to add to this
    the most important part to consider is "input voltage activation"
    National Luna stuff tends to only kick in and start charging when the input is above 13.5 v
    many modern vehicles will sit and charge at 13.2 once up and running, this means the NL will be "unlatched" the vehciles ecu will do a brief spurt to up the charging voltage at 14,5 post start and then once the main battery is replenshied from the first start the alernator demand is reduced to be more fuel efficient and allow smart control, this means the NL box isnt being charged
    please make sure your vehciles CONSTANT ie over HOURS of driving alternator output is enough to trigger this NL box
    Ask me how I know ?
    My Pajero would test fine but on the long road it would unlatch, then the same with my hemi jeep, I bypassed the circuitry in the NL box and effectively paralled my batteries to save the day
    Just please check your vehciles alternator output is enough to run the new NL box
    other than price it looks convenient
  5. #84
    Thanked: 296
    Quote Originally Posted by 3bar View Post
    Just to add to this
    Ask me how I know ?
    Thanks for the tip. Seems like NL thought about that and has included an ignition detection/override cable that you connect to somthing that gets switched on with the ignition.
    The voltages then drop as can be seen in this table.
  6. The Following User Says Thank You to oradba69 For This Useful Post:
  7. #85
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 179
    WRND
    HCDP
    NL
    CTEK
    You can add the Victron products and maybe the Benton as well
    I found the Ctek a bit sensitive to heat and it blew.
    The Victron charger mounted same place and already exceeded the Ctek lifespan with about a year and it was cheaper.
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  8. #86
    Jan 2017
    Rustenburg
    Thanked: 917
    WRND
    HCDP
    NL
    CTEK
    i think a lot of this stuff sells purely on the known name. The price National Luna charges for the “smart” solenoid is also ridiculous. It’s just a cole hersee 80 or 100AMP solenoid wired to a timed relay..... really not sure what’s smart about that, and you can have an original cole hersee solenoid and a timer relay for a 3rd of three price if it’s not in a National Luna box.
    ctek the same story. They were the first on the market and suddenly everyone needed a smart charger. But you can now buy a decent MPPT solar smart charger for 20 or 30 Amp for R2000.00, and it will even let you monitor your batteries with your smartphone. But someone will soon be along to say they aren’t meant for automotive applications and can’t handle the vibrations etcetc.....
  9. The Following User Says Thank You to RPiet For This Useful Post:
  10. #87
    Tshwanetoria
    Thanked: 647
    Quote Originally Posted by RPiet View Post
    Well, not everybody is "clever" with electrics, so we have to go on reputation.
  11. #88
    Thanked: 179
    If you shop around you can find a 15 Amp Victron IP65 7 stage smart charger between R2000-2500 - with Bluetooth
    Seen some people selling them for R3500
    A Benton goes a bit cheaper and does the same job.
    Good quality Solar panels of 100 Watts go for R700 to R2000 excluding VAT - same brand name at both shops.
    I stepped into this one and put up a fight at one of our well known outdoor shops - they took the panel back as it was still in the box.
    Got two for their price of one and had change
    A Victron MPPT 100/15 controller goes for between R1 200 to R3 000 - with Bluetooth you add about R600.
    At SetSolar Pta you could buy MPPT 100/15 just under R1k early 2019 when they cleared stock.
    I bought two then, should have bought a 100/30 as well as it was R1500 on special.
    They cost a bit more now.
    Some outdoor places only carry a specific well know brand at a inflated price.
    It all depends where you buy.
    Look at 4x4Direct.co.za, SetSolar.co.za, Waveinn and Takealot - watch out for specials.
