Map sd card
Results 1 to 13 of 13
Thread: Map sd card
    Mar 2017
    louis trichardt
    Thanked: 23
    Default Map sd card
    Hi I'm looking for a sd card to function the navigation feature on a after market radio.
    Any ideas where to get one wil be appreciated.
    Thank you in advance
    DIESEL POWER
    Friemersheim, Southern Cape
    Thanked: 3092
    Default Re: Map sd card
    Apr 2008
    Boksburg
    Thanked: 29
    Planet electronics in Pta
    Chris
    Pajero GLX
    Imagine Comfortvan
    Mar 2017
    louis trichardt
    Thanked: 23
    Just to update i managed to get the sd card and preloaded map. Im now struggling to get gps signal could my gps antenna be faulty. Is there a way to test it and where can i find a replacement antenna
    DIESEL POWER
    Thanked: 13577
    We'd need to know which radio. And model.
    Mar 2017
    louis trichardt
    Thanked: 23
    Its a paramount zx6200nbt radio
    DIESEL POWER
    Apr 2008
    Boksburg
    Thanked: 29
    Quote Originally Posted by nicodwt22 View Post
    Remove the radio and confirm that the antenna is plugged in.
    Chris
    Pajero GLX
    Imagine Comfortvan
    Thanked: 13577
    It does indeed seem to need a GPS antenna. If yours has one, you might have to reconsider its placement if it isn't picking up any Satellites.
    Mar 2017
    louis trichardt
    Thanked: 23
    I assumed that might be te problem so i orderd one waiting on delivery to test. To fit wil not be an issue as I've removed it a couple of times to ensure gps antenna is securely connected but no luck.
    DIESEL POWER
    Thanked: 13577
    PLACEMENT as in where it is situated, not REPLACEMENT
    lots of articles that say these antennas have to be OUTSIDE/ON TOP of the dashboard not INSIDE to pick up the satellites
    So consider this when you start testing again.
    Mar 2017
    louis trichardt
    Thanked: 23
    Sorry misread your post wil definitely try and move it to see what will happen.
    Thank you for your response and info
    DIESEL POWER
    Mar 2017
    louis trichardt
    Thanked: 23
    Het die gps antenna geskuif bo op dash maar het steeds geen sein nieName:  IMG_20200608_123858.jpg
    DIESEL POWER
    Thanked: 13577
    Dan is ek bevrees die radio se GPS receiver is murtu.
