Engine rebuilding lube
Results 1 to 20 of 22
    May 2010
    Sandton JHB
    Thanked: 106
    Default Engine rebuilding lube
    what doyou use on the bearings and bits when rebuilding engines and what is readily available in sunny SA??
    G
    Nigel
    Thanked: 2255
    Default Re: Engine rebuilding lube
    I put ghrease on the bearings and rings.
    Uniglide
    +27 zero eight 2 four 95 9252
    Kathu
    Thanked: 2744
    Quote Originally Posted by Gengis View Post
    G
    I uses Comp Cam`s products. Their cam lube on cams and engine assy lube on the rest. Most v8 shops in SA stocks them.
    https://www.compcams.com/engine-asse...-8-oz-jar.html
    edenvale
    Thanked: 221
    there are better ways to do it and you probably been getting away with it for years but using grease is not right, rather use an assembly lube like the comp cams one, or just a generous smear of new oil, the grease is often simply too thick and can block the small passages in the block and in the pistons between the rings where you want oil sprayed from the rod to provide lubrication and can cause the poor oil pump some major stress moving it through, once the engine is up to temp these concerns go away as the grease will be diluted and broken down but until it gets to temp grease is not doing your engine any good, and you may well get away with it but not for ever
    I blueprint race engines and build them for over 200hp a cylinder and i apply the same prinicples to all i build
    Jul 2010
    Modders
    Thanked: 243
    Wynn's no smoke.....only thing its good for
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
    Jul 2013
    Thanked: 288
    Mix no smoke and wynns gear oil treatment (also a enginge assembly lube)
    https://www.wynns.co.za/product/gear-oil-treatment/
    Wilderness
    Thanked: 1134
    The same oil that you would use to fill the engine. That is all that is needed.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Thanked: 2092
    Part prices can be high but the time and effort invested in rebuilding an engine is not something to waste. I use the best parts I can afford even if it has to be imported. I am not going to take chances on something that will "work". I use proper ass lube and that gives my engines the best protection at first startup. Yes I prime the oil pump and turn the engine by hand until there is oil pressure and if possible I remove the dizzy and turn the oil pump to get the oil through the engine but using proper ass lube has saved my engines unnecessary wear. The stuff below can be bought from The V8 shop
    Henk
    Follow us on Facebook
    Aug 2019
    Kimberley / Edenvale
    Thanked: 95
    Maybe the one time where its a bad idea to abbreviate assembly lubrication.
    Langs die rivier, op n berg
    Thanked: 2867
    Te koop by v8 shop, of alternatiewelik, adult world.
    durban
    Thanked: 1008
    lol
    joburg
    Thanked: 431
    Assemble, put in, start, then I use engine oil in a squirty old fashioned oil tin. If it's assemble, wait for other stuff to be done (like in a restoration/rebuild) then I'd use engine assembly lube.
    Thanked: 2092
    As long as you don't add an R Previous one was called Ass lube and the name just stuck
    Henk
    Nigel
    Thanked: 2255
    Quote Originally Posted by 3bar View Post
    This idiot from the bush is now confused.
    Uniglide
    Wilderness
    Thanked: 1134
    What is used in the factory's when assembling engines?
    What is used by Ferrari, Lamborghini, Jaguar, Porche, Bugatti, BMW, Mercedes, Toyota, Volkswagen, Ford, Scania, Volvo, Nissan etc, etc.
    Do they use special lubes?
    Dec 2014
    Thanked: 1787
    Lubriplate grease is very light/thin.
    I don't know what grease you use, but it will likely be thicker than the Lubriplate.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Nigel
    Thanked: 2255
    Very light thin grease.
    But as has been said. I have got away with it for years.
    Uniglide
    Kathu
    Thanked: 2744
    In most cases pressure oil injection.
    May 2017
    Kanoneiland
    I use Wynns Gear oil treatment
    Thanked: 2092
    I think you are the last person that anyone could refer to as an idiot
    The persons that taught me the most about engine rebuilding were also involved in competition engines hence my using assembly lube. Strangely it is a sticky type of greasy substance. I had to pull an engine out for some reason or the other after it had started and ran up to warm. When we pulled the big end caps there was still white assembly lube under the cap that had not washed out with oil. My bearing clearances were perfect as another one of my old school habits is plastigauge. Modern machine tolerances are good but not as perfect as the manufacturers want you to believe
    I can see no reason why a light grease would not protect better than a squirt of oil during assembly and first start up and to be honest I have used it an alternative when I did not have the assembly lube available so there I have just joined your idiot gang. Ps the engine did not blow up
    Engine break in additive is another well kept secret on older engines. To comply with regulations all zinc have been removed from modern engine oils and thus the benefit for hard wearing parts is lost. With Comp additive this is replaced at first start up and break in. It also allows for a smoother break in of a newly rebuilt engine, we use it in heavy horsepower engines as well as in my Mitsu ( it needs every bit of advantage to stay together)
    Henk
