Impressed with China Pure Sine Wave Inverter
Page 1 of 46 1 2 3 4 5 6 7 8 9 10 11 26 ... LastLast
Results 1 to 20 of 908
    Thanked: 474
    Default Impressed with China Pure Sine Wave Inverter
    Got my cheap China inverter today and tried it out with a load up to 1300W with my heat gun. Also started a 4 pole 0.75W induction motor a few times and it started as if connected to the grid. As expected the peak is not near the 3000W as indicated on this model. I will be checking the wave form on the scope in the morning.
    This design is available in 2000, 3000, 4000, 5000 and 6000W which is again the peak. One should then apply 50% of this value. It is made in 12, 24, 36, 48, 60 and 72V.
    It took was loaded on the plane on 17-01 and 3 business days later I received it via the courier used by Banggood. Interesting clearing customs took only 90min. I opted to pay the tax up front.
    Pictures of display is DC V, AC V and Watts. It has a mode switch to scroll through these 3 measurements or show any one of them all the time.
    Very impressed with the operation from 12V and selected this model in order to be able to use the car battery for power tools when on the move and on site.
  2. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
    Rangeview Krugersdorp
    Thanked: 1200
    Default Re: Impressed with China Pure Sine Wave Inverter
    Thanks, and now the most important info is ? 🤣
    Hyundai Getz 1.6 2010
    Cape Town Southern Suburbs
    Thanked: 1097
    Awesome, if you are careful you can get some very decent Chinese stuff for epic prices.
    Could you perhaps post a link to the item you ordered?
    Thanked: 474
    Currently I cannot search for the item. Search for the text on Banggood. Com
    Hillcrest, Malaysia
    Thanked: 6455
    That's the CHANGI. ?
    Must say, all it gets is excellent reviews, and build quality inside looks more than half decent.
    https://www.banggood.com/Intelligent...r_warehouse=CN
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Oppierotse
    Thanked: 260
    How many amps does it draw from the battery at 1050W?
    98 Hilux 2.8D D/C 4x4
    Thanked: 474
    Quote Originally Posted by wiel View Post
    It draws 84A. Not for regular use but it does help for load shedding for lights around 300W which will include ceiling fans on hot days. For the test I used a spiral camping hot plate and running on 2 x 102Ah batteries.
    Just to show the difference between modified sine and pure sine. Even the frequency is out of this world for such a cheap unit at 50.07Hz.
    Today I tested it right up to 1500W at which point it would cut out in 3 sec using a heat gun on high setting. Heat gun low setting is 780W.
    Aug 2017
    Durban or Centurion
    Thanked: 1229
    Looks impressive. Any suggestions for a 12v unit at half the AC output?
    Montana
    Thanked: 114
    Also happy with my Chinese inverter 3500 watts, installed 11 months ago and we don't experience any loadshedding issues.......
    Hillcrest, Malaysia
    Thanked: 6455
    Just use the same one and use it at half power. Then it will be idling along nicely.
    ZS5KAD
    3 V8's
    Aug 2017
    Durban or Centurion
    Thanked: 1229
    Now why didnít I just think of that?!
    Thanked: 474
    Just remember the 3000W model is only good for 1500W max. So one can also buy the 2000W model and use up to 1000W but I would prefer not to stress these units up to their max but rather let them idle.
    Also of interest is that by comparing it with a big modified sine the modified sine tested a 2A standing load with nothing connected but switched on and this pure sine only draws 0.7A. This is one area where more expensive units can draw as low as 0.35A standing idle.
    Thanked: 214
    Today I tested it right up to 1500W at which point it would cut out in 3 sec using a heat gun on high setting. Hest gun low setting is 780W.
    So you would say this is fine for electronics?
  15. #14
    Gaborone, Botswana
    Thanked: 1116
    ....It took was loaded on the plane on 17-01 and 3 business days later I received it via the courier used by Banggood. Interesting clearing customs took only 90min. I opted to pay the tax up front...
    What shipping method did you use?
    Kobus
  16. #15
    Plett/Paulshof
    Thanked: 903
    Quote Originally Posted by Wicd View Post
    Yes, as long as you stay within the nice sign wave spec as per pic 1. Once you get clipping as in second pic you may have an issue.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
  17. #16
    Thanked: 474
    Clipping is not shown in the 2nd picture. That refers to a modified sine wave and is the normal wave for of a modified sine. Even under load the pure sine will not look like the 2nd picture.
  18. #17
    Thanked: 474
    I used a seller on Banggood that uses Buffalo logistics that does courier in Africa. The Mail Direct option uses Buffalo. Not all sellers on Banggood use Buffalo and some will even quote other couriers and the cost can go as high as R800 for the same weight.
  19. The Following User Says Thank You to ekkekan For This Useful Post:
  20. #18
    Okahandja, Windhoek
    Thanked: 809
    How does the physical measurements of these pure sine inverters compare vs a MS inverters?.
    Johan Kriel
    LCs, Hilux and Echo Chobe
  21. #19
    Plett/Paulshof
    Thanked: 903
    According to OP the wave in second pic was at max power and it was cutting out...same pure sine wave inverter just at max power under heat gun load....or am I mistaken?
  22. #20
    Thanked: 1097
    2nd.pic was the output of a MSW inverter.
