Page 51 of 56 FirstFirst ... 26 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 LastLast
Results 1,001 to 1,020 of 1113
  1. #1001
    Thanked: 908
    Hi guys, parcel coming of lamps for muscle rehab from UK.
    Which courier must they use so as to not involve SAPO etc ?
    Read one of them add VAT and duty and parcel comes straight to house .
    You will have to choose a courtier option so that it does not go via SAPO. Refer to the cost to guide you if SAPO or courier service.
  2. #1002
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 1541
    Cost not an issue really. Which courier goes direct to my house ?
    Ford Figo 2016
  3. #1003
    Aug 2008
    Thanked: 1541
    Scotts Shipping, DHL ?
    Ford Figo 2016
  4. #1004
    Klerksdorp
    Thanked: 559
    Speak to Scott, he has a good reputation.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  5. The Following User Says Thank You to Family_Dog For This Useful Post:
  6. #1005
    Thanked: 908
    If anyone is still looking for a good socket for the current range of China inverters I found this socket and it fits with only one 5mm hole to be drilled. This is to replace the universal ?? socket fitted.
    There is a 5mm guide pin between the front and back halves. 3 screws of which one is from the front and 2 from the back. Cost is about R60 from ACDC although the web shows a price of R93. It is in the shelf where all the different plugtops are in line with the counter in the Centurion branch.
    At Clicks there is a UK 3pin plug to SA 16A 3 pin socket adaptor for a price of only 25% of what a few other shops are selling which also works very well.
  7. The Following User Says Thank You to ekkekan For This Useful Post:
  8. #1006
    Thanked: 1835
    Has anyone had a load of 900-1000W on the inverter for more than an hour?
    I use a dribuddy (tumble dryer thinghy) to dry my daughters clothes, I want to run it from the inverter, when on the inverter it varies between 940 ish to a 1000w
    Can I run it for say 90min or would the inverter go bang? I have the 12v 3000W
  9. #1007
    Jul 2015
    Vereeniging
    Thanked: 8
    Quote Originally Posted by Morne - Skip View Post
    Hi
    I have run 800w-900w for 8 hours a day for 8 days.
    But that is on a 3000w 24V inverter.
    the inverter did get hot, so I put a fan next to it to cool it down.
  10. #1008
    Hillcrest
    Thanked: 7704
    Quote Originally Posted by R1Biker View Post
    Hi
    Holy cow. What batteries are you using and how did you charge them.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
  11. #1009
    Thanked: 908
    Info on another topic placed last week.
    I have a 3KV 60A MPPT Controller/charger(12V, 24V, 36V, 48V), Changi 24V 3000W inverter, 4 x 120AH CSB Gel batteries and 6 x 150W panels.
    It can run most of my essential stuff when the power is off for days (8 days the last time) but it then cant keep the batteries charged.
  12. #1010
    Thanked: 1835
    Hi
    I'll just stick an additional fan on it. thanks.
  13. #1011
    Jan 2018
    Thornhill
    Thanked: 11
    I thought to add my experience here, as this thread helped me a lot.
    I bought the 4000w 24v from Banggood for just over R3000. I've been testing it and it only cuts off when the indicator on the inverter shows 2500w. The BMS on my battery indicates a draw of about 120amps.
    I can run a 2200w Miele vacuum cleaner and a 710w drill at the same time. It's only when I put a big load on the drill that it hits 2500w. I've got a 250mm ryobi mitre saw and I thought the startup burst would be an issue, but no, not even a alarm. The only thing that made it trip, was when I tried to weld with a 160amp inverter welder. It just makes a arc, and then cuts out.
    Thank you for all the info here. Hope this post helps someone else
  14. The Following User Says Thank You to Bakgat104 For This Useful Post:
  15. #1012
    Nov 2019
    Thanked: 20
    So a while back I posted that my inverter didn't handle the corrugated roads of KNP. I finally opened it up to assess the damage. A small power supply board broke off; it was soldered to the main board with 5 pin headers. Soldering it back on appeared to be a mission, so I just pushed the remaining pin headers backwards through the PCB and soldered the back side onto the pins sticking up. The inverter appears to be working correctly again.
    There are three boards attached to the main board with pin headers - these will all be weak, so I suggest taking some hot glue to them to reinforce them. There are also some input capacitors which aren't glued down - I also suggest gluing them to the main board.
    The board layout and the way it's put together is still going to be weak, and vibrations will kill this thing easily. If you take it on the road, put a nice thick cushion under your inverter to shield it from the bumps.
ID:	600750   Click image for larger version.
ID:	600751   Click image for larger version.
ID:	600752   Click image for larger version.
ID:	600753   Click image for larger version.
    Someone said I should use a first name, so here it is: Marc
  16. The Following 4 Users Say Thank You to Mrcloc For This Useful Post:
  17. #1013
    Feb 2017
    Thanked: 85
    My inverter is no longer outputting 220V although it is picking up the battery voltage.
    Any ideas as to what is wrong and how I can fix it? Iíve opened the inverter and I donít see anything loose or disconnected.
  18. #1014
    Nov 2019
    Thanked: 20
    I can't see anything from this perspective, but maybe just check the fuse.
  19. #1015
    Feb 2017
    Thanked: 85
    Quote Originally Posted by Mrcloc View Post
    Excuse my ignorance but where is the fuse? Iím clueless when it comes to electrics.
  20. #1016
    Nov 2019
    Thanked: 20
    No problem. You should have gotten a pair of them with the inverter, so it is possible to replace, but as far I know, the fuse is unfortunately soldered to the board. I could be mistaken, but that's what I think I read somewhere here.
    The fuse is circled in the pic I attached.
    For reference:
  21. #1017
    Thanked: 908
    Quote Originally Posted by Neville Bailey View Post
    Excuse my ignorance but where is the fuse? I’m clueless when it comes to electrics.
    There are 4fuses inside. This picture will show it clearly. On your picture they are dark red/maroon and behind the thick red wires.
    They just push into female lugs and need no tools to remove. If they were blown I doubt you would get the battery voltage to display.
  22. #1018
    Nov 2019
    Thanked: 20
    Yes, that's right - you probably wouldn't get a battery voltage reading if it was the fuses. In my earlier post of how I repaired mine, I referred to the three boards which are attached with pins to the main board. Check those - the little one is only attached with 5 pins, so it's a bit weaker, and if a pin was to break, that would be the more likely board. It can be difficult to see if a pin is broken, so if you can get a close up photo, it's easier to see. I would suggest taking the photo with bright sunlight lighting it up so that you get the clearest photo possible.
    Otherwise look for other obvious broken connections.
  23. The Following User Says Thank You to Mrcloc For This Useful Post:
  24. #1019
    Feb 2017
    Thanked: 85
    Iíve dropped off my inverter with someone who repairs inverters - should get it back later today.
  25. #1020
    Jul 2015
    Vereeniging
    Thanked: 8
    Hi
    Have a 24V 3000w Changi for sale if anyone is interested.
