Impressed with China Pure Sine Wave Inverter - Page 10
Page 10 of 38 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 35 ... LastLast
Results 181 to 200 of 759
  1. #181
    Nov 2019
    Thanked: 11
    Default Re: Impressed with China Pure Sine Wave Inverter
    I received my inverter. Looks good. Comes with battery terminals too, which is cool. It also arrived with a universal plug adapter, which is completely useless, but still, it's the thought that counts!
    Someone said I should use a first name, so here it is: Marc
  2. #182
    Rangeview Krugersdorp
    Thanked: 1082
    Quote Originally Posted by Mrcloc View Post
    Pic and price please ?
    Mitsi Outlander 2.4 Auto
  3. #183
    Thanked: 664
    Days until delivery?
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  4. #184
    I would take it that these "inverters" are approved and can not be grid tied?
    Would be keen to see your setup's.
    Paulo
    '20 Ford Ranger 3.2 4x4 Auto DC
    Previous
    '05 Terracan 2.9 CRDi
    '12 Ford Ranger 3.2 4x4 Auto DC
    '07 Discovery TDV6 S - Sold
  5. #185
    Nov 2019
    Thanked: 11
    Ordered: 30 Jan
    Received: 13 Feb
    Paid: $79.99 + insurance of $1.60 (total R1228.87 at the time)
    Customs/VAT: R128
  6. The Following 2 Users Say Thank You to Mrcloc For This Useful Post:
  7. #186
    Dec 2015
    Thanked: 26
    This sounds like account hacking stories to me!
    I had the same it's a result of our government regulations with regards imports. Only 3 imports per year allowed on your ID number. You will have to register as an importer and use your import number instead of your ID number.
    Its been discussed before on here.
    https://www.4x4community.co.za/forum...57#post4125257
  8. #187
    Thanked: 664
    Aaaah SARS wanting its pound of flesh.
    Makes sense.
    Nico Swart
    ZS6NJS
  9. #188
    Thanked: 68
    What are you guys using for the outlet plug part? Can something more sturdy by built as opposed to my cheapie travel adapter? I plan on using 4mm cable from the inverter, so ideally a plug that can accommodate this size cable.
  10. #189
    Hillcrest, Malaysia
    Thanked: 6282
    Quote Originally Posted by veedub View Post
    Why, even 1.5mm will be an overkill, and 2.5mm a serious overkill.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  11. #190
    Jul 2016
    Thanked: 476
    im using a square plug. Ex Zimbabwe...had one lying around
  12. The Following User Says Thank You to MikeBob For This Useful Post:
  13. #191
    Dec 2015
    Thanked: 26
    I bought both the 2 pin USA and the 3 pin UK. I gave it some thought and realized my multiplug would be useless with the 3 pin UK.
    The 2 pin USA I can plug it into my lawnmower and edge trimmer cables which make convenient extension leads..
  14. #192
    Thanked: 426
    I see they currently have a 4000w costing R456 with R12 shipping ?
    Whats the fine print say...
    That is a modified sine and one cannot compare it with the model I started the posting. Glad to see a number of happy chappies.
  15. The Following User Says Thank You to ekkekan For This Useful Post:
  16. #193
    Thanked: 426
    Quote Originally Posted by Tony Knipe View Post
    But you can put the UK plug on the multiplug and plug in your trimmer as you have been doing in any other plug in your home?
    I found the UK plug with the earth point a sturdy fit while the 2 pin Euro is a bit loose.
  17. The Following User Says Thank You to ekkekan For This Useful Post:
  18. #194
    Dec 2015
    Thanked: 26
    Agree with you 100%
  19. #195
    Hillcrest, Malaysia
    Thanked: 6282
    Agree with you 100%
    Of all the domestic plugs I have encountered around the world I like the UK 3 pin the best.
    When used in the guise of the socket on the inverter you have a UK 3pin, Euro/SA 2/3 pin , SA 5A and North America 3 pin and North American 2 pin compatible socket.
    ZS5KAD
    3 V8's
  20. #196
    Thanked: 415
    It seems that my inverter will be delivered by PAXI couriers to my local PEP stores..weird.
    2004 Defender 110 Td5
  21. #197
    Struisbaai
    Thanked: 768
    Quote Originally Posted by Sawdust View Post
    I also got the same yesterday.Delivering to Pep in Bredasdorp.No Pep is Struisbaai.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    1983 Suzuki SJ 410 SOA.
    2000 Prado 90 SWB.
    Bush Lapa Boskriek No 607 - Die Kriek
  22. #198
    Feb 2016
    Stellenbosch/Plett
    Thanked: 55
    Received my 4 kW (actually 2 kW) inverter this morning.
    Tested it on an old deep cycle, and I was able to (separately) power my iron (measured at 1.6 kW) and Nespresso machine (measured at between 1 kW and 1.3 kW, depending on the setting).
    The output voltage did seem to drop a bit when powering a heavy load, although I suspect that is the result of the deep cycle that has seen better days. The fan does come on when the unit is under heavy load, but it modulates its speed according to the required cooling.
    The cabling that came with the inverter does seem well made, although it did get slightly warm (not enough to be a safety concern, however). I will replace this with thicker cabling in the future.
    Switching noise is audible, however it shouldn't be bothersome if placed in another room or cabinet.
    All in all, I'm very satisfied so far. Definitely a decent product, especially for the price.
    2009 Land Rover Defender 110 Station Wagon - 12" Fox 2.0 shocks, Ashcroft Lockers Front + Rear, and a few other things
    2012 BMW R1200GS Adventure 8)
  23. #199
    Thanked: 1082
    So it's fine for a small bar fridge ? Bushpower Eco kit and 100ah battery ?
  24. #200
    Thanked: 426
    No it won't be suitable for a bar fridge as the bar fridge has a normal AC motor and you do need pure sine wave. Further depending on the hours from sunset that the bar fridge runs it would flatten a 100Ah battery before the PV has a suitable output. The bar fridge would draw about 8 amps and the period is about 14 hours of which the motor might run 10 hours as a guess. Some of the newer fridges have smaller compressors but they tend to run most of the time. If however it is an older Samsung or LG they tend to run for short periods and use less power than some cheaper brands. This assumption is based on the average bar fridge and not on the A+ low energy models.
  25. The Following User Says Thank You to ekkekan For This Useful Post:
