80 GX Suspension Questions Please
Results 1 to 14 of 14
    Bethlehem
    Thanked: 4355
    Default 80 GX Suspension Questions Please
    Hi Guys
    Apologies for yet another Thread, almost similar to my "Spacers" one.
    1)............I have a 97 80 GX Diesel that looks "afdraande", I may be wrong, but it just stands a bit nose down for me.
    2).....The coils may have sagged a bit?
    3)......I have newish coils from a 76 v8, will they fit (obviously only the fronts)?
    4).........I'm busy having the shocks tested, if not 100% I'll put new Monroe Magnums, so that's fine.
    .........Or do I just have the coils tested, and if necessary replace with fresher 80/105 Series original coils??
    I'm not overly keen on an aftermarket suspension like OME or Ironman.........I'm just not.
    The 80 drives great, no issues. I will however want to replace the shocks if even remotely necessary, and definitely also the steering damper - car feels "jittery" (very little but still) over a pothole.
    THANKS
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
    Bethlehem
    Thanked: 4355
    Default Re: 80 GX Suspension Questions Please
    Just got the 80 back from the shock shop.
    Shocks and rubbers etc etc are all 100%.
    Silly question - how does one test a coil(s), if it has sagged??
    My pel by die shock shop se ek verbeel myself, die 80 le nie afrdaande nie.
    Krugersdorp
    Thanked: 373
    Post 'n foto dat ons kan sien?
    Bush Lapa Miskruier 586
    Bethlehem
    Thanked: 4355
    Bethlehem
    Thanked: 4355
    Hiers nog enetjie
    Bethlehem
    Thanked: 4355
    Kar ry lekker, soos 'n 80 moet, geen ge swayery of bumpety bumpetness nie. Steering damper is dalk so bietjie klaar, soos ek se hy voel half jittery oor slaggate.
    Bethlehem
    Thanked: 4355
    Mind you....hoe meer ek hom nou kyk hoe straighter begin hy vir my ook lyk
    Eks maar net vol akkas, besig om al weer te over analyse.
    My shock shop pel was dalk toe reg.
    Dink ek
    Thanked: 219
    Petri staan hulle nie maar effens so nie? Myne het ook so gestaan met sy OME suspensie. Dan is hulle meer gelyk wanneer hulle gelaai is.
    Ek weet jy hou nie van aftermarket nie, maar jy moet dalk na Tough Dog se Return to Centre damper kyk. Ons het al so paar verkoop, maar almal was baie happy met die resultaat.
    Bethlehem
    Thanked: 4355
    Quote Originally Posted by Wicd View Post
    Wicus, dis die steering damper??
    Prys??
    Kan jy hom stuu...... as alles reg klink sal ek daarna kyk baie dankie!!
    Krugersdorp
    Thanked: 373
    Dis darem 'n mooi 80 series daai...
    Aug 2018
    Thanked: 110
    Petri
    As jy die kas Jack an box sigarette uit die boot haal sal hy dalk baie meer level staan, of jy moet net voor in gaan sit
    As jy wheel arch tot rim meet, hoe lyk die afmetings? as dit jou nog regtig pla.
    Ek dink daai 80 lyk mooi, en level.
    Thanked: 219
    Petri dit is bietjie van 'n upgrade op n steering damper. dit is 'n Damper met n coil spring by om die stuur terug te bring na centre as jy gedraai het. Hier is 'n video oor die produk: https://www.youtube.com/watch?v=s8lxnctB83g
    Die 80 en 105 gebruik dieselfde part en ek het. EK kan vir jou stuur as jy belangstel.
    Bethlehem
    Thanked: 4355
    Wicus dankie - Prys ens ens??
    Dis 'n 97 80 GX Diesel.
    Sommer net - het jy vir 98 Patrol 4500 GL ook so iets??
    Aug 2018
    Thanked: 110
    stel ook belang in prys asb?
