What solar MPPT to charge a Li-ion battery?
Results 1 to 20 of 20
    Thanked: 1033
    Default What solar MPPT to charge a Li-ion battery?
    Most solar inverters with MPPT's seem designed to charge lead acid/gel type batteries, what MPPT has charge profiles for a Li-ion battery?
    I'm looking for a solar inverter with MPPT that can do Li-ion batteries on 24v and one for 48v.
    Feb 2016
    Thanked: 607
    Default Re: What solar MPPT to charge a Li-ion battery?
    Victron Energy tick all those boxes
    Thanked: 350
    The Victron 100/20-48 does only 48V. From the 150/35 and up can do 12/24/36 and 48V
    Thanked: 1033
    And those different voltage charge option's all have options for Li-ion charge curves?
    Feb 2016
    Thanked: 607
    Iíve not seen a Victron charger that doesnít have a Li-ion curve, Iím 99.9% sure they all have
    I see you are from George? Give Thys Fourie a call (0827727857 or 0731214466) heís the owner of Omnisolar in George. They have a huge stock range and really good prices.
    Mar 2011
    Walker Bay
    Thanked: 1033
    What are you using these batteries for?
    What are they connected to - solar for the house?
    Thanked: 1033
    Quote Originally Posted by MrTolbos View Post
    Thanks.
    Connected to solar to use as a small off grid battery pack, a bit like a DIY Flexopower Lithium444 power pack.
    Thanked: 1033
    Reading up on the Victron website they seem to only support recognised Li-ion battery packs, I'll be making a custom pack out of 18650 cells and would like a mppt where I can customise the charge cutoff etc.
    Thanked: 350
    You will then find those custom settings as part of the Victron MPPT controllers.
    Feel free to ask any questions on the Victron forum. They do offer great support in a short turn around time.
    Friemersheim, Southern Cape
    Thanked: 2204
    You can set User defined Battery Settings on the Victron Smart Controllers
    Feb 2016
    Thanked: 607
    You can change those setpoints/profiles to exactly what you want via the victron app on your smartphone
    Feb 2017
    You can buy a cheap BMS on Amazon to take care of charging , discharging and balancing of your LiFePO4 battery packs. Should then work with most standard battery chargers.
    Thanked: 1033
    Quote Originally Posted by BL699 View Post
    That sounds interesting, it would probably have some built-in loss though so being able to natively charge the pack via the mppt would be the optimal method.
    Do you perhaps have a link to one of these BMS on Amazon?
    It's a bit of a nightmare sifting through the endless options they sell.
    Oct 2008
    Thanked: 265
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
    Earth
    Thanked: 1931
    Quote Originally Posted by Charlie100 View Post
    Not really a fan of that guys installation
    The wood fittings he uses really puts me off his work wood is not generally good idea when working with electrical items
    2007 Subaru Forester 2.5XT
    (most people don't agree)
    Thanked: 58
    Yes, if you are using a VenusGX/CCGX and you want the Li-ion battery BMS to integrate with a VenusGX/CCGX, then you must use one on the list.
    Promising times ahead as more BMS'es will be listed in the future on that list.
    As some has already said, all Victron inverters and MPPT's are 100% programmable to charge any type of battery technology out there today.
    I'm looking at a 2nd Life battery bank that is not on the Victron list. All I need to ensure is:
    1) I have a SOC that the VenusGX can use.
    2) The bank is big enough that the BMS will not switch off prematurely if the inverter is powering the load during a Eskom failure ito the peak amps drawn.
    Meeting the above two points, one can add any bank to a Victron kit.
    Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
    Aug 2019
    PTA
    My Victron SmartSolar 75/15 worked fine when tested on lithium, also have a Benton BX-1M for charging both lithium and normal battery.
    Aug 2017
    Thanked: 887
    How do you plan on balancing the cells if you are not running a BMS? Most BMS units draw extremely low currents
    Thanked: 1033
    Manual balancing every few weeks and not allowing a deep DOD which is when issues with unbalanced cells start rearing their heads.
    That's the theory but from what I have read it works pretty well, though not a set and forget type setup.
    Dec 2019
    If you looking for a BMS, you can check here. https://lithiumbatteriessa.co.za/collections/bms
    I just finish building my 16s 120amp setup with Ant Smart BMS that I imported fro my setup. It came with a screen and can connect to my phone. I'm running a Microcare LCD MPPT's on my setup. The Microcare Units is 12v/24v/36/48v units and you can order them from Microcare now with the new Li-ion settings on them. I still need to send my one MPPT unit to them for this new software and then my other unit after that.
    A did a bit of fine tuning on the MPPT to check to find the rite settings and so far things looks good.
