Disco 3 - unbraked towing capacity
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 42
    Sep 2014
    Default Disco 3 - unbraked towing capacity
    I need to know what the unbraked towing capacity of a Discovery3 TDV6 is specified to be. I intend to tow a Landcruiser to workshops with the Disco 3.
    I have a Landcruiser Game Viewer that is not licenced and needs to get to an autoelectrician and reputable Toyota workshop (the mechanics can't fix rear leaf springs or find the electrical speedo error). As a result, it will need to be towed to and from civilisation.
    What would be best for towing:
    1. Piggy Back trailer
    2. Load up trailer (2 tons)
    The Game Viewer drives fine - it just is not licenced to go on a public road.
    Thanks for suggestions in advance..............
    Langs die rivier, op n berg
    Thanked: 2490
    Default Re: Disco 3 - unbraked towing capacity
    Unbraked trailer: 750kg
    Unbraked vehicle on A-frame: no limits
    Thanked: 2490
    But A-framed vehicle must be registered.
    Best option. Double axle braked car trailer. Renting is about R350 per day
    Jan 2017
    Rustenburg
    Thanked: 916
    Quote Originally Posted by Photorer View Post
    definately not a piggy back on such a heavy vehicle. proper Car trailer is the safe way to do this, and they should all be braked.
    disco 3 will be more than capable to tow a cruiser on a trailer.
    legally, you canít tow anything unbraked if it weighs more than 750kg.
    Sep 2014
    Thanks for the quick replies..... awesome!
    It seems that a double axle vehicle trailer would be the answer.
    Anyone have experience with doing this? Since I've not done that kind of towing before, I would appreciate some advice, especially on:
    1. Towing the empty trailer to go pick up the vehicle
    2. Loading the Cruiser onto the trailer
    3. Tying it down onto the trailer
    4. Driving with the Cruiser on the trailer (suggested speeds etc, and how to handle quick stops, or stop/start traffic)
    5. Offloading the vehicle again.
    The other option would be to find a suitable towing operator to come collect for me!
    Thanks so much!
    Thanked: 2490
    10% of towed vechile weight on towball, or you wont go over 110km/h without swaying.
    Ratchet strap over every wheel of towed vehicle straight down to trailer
    If towed car is running, just drive it onto trailer with ramps. Same for unloading.
    Make sure you have correct driving license for towing trailer heavier than 750kg
    Thanked: 2490
    Straps over the wheel
    Or strap through wheels
    Sep 2014
    Do you drive onto the trailer with it attached to the Disco, or on the stand? I just don't want to end up with a trailer which breaks in two, or my Disco doing a headstand!
    Thanked: 816
    It will most likely be worth your while to get hold of HenriS here on the forum to quote on doing the move for you. He owns SADC Assist and has the correct trailer and kit to do the move safely.
    I have towed car and bike trailers around the country for many years while racing. If you have haven't towed a big heavy rig like this before it is very easy to get it wrong.
    The humble person makes room for progress; the arrogant person believes theyíre already there.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
    Thanked: 2490
    Attached to disco.
    Might help to support back of trailer.
    Thanked: 2490
    Might be better, easier, safer and cheaper
    Sep 2014
    Thanks - this is quite daunting....... so I will have a look at this as a quote. Many thanks!
    Jan 2017
    Rustenburg
    Thanked: 916
    Attached to the disco please. And yes. Support the back of the trailer might help.
    make sure the trailer you rent will allow you to tie over the wheels. Some of the rental trailers donít have sufficient tie down points.
    makw sure you use decent ratchet straps, not Midas cheapies.
    as mentioned by others, maybe better to get someone to assist you. Could end up getting expensive if something goes wrong
    Nigel
    Thanked: 2105
    If you are going to rent a trailer to haul something really heavy, it is always a toss up.
    Condition of the bearings.
    Condition of the brakrs.
    Integrity of the trailer itself.
    Load rating of the trailer.
    Also make sure, that is something does go wrong, either the law or your insurance don't want your hide.
    Uniglide
    +27 zero eight 2 four 95 9252
    Thanked: 2490
    Yip. En as jy huur, ken jy nie swaar sleep.
    Laat henri dit doen en slaap rustig
    Thanked: 53
    Over is fine till a wheel decides to go flat
    '99 Cherokee (XJ) 4.0 @ 143000km
    "Frankenstein" 5" lift | Nomad Bumpers | Safari Snorkel | Gorman rocksliders | Khumo 31x10.5x15 | Jerry can holders | 29Mhz Radio | Custom roof rack | Dual Battery | ARB onboard compressor
    Thanked: 53
    Get a temp license from the traffic department and drive it there
    https://www.gov.za/services/roadwort...vehicle-permit
    3 day special permit
    Thanked: 2490
    Quote Originally Posted by sclater View Post
    Nog nooit pap geraak, ek het al wel straps laat afglip in ry. Maar dan is daar nog 3 ander. Stop elke 200km, check straps. Tegnies hoef jy net die 2 voorste wiele te strap, so risiko van/en as wiel wat pap raak, is minimaal.
    Het al n wa van oad af gedruk en ge-jack knife deur n grensdraad langs pad teen 120, en die bakkie op wa het nie n cm beweeg. Strap oor wiel is by verre die beste manier.
    As jy dubbeld wil seker maak, sit nig n strap deur elke wiel na hoeke van wa.
    Thanked: 53
    Strap deur wiel my keuse of anders op suspensie arm aan wiel se kant
    Thanked: 2490
    Myne bly oor die wiel.
    Maar dit is ek, vir my. En ek doen dit nie so baie. Seker maar so 15 000 km per jaar met kar op trailer. Die ouens wat dit meer gereeld doen, het seker hul eie manier van doen. Maar van al die maniere, werk dit beste vir my. Darem nog nie een verloor so vÍr nie.
