Bog-out
Results 1 to 20 of 20
Thread: Bog-out
    Jun 2013
    Thanked: 98
    Default Bog-out
    This looks like some handy kit to have as part of your recovery gear......just hope you always have an anchor point available.
    https://cloud.tapatalk.com/s/5e240a50...118-WA0015.mp4
    2010 Defender 110 Puma HCPU (Bostrok)
    2015 Mercedes Benz GLA (Swambo's Glam)
    Thanked: 273
    Default Re: Bog-out
    This seems to be a great idea. Nobody making it in SA yet?
    [SIGPIC]MikevR Be determined to live the unlived life within you.
    Feb 2016
    Thanked: 607
    Default Re: Bog-out
    I see they sell for $199USD on amazon, almost R3000....
    Aug 2017
    Thanked: 888
    Default Re: Bog-out
    ... think Iíll try and make my own
    Apr 2018
    Fraserburg
    Thanked: 603
    Default Re: Bog-out
    The old Series Landys had wheel hub winches which bolt straight onto the steel wheel rims using the existing standard wheel nuts. I have a set for my Series 2A
    Jun 2013
    Thanked: 98
    Default Re: Bog-out
    Safety belt webbing might be an option....
    Sasolburg
    Thanked: 473
    Default Re: Bog-out
    Quote Originally Posted by Bostrok1 View Post
    Cargo straps, the ones used to tie down stuff on trucks.
    Those seat belts are not very strong, I have see one used in a emergency recovery. Snapped like nothing
    If Force is not the solution, not enough of it was applied....
    Oct 2017
    Rustenburg
    Thanked: 1291
    Default Re: Bog-out
    The old Series Landys had wheel hub winches which bolt straight onto the steel wheel rims using the existing standard wheel nuts. I have a set for my Series 2AClick image for larger version.
    Note, that these are placed on the outside of the wheel... The oldies were thinking about practicality when they thought about this. You can even steer into the belt.. sothat it does not pull off the pulley.
    Now imagine the product mention by the OP, with the vehicle slipping in muddy conditions, or steep climbs, as they do(Anyone who has driven off road knows this), and that thing wraps itself around the axle on the inside of the wheel....
    Man... You are going to have some fun trying to get it out!
    That thing is probably going to sell like hotcakes,...... to the keyboard warriors...
    _______________________________________Dum vivimus, vivamus!With a mild case of "Camping Personality Disorder" or CPD I drive a five cylinder bakkie and tow an army inspired van.
    Nov 2016
    Thanked: 83
    Default Re: Bog-out
    I have a friend in Aussie that has them and uses them a lot. He is bringing me one in mid Feb. Looking forward to trying it !!!
    Apr 2018
    Fraserburg
    Thanked: 603
    Default Re: Bog-out
    And when that happens, the replacement of CV rubber boots and brake hoses. Lots of fun.
    More pics of the Factory Standard Land Rover Wheel hub winches that bolt onto the rim using the standard wheel nuts.
    Apr 2018
    Fraserburg
    Thanked: 603
    Default Re: Bog-out
    Another pic
    Elarduspark
    Thanked: 207
    Default Re: Bog-out
    I watched the video as someone sent it to me on whatsapp. All I will say is that it might work if you use it on both wheels not just one side. Things always look simple on the videos made by the creators of these gimmicks.
    I will get a chair, a cold one and some shade and watch whoever used the contraption trying to get it loose. It will not be as easy as the video would want you to believe.
    Henk
    So understand
    Don't waste your time always searching for those wasted years
    Face up, make your stand
    And realize you're living in the golden years
    Apr 2018
    Fraserburg
    Thanked: 603
    Default Re: Bog-out
    Quote Originally Posted by Henkus View Post
    I was wondering how you remove it once it's wound onto the tyre.....
    Vaal triangle
    Default Re: Bog-out
    drive back into the mud?
    Jun 2013
    Thanked: 98
    Default Re: Bog-out
    I would untie the straps from the anchor point, secure the loose ends to the rim and drive like that to a place where you can reverse to remove. If too tight tie to a new anchor point and reverse out of the straps.
    Nov 2012
    Thanked: 143
    Default Re: Bog-out
    Daardie kontrepsie is net vir moeilkheid met n K soek.
    A journey is a person in itself; no two are alike. And all plans, safeguards, policing, and coercion are fruitless. We find that after years of struggle that we do not take a trip; a trip takes us.
    John Steinbeck
    May 2016
    Thanked: 2799
    Default Re: Bog-out
    When in the army, our Land Rovers were fitted with these, and steel cables.
    We were trained to use them (always as a pair).
    When used, and out of the obstacle, the wheels are removed, the cable taken off (and discarded )and the wheels replaced.
    The cables were "use-me-once" items.
    2006 VW Touareg V10 TDi
    Cape Town, Plumstead/The Sea/Franskraal
    Thanked: 459
    Default Re: Bog-out
    5 Things.
    1. Great device. Have seen this before but made with seatbelt webbing, The main pull is on the two outer straight belts, the cross brace is to keep it in place, impossible to slip off the wheel. Well the one I saw was custom made to the wheel.
    If the vehicle is very stuck, you do run the risk of damage. You can easily burn your clutch, so be careful when using it.
    2. I do not understand how this would work, or the Land Rove one, if you don't use it in pairs on an open diff. If you have a diff lock, then it's logical, open diff, you ain't going to even get it to spool.
    3. It is impossible to wind it round an axle, even a IFS setup, is guarded by the hub and suspension. If you know what it looks like behind the wheel, you will understand. Rear diff same thing.
    4. Getting it off is no problem, once on hard surface you drive the opposite way that you went to put it on. There is nothing holding it so just rolls off, even if you use 3 as we did, started to get a bit full but you just drive "off" it.
    5. Make your own one, custom made for your car. 265 width, add 60mm, plus 4x the width of the webbing and double sow it to have the side braces go round the two side "pulling straps". The extra length on the middle braces is to force it to go round the tyre and form a "basket" that does the pulling, Space the braces 250mm apart for best contact on the wheel.
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
    Tzaneen
    Thanked: 231
    Default Re: Bog-out
    The anchor will have to be straight behind or -infront.At a angle I think it can become complicated??
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
    Default Re: Bog-out
    SECURETECH sold this product for many years but was discontinued due to lack of demand
    Nissan Patrol (2014)
    Suzuki Grand Vitara (2011)
    SECURETECH 4x4 Recovery Kit Bag
    SECURETECH Snow Chains
