Andrew St P White, Jurgens en Xplorer
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 54
    Nov 2011
    RSA
    Default Andrew St P White, Jurgens en Xplorer
    Ek het 'n stuk van die man se video van bg op youtube gekyk waarin hy Jurgens aanvat en maan oor die Xplorer se aste - en oor die algemeen uitvaar teenoor sleep en die Xplorer spesifiek.
    Die video is 2019 gedateer, hy lyk ouer en grys dus neem ek aan dis 'n taamlike vars ding.
    Ek het nie tyd vir die krel nie maar die ding oor die aste pla my - het ek rede tot kommer met my 2007 model se as?
    Was dit die vroer modelle want die nuutstes het tog nog steeds met Rubax aste uitgekom?
    Is skokbrekers 'n uitweg of moet ek my as vervang?
    2014 LC200
    2019 LC79 V6 bakkie
    2018 Merc E63S
    SL65 AMG
    2016 silwer Pajero swb
    3 x Mazda Bt50's
    2 x Nissan 2.5's
    Cessna 210T ZS-..K
    Moenie als glo wat jy lees of hoor nie!!
    Old enough to share experiences, young enough to learn.
    Nigel
    Thanked: 2289
    Default Re: Andrew St P White, Jurgens en Xplorer
    Sit coilover shocks in.
    Uniglide
    +27 zero eight 2 four 95 9252
    Ruimsig
    Thanked: 10437
    He is relating the story in 2019 but referring to the events of 1999 to 2001. He refers to it in his ''The complete guide to Four Wheel Drive in Southern Africa'' 2000/2001 edition.
    This is the rubber torsion axel. Is this fitted to yours?
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Outeniquastrand
    Thanked: 14
    Verduidelik assblief.
    2018 VW Amarok V6 4Motion A/T
    2019 VW Tiguan 2.0 TDI Highline
    2015 Jurgens Xplorer
    Nov 2011
    RSA
    Rubax torsion axle.
    Kan nie skokbrekers met so 'n as insit nie.
    2014 LC200
    2019 LC79 V6 bakkie
    2018 Merc E63S
    SL65 AMG
    3 x Mazda Bt50's
    2 x Nissan 2.5's
    Cessna 210T ZS-..K
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    May 2017
    Thanked: 50
    I got an 2017 Explorer with the rubber axle.
    Over the last three years we traveled extensively in Southern Africa on really bad roads with heavily laden Explorer. Deep sand, mud, rocky terrain. Extreme conditions some times.
    No issues with axle at all. The thing tows easily and will go where your car goes.
    Just manage your tyre pressure and use common sense.
    Personally, I disagree with Mr. Andrew St P White.
    The Explorer is a beast.
    Ellisras
    Thanked: 559
    I watched one of his episodes on TV where he tried to explain batteries.
    Never again will I give any ear to what he purports
    Bethlehem
    Thanked: 4359
    Ja nee kyk...
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
    Oct 2006
    Pretoria (Rietvalleirand)
    Thanked: 80
    Quote Originally Posted by robert bosch View Post
    Moenie jou te veel steur aan die ou nie! Hy is maar die Jeremy Clarkson van die off-road wereld...................hy weet dit net nie!
    Ons het vir 14 jaar 2x Xplorers oral oor gesleep, en nee......nie Warmbad toe nie! Nooit 'n probleem gehad met die Rubax aste nie.
    Moenie oorlaai nie, BLAAS DIE BANDE AF en pas spoed aan waar nodig en jy sal goeie diens kry.
    Los maar die skokbrekers ook. Die styfheid van die suspensie moet behoorlik ontwerp word en mens kan nie "willy nilly" net skokbrekers bysit nie.
    Het dit op die harde manier geleer deur te veel internet te lees, en toe skokbrekers op my eerste wa laat sit by 'n plek. 20km op die eerste sinkplatpad het albei se boute afgebreek! Afgehaal en weggegooi!
    Johan
    Pajero Gen 4 GLX 30 Year Heritage Edition - Grondpad
    VW Tiguan 2.0TDi - Teerpad
    Bushlapa Boabab 4.2 in tow
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by LowRange View Post
    Johan
    (Like..)
    Jun 2017
    Kuilsriver
    Thanked: 116
    Soos vroer genoem deur SAND, lees gerus die ander 'thread'. Jou grootste oorweging moet wees die geskiktheid van jou toerusting vir die spesifieke taak.
    Daar is absoluut niks verkeerd met die rubber suspensie aste nie mits hulle gebruik word waarvoor hulle ontwerp is en d.i. redelik goeie teerpaaie plus 'n stukkie 'gravel' tot by jou kampeer plek. Langafstand grondpaaie is 'n doodsvonnis vir hierdie aste
    En die rede is die sinkplaat van die grondpad. Bv. as die sinkplaat riwwe omtrent 200mm uitmekaar is en jy reis teen 80km/hr dan sal jy binne EEN UUR 80000000mm vr gery het en jy suspensie sal (80000000/200=) 400000 (vierhonderd duisend) keer op en af beweeg het.
    Die energie (hitte) opbou in die rubber is geweldig hoog en kan lei tot katastrofiese resultate. Die foto's wat hier aangeheg is behoort als duidelik te maak...1/ asbeweging 2/ rubber wat oorverhit is en 3/ die moontlike resultaat ('n ander 4x4 comm. thread). Moet nie jou geld mors deur te probeer springe of skokbrekers aan 'n rubber-as te hang nie.
Name:	Suspension Movement.jpg
ID:	555051   Click image for larger version.
Name:	Heat degradation.jpg
ID:	555052   Click image for larger version.
Name:	Rubber Axle & Corrugated road.jpg
    Nov 2011
    RSA
    Bullterrier, ek moet met die wa Botswana toe Augustus. Baie van daardie paaie is sinkplaat en baie is sand met ho middelmannetjes.
    Wil jy nou vir my s die wa se suspensie gaan ingee en ek gaan moeilikheid optel?
    Waarvoor is die ding dan ontwerp en gebou? Sekerlik nie net vir teerpaaie en 'n bietjie grondpad/sinkplaat nie?
    Ek lees dan gereeld van mense wat lng grondpaaie in Suidwes sonder probleme gery het?
    Ek was Desember in Botswana met 'n Bundu sleepwa en 'n 200 Cruiser.
    Die Cruiser het probleme gegee, die Bundu nie.
    Die sleepwa het wel orals begin kraak en breek waar die spaarwiel en daktent vas kom maar sy bladvere - sonder skokbrekers - het goed gewerk.
    Ek het n die trip die Cruiser ingeruil op 'n swb diesel Pajero en die Xplorer aangeskaf.
    Hoop van harte ek het nie met beide 'n fout gemaak nie
    Kan ek die rubber as met 'n bladveer en skobreker eenheid vervang?
    2014 LC200
    2019 LC79 V6 bakkie
    2018 Merc E63S
    SL65 AMG
    3 x Mazda Bt50's
    2 x Nissan 2.5's
    Cessna 210T ZS-..K
    Lanseria
    Thanked: 30
    I took the photo of that Explorer just outside the entrance to Planet Boabab. The caravan belonged to Loftus Caravan. Rental. The spindle coming from the hub broke off and the wheel came off. Loftus Viljoen drove all the way from Pretoria with a new Rubax axle which he fitted the next day and all was sorted. The same thing happened to me with me in 1998 in Moremi with my 1996 Brakhah trailer. I had to leave my trailer in the bush, drove to Pretoria, picked up a new Burquip axle from Brakhah and drove back to Moremi. Luckily my trailer was still there and I managed fit the axle to get it back home. Changed the axle then to a solid axle, with leaf springs and shock absorbers, and my niece and her husband are still using that trailer for trips into Southern Africa.
    After towing trailers and caravans all over the place I came to the conclusion that the main culprit is speed. Slow down and all will be well when you tow.
    Ruimsig
    Thanked: 10437
    In principle, there is nothing wrong with torsion type suspension and it is used to good effect in many vehicles. I have had 2, the Renault 9 and now the Hummer H3. On the rear with the Renault and the front with the H3.
    However, these type of systems rely on the torsion resistance of the metal of the torsion bars themselves. My understanding is that the rubber component in the type of system used in the OR caravan, makes use of the rubber component to provide torsion.
    Like air suspension on my Range Rovers, the spring is replaced with a bag made of rubber. I am not convinced, rubber as a replacement for metal is a great idea having had a number of inconvenient failures of these components.
    In terms of failures, the possibility of any system failing will always be there, the probability though, is something different. Some systems will have a higher probability than others. I dont have the available stats on failure rates for any of the different types of system so my opinion would be that this type of system would have a higher probability of failing than a conventional system.
    A quick search on Google yields sufficient reading regarding the failures of this type of axel.
    Regardless of what one thinks of ASPW, the man has earned his stripes and he poses his opinion strongly. However, its at the users risk when summarily disregarding what he or other experienced people have to say.
    For peace of mind, I would suggest that you seek advice on options for your make of caravan/trailer from people in the business and then if possible, convert/upgrade accordingly.
    Hummer H3 V8
    W.A.P Objectivist
    Jun 2017
    Kuilsriver
    Thanked: 116
    Bladvere is meer geskik vir grondpaaie as die rubber-suspensie aste MAAR as daar geen alternatief is nie moet jy net meer bewustelik bestuur.
    • Oor lang afstande van sinkplaat ...ry stadiger sodat jy minder beweging het in die suspensie. Want as jy vinnig ry spring die wiele verder op en af wanneer dit stamp teen die riwwe ens.
    • Stop 'n bietjie meer m.a.w. ry korter afstande sodat die as so effens kan afkoel wanneer jy stil staan.
    • Verlaag die wa se banddruk sodat die ' tyre walls' bietjie meer kan 'flex' wanneer jy oor riwwe ry en sodoende sal die as beweging afstand korter wees. Met minder 'torsion van die rubber in die as sal die hitte-opbou ook minder wees.
    Met hierdie raad behoort jy OK te wees.
    En laastens: Ja jy kan jou as vervang met soliede as en bladvere maar jy moet in ag neem dat jou wa gaan hor staan en sommige van die kontrepsies wat aan die buitekant van jou wa gemonteer is, sal nou ook 'n bietjie hor van die grond wees.
    Groete.
    May 2017
    Thanked: 50
    Robert,
    Ek het afgelope jare met twee Explorers baie kms slegte en sinkplaat grondpad gery. Nog nooit probleme met aste gehad nie. Blaas net jou bande af en ry ordentlik. (Hou net jou "wheel nuts" dop want die goed raak soms los.
    Ek het al ouens met ander boskaravane gehelp wat ander ander tipe aste met skokbrekers het, wat gebreek het.
    My opinie: Gaan geniet jou trip!
    Thanked: 2308
    Quote Originally Posted by Laevelder View Post
    Hy is omtrent die enigste ou wat homself glo.
    Thanked: 333
    Agree.
    Apr 2012
    Thanked: 8
    Moenie jou te veel steur aan die ou nie! Hy is maar die Jeremy Clarkson van die off-road wereld...................hy weet dit net nie!Ons het vir 14 jaar 2x Xplorers oral oor gesleep, en nee......nie Warmbad toe nie! Nooit 'n probleem gehad met die Rubax aste nie.Moenie oorlaai nie, BLAAS DIE BANDE AF en pas spoed aan waar nodig en jy sal goeie diens kry.Los maar die skokbrekers ook. Die styfheid van die suspensie moet behoorlik ontwerp word en mens kan nie "willy nilly" net skokbrekers bysit nie.Het dit op die harde manier geleer deur te veel internet te lees, en toe skokbrekers op my eerste wa laat sit by 'n plek. 20km op die eerste sinkplatpad het albei se boute afgebreek! Afgehaal en weggegooi!Johan
    Lowrange..dan ry jy nog n Pajero ook! Het jy gesien wat hy te se het daaroor?
    _______________________
    Heinz Reinstorf
    Mitsubishi Pajero 3.2 Did GLS
    VW Tiguan Tdi
    Bushlapa Miskruier No. 68
