Suspension Toyota Hilux - lift up rear suspension
Results 1 to 9 of 9
    May 2013
    Default Toyota Hilux - lift up rear suspension
    I bought a new Toyota Hilux 2.8GD 4x4 DC. I installed a RSI canopy with built in kitchen, 50litre water tank and drawer unit, I noticed that the rear suspension sag a bit specially when I am towing. Someone recommend that I install a LXH TWIN BLADE STABILISER supplied by www.loadhog.co.za. Does someone have experience of this system or is there any other system that you can recommend that will give extra lift to the rear without compromised on the driving quality and stability of the vehicle
    Stefan
    2003 Toyota Prado GX 3,0D manual, (bought new - now 211'000km and still going strong)
    Luna duel battery system
    Outback roof rack
    Gabriel Safari HDP socks
    Bridgestone Dueler D694 A/T
    Jan 2014
    Shelley Point
    Thanked: 33
    Default Re: Toyota Hilux - lift up rear suspension
    I have the same setup and I installed a Air assistant system, working well , put 3 bar into it and then the Hilux is back to 390mm from ground to tow-bar bracket.
    I ordered from Amadaxtreme and installed myself.
    Thanked: 120
    I had the same problem and had an extra blade added to the existing Old Man Emu pack.
    ORRA Callsign: X130
    Aug 2014
    Thanked: 138
    Have a look at this. Had it installed on my Vigo (With RSI Canopy filled with camping gear inside and on top, Smart Kitchen, Drawer system, filled 60l water tank and third aux battery) and she sits perfect. Whats nice about the Loadhog is that it has little inpact on your suspension when not under weight so no bumpier ride as with extra blade. Air helpers were to expensive and the risk of punctures also counted against them for me.
    https://www.loadhog.co.za/
    2014 Toyota Hilux DC 4x4 - Legend 45
    2010 Jeep Wrangler Unlimited - Mountain Edition (Sold...)
    Oct 2008
    Grabouw
    Thanked: 170
    Quote Originally Posted by JeeperCreepers View Post
    What is the price for the Roadhog system Jeeper?
    Aug 2014
    Thanked: 138
    Quote Originally Posted by BarnieH View Post
    Barnie, IIRC it was R2800 installed
    Thanked: 179
    Also have the amadaextreme air bags and they have taken the fortuner drag asss when towing to level and towing like a dream
    Fuel consumption this December over 3500km did not change from normal town driving. Towing full trailer and 4 people
    Last year June we did not have the air helpers and die backside dragged and car worked hard and used lots more fuel
    Riku
    2011 Echo4 with Blinkgat Nose cone and
    Oct 2008
    Grabouw
    Thanked: 170
    Thanks.
    I have looked at air helpers, but there is no straight fit for the XJ.
    Thought of shackle relocation bracket also, but this looks good especially if you say that it does not
    affect road handling when not under load.
    Aug 2014
    Thanked: 138
    Quote Originally Posted by SPP View Post
    Tjrrr, I should learn to read.... Loadhog is good. See post 4
