Resistor for LED light upgrade?
Results 1 to 12 of 12
    Feb 2007
    melkbosstrand
    Thanked: 137
    Default Resistor for LED light upgrade?
    Good evening all,
    I have installed LED replacement bulbs (H4) in my Fj and im very happy with the outcome, but since installing them my auxiliary spot lights have stopped working...
    I'm no expert, but i'm thinking that the relay is not being triggered because of the lack of resistance from the LED.
    If i put my halogen bulbs back, everything works a charm.
    What type of resistor will I need and where do I install it?
    The relay is triggered by the positive wire from the brights, can I add a resistor to that line?
    Thanks in advance.
    Jono
    Current: Toyota FJ Sport Cruiser
    Previous: VW Amarok ULTIMATE 4motion (auto)
    Previous: Amarok 4motion (MT) with a few goodies
    Previous: Isuzu KB300 Dteq 4x4 not that many goodies
    Prevous: Isuzu KB360 4x4 with a few goodies
    Nigel
    Thanked: 2282
    Default Re: Resistor for LED light upgrade?
    I added one in parallel and all is happy.
    Uniglide
    +27 zero eight 2 four 95 9252
    Feb 2007
    melkbosstrand
    Thanked: 137
    So do I wire it on the feed from the bright tie in?
    What type of resistor do I need and where would one purchase them? Is there a specific rating? Wattage/Voltage/Resistance?
    Nigel
    Thanked: 2282
    Quote Originally Posted by jonoB View Post
    Will take a pic and post it.
    Uniglide
    Feb 2007
    melkbosstrand
    Thanked: 137
    Thanks a million!
    Feb 2007
    melkbosstrand
    Thanked: 137
    So where should I wire this? apologies for all the questions, but I would like to get this right.
    If I wire it between the brights tie in and the relay will it work?
    Nigel
    Thanked: 2282
    I wired mine over the bright. That is when the blue light on the dash gets confused. Also wouldn't kick in the relay for the spots. Now it does. (Been there for about a year now.)
    Uniglide
    Feb 2007
    melkbosstrand
    Thanked: 137
    I have found these on the FJ cruiser club chat group.
    Going to collect from Assegai Africa. R350 for the set! Appreciate the help!
    Jul 2013
    where are they based? I am in the same boat and trying to locate a set of resistors
    Thanked: 515
    Quote Originally Posted by Reggiesrocket View Post
    As can be seen from the Pic of the kit the resistor value is 8 ohm and 50W. They are available from za.rs-online.com at about R60 each.
    Hillcrest, Malaysia
    Thanked: 6460
    Or just wire in an indicator bulb and leave it taped to something under the bonnet.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Sep 2010
    Brymore, Port Elizabeth
    Thanked: 31
    ...and when all is done go sit in a sedan and have someone approach you at night with your vehicle and decide if that is what you would like to do to all the other road users you are going to approach at night.
    Pieter
    2018 Fortuner 2.8 4x4
