Media Release: SA first country globally to launch automatic on the Mahindra
Results 1 to 9 of 9
    Jun 2018
    Thanked: 73
    Default Media Release: SA first country globally to launch automatic on the Mahindra
    South Africa first country globally to launch automatic on the Mahindra Pik Up
    January 15, 2020; Pretoria: The highly popular Mahindra Pik Up range has a new flagship and its automatic!
    The all-new Mahindra Pik Up S11 Automatic arrives on dealership floors a couple of months after completing a year of arduous testing in South African conditions, including extended durability testing at the tough Gerotek test track outside Pretoria.
    "South Africa is the first country in the world to officially launch the all-new Pik Up Automatic, which is only fitting, since it was the test bed for this model. There has been an overwhelming demand for an automatic transmission in our bakkie range, and we believe we have the perfect answer with the S11 and S11 Karoo AT," says Rajesh Gupta, CEO of Mahindra South Africa.
    Smooth-shifting six-speed flagship
    The all-new six speed automatic transmission fitted to the Pik Up is a next-generation transmission used for the first time on this model. It features a sequential self-shifting option and is mated, in 4x4 models, to a new Hill Descent Control (HDC) system that utilises engine and vehicle braking for slow descents on tough, off-road terrain and that can be controlled with the in-built cruise control system.
    The transmission has been designed to offer near-imperceptible shifts and to best utilise the 320 Nm of torque delivered by Mahindra's mHawk turbodiesel engine, while the engine mapping has been fine-tuned to work perfectly with the standard cruise control system, for effortless long-distance cruising.
    At first, the new automatic gearbox will only be available in the double cab Pik Up body style. It will be launched with a new, luxury S11 specification level that includes all the luxuries of the S10 and more.
    "Our market research shows that customers often prefer an automatic transmission in the double cab lifestyle segment of the bakkie market. We have therefore combined the new automatic transmission with a very high level of luxury equipment so that the customer's every need is taken care of," says Rajesh.
    S11 - Eye-catching design
    The new automatic transmission is not the only change to the Pik Up flagship. The new S11 specification level boasts a new grille and bumper, upgraded headlamps and other subtle luxury changes to the design to make sure that it immediately stands out as the top-of-the-range model.
    The main design change is the bold and stylish new grille, which replaces the narrower chrome inlays of the S10 model with wider chromed vents that are reminiscent of the range-topping Mahindra Scorpio S11 models.
    The grille is flanked by new headlamps, with chrome inserts housed in and behind clear screens. New, chromed fog lamp surrounds in the wide, lower air intake round off the front design changes.
    In addition to the new front design, the S11 Automatic Pik Up has colour-coded side mirrors with integrated indicators. At the rear of the new model, there are S11 and Automatic decals as well as the addition of a new reverse camera that has to date not been available on any Pik Up model.
    Luxury abounds
    To further boost the premium appeal of the all-new S11 Automatic Pik Up, Mahindra has added a host of new luxury features as standard on all models.
    Taking centre stage is a brand-new 7" touch screen infotainment system with a capacitive interface. This new system offers Bluetooth connectivity, a multitude of entertainment and vehicle information screens and full turn-by-turn navigation as standard. The infotainment screen also displays the image of the in-built reverse camera in full colour.
    All S11 models will further offer an automatic climate control system in place of the standard manual air conditioning system, and all models have an adjustable multi-function steering wheel that controls the infotainment, phone and cruise-control systems.
    As the most luxurious model in the range, the S11 carries over all the luxury and safety features of the manual S10 models. This includes two airbags, 12V power points for the front and rear occupants, traction control, electric windows with an automatic up/down mode on the front windows and automatically locking doors.
    Trusted mHawk power
    All S11 models will be fitted with Mahindra's much-loved mHawk turbodiesel engine of 2.2 litres.
    This four-cylinder engine has common rail injection and turbo charging to deliver 103 kW at 3 750 r/min and 320 Nm at a flat band between 1 500 r/min and 2 800 r/min.
    The mHawk turbodiesel was designed with a high 16.5:1 compression ratio to offer exceptional performance, while only using 7.9 litres of fuel every 100 km in a combined testing cycle.
    The King of Pik Up models - S11 Karoo AT
    Mahindra first launched the Karoo Special Edition late in 2018 to celebrate the successful opening of its local assembly facility in Durban, KwaZulu-Natal.
    Since its launch, the Karoo has proven to be extremely popular - in both S6 and S10 specification levels - and it has prompted Mahindra to design a special S11 Karoo model with a refreshed design theme and even more equipment as standard. This model will offer all the luxury equipment of the S11 range and add additional styling features and specifications for a truly stand-out special edition model.
    Viewed from outside, the all-new S11 Karoo Automatic will feature a unique decal design on the side panels and nudge and styling bars. This model also has a custom-designed and lockable roller deck system for the load box as standard, while all S11 Karoo models will have a rubberised load bay.
    Rounding off the new design are special custom designed off-road ready alloy wheels that feature a blacked-out design with chrome detailing.
    At the same time, Mahindra has made subtle changes to other Karoo models.
    On the S6 Karoo, Mahindra has upgraded the decal package to align it more closely with the new design on the S11 Karoo. It has also created new designs for the roll bar, featuring a steel-stamped Karoo decal.
    The S10 Karoo will also get updated decals and branding on the steel roll bar, but it will further treat owners with a new tonneau cover and upgraded stylish alloy, all included in the standard selling price.
    Built on the Pik Up DNA
    While the Pik Up S11 Automatic and S11 Automatic Karoo are the most luxurious models in the range, they share the same tough and durable DNA of their siblings.
    All Pik Up Double Cab models feature a standard ground clearance of 210 mm, an approach angle of 34 degrees and a departure angle of 15 degrees. The high standard ground clearance and narrow-fitting side rails mean that the Pik Up has a very impressive breakover angle of 18 degrees.
    Among the many benefits of owning a Pik Up are its heavy-duty Cushion suspension system, which allows the 4x2 double cab models to load up to 1 095 kg, while 4x4 models can easily transport up to 995 kg. As on other models, the S11 also offers a double walled load bay for extra durability.
    The Mahindra Pik Up double cab range is certified to tow a braked trailer of up to 2 500 kg, and all double cab models are fitted with Mahindra's mechanical differential lock (MLD), which it developed in partnership with Eaton and which offers complete lock-up between the rear wheels when there is a loss of traction, such as in challenging off-road conditions.
    Lastly, the Pik Up has a comprehensive range of accessories, including approach and recovery bumpers and rock sliders that can be fitted under warranty by any Mahindra dealership or at Mahindra's newly inaugurated Special Fitment Centre in Gauteng.
    Warranty, service plan and pricing
    The all-new S11 Automatic and S11 Automatic Karoo will be available with a standard 4-year / 120 000 km technical warranty and free Roadside Assistance plan. It also has a comprehensive service plan for 5 years or 100 000 km. The first lubrication service is at 10 000 km and every service thereafter will be done at intervals of 20 000 km.
    The double cab pricing is as follows:
    Mahindra Pik Up S6 4x2- R312 499
    Mahindra Pik Up S6 4x2 Karoo - R322 499
    Mahindra Pik Up S6 4x4 - R342 499
    Mahindra Pik Up S6 4x4 Karoo - R352 499
    Mahindra Pik Up S10 4x2 -R347 499
    Mahindra Pik Up S10 4x2 Karoo - R352 499
    Mahindra Pik Up S10 4x4 - R377 499
    Mahindra Pik Up S10 4x4 Karoo - R382 499
    Mahindra Pik Up S11 AT 4x2 - R384 999
    Mahindra Pik Up S11 4x2 Karoo AT - R399 999
    Mahindra Pik Up S11 AT 4x4 - R414 999
    Mahindra Pik Up S11 4x4 Karoo AT - R429 999
ID:	554380   Click image for larger version.
ID:	554381   Click image for larger version.
ID:	554382   Click image for larger version.
ID:	554383   Click image for larger version.
ID:	554384   Click image for larger version.
ID:	554385   Click image for larger version.
ID:	554386   Click image for larger version.
    Friemersheim, Southern Cape
    Thanked: 3104
    Default Re: Media Release: SA first country globally to launch automatic on the Mahindra
    Wonder if Reenen is going to change from Nissan to Mahindra
    Langs die rivier, op n berg
    Thanked: 2980
    Ek is nie getroud met n fabrikaat. Ek het basies van alle (meeste) fabrikate.
    Thanked: 2980
    Maar mahindra lyk nog vir my grond lelik
    Constantia Kloof
    Thanked: 1011
    As hulle die auto in die single cab sit ruil ek more myne in.
    Brandt Theunissen
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
    Mar 2016
    Auckland
    Thanked: 63
    Let's see how this works out. Personally i think the manual gearbox in the pikup is not a great gearbox, now before fixing it they are putting out an auto.
    Constantia Kloof
    Thanked: 1011
    Quote Originally Posted by Kiwi 4x4 View Post
    They did fix it. The 6 speed box in the new Pik Up is a tremendous improvement over the 5 speed unit found in older models.
    Brandt Theunissen
    1968 VW Beetle 2276
    Jan 2020
    Thanked: 11
    Quote Originally Posted by Koebelwagen View Post
    I have to agree. The 6 speed in my Pik Up is really good. Makes highway driving a breeze. I am glad I bought Mahindra when I did, the new pricing shows that the brand is slowly moving towards a more premium offering.
    I wonder if the auto will boost sales and bring people across from other brands
    Sep 2018
    Thanked: 106
    Quote Originally Posted by Schambies View Post
    Schambies I agree 100%
    The gearbox is great, 2,600rpm at 120, featherlight clutch and it really works well in difficult terrain. I certainly wouldn't swap this gearbox for an automatic, but then I never liked auto boxes anyway.
    I'm also glad I bought when I did - you run a risk as an early adopter but with Mahindra trying to break into a market dominated by Ford and Toyota, they had to shave their profit margins at first, translating as very good value for money.
    That you see more and more of them on the road explains the price increases.
    I'm extremely happy with the S6 Pik Up all round execpt for one thing - the alarming reports on this forum about catastrophic wheel bearing failure.
    I have an excellent local dealer, Mahindra Helderberg who I have pointed at the relevant thread with an email headed bad publicity asking them to look into this issue, specifically whether it has been addressed on the newer models.
