2008 Ford Ranger 3.0TDCI - ABS Light
Results 1 to 12 of 12
    Jul 2017
    Thanked: 102
    Default 2008 Ford Ranger 3.0TDCI - ABS Light
    Just wondering if anyone has had this happen to them. Driving back from Laingsburg my ABS light came on and hasn't gone off.
    I checked the fuse in the engine bay and all seems fine. Also had an emergency brake situation on the M3 and brakes seem fine.
    I probably need to take it to have the error code read, but if possible I would like to try solve it myself.
    2008 Ford Ranger 3.0 XLT 4x4
    Aug 2015
    Kraaifontein
    Thanked: 21
    Default Re: 2008 Ford Ranger 3.0TDCI - ABS Light
    I had the same on my BT-50, it was the right front ABS sensor that was faulty. Replaced it with one from Mazda and all was good again.
    Brynmor
    2014 Ford Ranger 3.2 Extracab 4x2
    2012 Ford Ranger 3.2 Extracab 4x2 (Sold)
    2009 Mazda BT50 3.0 Extracab 4x2 (Sold)
    Jul 2017
    Thanked: 102
    Thanks. Do you know where these are situated?
    I want to take them off and clean them.
    Thanked: 26
    You will see them clearly behind the wheels. They have white wires.
    I can post a photo if you are interested.
    Jul 2017
    Thanked: 102
    Thank mate.
    If you don't mind that would be awesome. Gonna give it a go this afternoon.
    Thanked: 26
    The white wire/cable isn't white any more but my pen points at it. The pen is on the ball joint. Its the LF wheel.
    Klipriver
    Thanked: 239
    Brake fluid level?
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Thanked: 26
    Brake fluid level doesn't influence the ABS light.
    Jul 2017
    Thanked: 102
    Thanks so much mate, your advice lead me straight to the problem area. The small bracket (holding the wire) bolt came loose and caused the wire to touch the wheel and wear through. Bit of soldering, tape and a new bolt with locktite and its all fixed.
    Thanks again.
    Jul 2017
    Thanked: 102
    thats the handbrake light if i am not mistaken?
    Thanked: 26
    Correct
    Thanked: 26
    Quote Originally Posted by Walnut View Post
    Thanks again.
    Pleasure is all mine
