Painting aluminium (aluminum?)
Results 1 to 20 of 23
    Tshwanetoria
    Thanked: 787
    Default Painting aluminium (aluminum?)
    Can aluminium be painted successfully? How?
    Would like to make my solar panel slides underneath the roof rack, permanently black
    Dec 2010
    Morgenzon
    Thanked: 35
    Default Re: Painting aluminium (aluminum?)
    if bare metal then paint first with 1k etch primer then normal ms primer and youre 2k paint or what ever
    Thanked: 939
    As mentioned in the previous post you need to use an etch primer for aluminium that you can get from better auto paint outlets. Clean the surface with thinners and rub it down with Scotch Brite to get a matt finish. This allows the primer to adhere to the surface without peeling off. The spray normally with a good quality 2k paint. Just remember that the aluminium etch primer, fill primer and paint will all use different hardener and thinners at different ratios.
    If the frames sections can be removed from the panels you could have the aluminium annadised black which will be hardier than painting.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
    Nov 2012
    Thanked: 1087
    I have aluminum roofrack that I had sandblasted. Then painted it with hammerite special metals primer and then with black hammerite. After a couple of years of duty it is still as new. I don't think you can get better than that.
    Choose life
  5. The Following User Says Thank You to Coenoes For This Useful Post:
    Wartburg
    Thanked: 1676
    I used automotive primer for aluminium with good success. Beige stuff.
    Thanked: 939
    It is probably okay when there is no flex in the aluminium but it's best to use the stuff the paint manufacturers recommend. I've seen sheets of paint come off the side skins of a Lotus 7 replica because they used normal steel paint and primer. If you are taking the trouble to do the job, do it the correct way the first time.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
    Wartburg
    Thanked: 1676
    The local automotive paint shops have different stuff for aluminium, according to them. Not sure of the make or name of it? Used it to spray some of my LRs as well as the Al canopy and RR I built. It never peeled - only tough Arcacia thorns cut through it
    Wilderness
    Thanked: 1222
    Jotun hardtop Flexi. No primer needed, sand or scour well and paint. 10000 km and 2 years and the doors on my caravan are still fine! One of the well known offroad caravan manufacturers, also use this successfully.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Tshwanetoria
    Thanked: 787
    Hence my question. As I understand it, oxidization of alu takes place so quickly (although not visible to the naked eye) that you do need a special primer, applied immediately after "cleaning" the material. But that is what I read many years ago. I assume technology has advanced and I am pushing my luck. Somewhere in my subconscious, the Hammerite option got stuck.
    My "project" is really not something huge - just to lenghts of 25x 40 alu channel fixed to the RR with brackets made from 25 x 50 angle alu. I think the whole setup will look a lot better if the alu could look the same as the RR. You know that itch, the one until the next camping trip arrives, don't you?
    Thanks for all the advise, I thing for interest sake and to scratch the itch, I will experiment a bit?
    Thanks a lot for the inputs!
    Tshwanetoria
    Thanked: 787
    Thanks, never heard of that. Where can it be sourced?
    Thanked: 82
    Ciry Paint and Tool, or Google Jotum stockist
    Jul 2013
    Thanked: 309
    Tshwanetoria
    Thanked: 787
    Quote Originally Posted by janseekat View Post
    Thanks!
  15. #14
    Dec 2014
    Thanked: 1915
    For the choppers that we used offshore when I was at Court Helicopters we used to scrub the ally with scotchbrite, treat with Alodine, then prime with Plascon EpiWash Strontium Chromate primer, and paint with topcoat of choice.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  16. #15
    Mar 2016
    Louwsburg
    Thanked: 206
    OP, what did you end up using, and did it work? I want to paint my canopy doors and roofrack black, so looking for a diy optionClick image for larger version.
    2017 Mitsubishi Triton D/C 2.4 manual 4x4
    2014 Mitsubishi Pajero Sport 2.5 Auto 4x4
    1998 Mitsubishi Pajero SWB 3.0 V6 - SOLD
    2017 Ford Ranger XLS Auto 4x4 D/C - SOLD
    2014 Mitsubishi Triton 2.5 DiD D/C - SOLD
  17. #16
    Thanked: 920
    Crikey, lots of overcooking here - clean well with a scotchpad and use the best paint in a can - Rustoleum......one very light coat followed by two more at 20 minute intervals.
    FJC - Just Cruising
  18. #17
    Cape Town Southern Suburbs
    Thanked: 1134
    Quote Originally Posted by dirtshark View Post
    On bare metal or aluminium you need to first prime with etch primer or else that paint will be flaking off well before it's time.
  19. #18
    Thanked: 920
    Yes sorry I meant Rustoleum Self etching primer, fantastic stuff not needed for normal metal though, just usr the Rustoleum 2X for that.
    FJC - Just Cruising
  20. The Following User Says Thank You to dirtshark For This Useful Post:
  21. #19
    Thanked: 1059
    Why paint it? Much easier to chemically colour it black. Much easier and much more successful.
    We did that to colour mag wheels when we were younger, colour the whole face black! Just polish the front edges to shiny silver.
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
  22. #20
    Tshwanetoria
    Thanked: 787
    You have a number of option, as indicated above. Obviously, you get what you pay for.
    I used:
    https://www.duram.co.za/product/ns5-...e-etch-primer/ follow the instruction to the letter.
    And good quality PU satin black paint.
    Since I painted small surfaces, 40x50 alu channel for my solar panel carrier, it was easy to obtain a even and smooth finish. I used a small sponge roller - the newer type that seems to have fine hairs on it. It gives a nice textured finish.
    Durability still to be proven, but I can tell you that the end result gives a very hard finish. Being alu, peeling may eventual be the problem.
    If I had to paint larger or more surfaces, I would have gone for other products that may have warranted the costs.
  23. The Following User Says Thank You to hatjohan For This Useful Post:
