2008 KB 300 D Teq loosing water
Results 1 to 20 of 21
    Live : Bethal , Work : Saudi
    Thanked: 228
    Default 2008 KB 300 D Teq loosing water
    Good day guys
    My Isuzu is loosing water
    No water leaks
    No water in the oil and no oil in the water
    Any advice please
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
    Wilderness
    Thanked: 1079
    Default Re: 2008 KB 300 D Teq loosing water
    Take the bashplate off underneath the engine. Check behind the waterpump pulley for a telltale droplet before you start in the morning. there should also be a telltale mark under the bonnet where it sprays water from the belts. Check that radiator cap seals proper. Look for any discoloration around pipe joins and clamps and behind the waterpump pulley. When the engine has reached operating temperature and using the wifes vanity mirror, use the mirror to check for steam from a broken pipe or leak.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Thanked: 228
    Thank you Pieter
    I will have a look in the morning
    One life Live it
    Sep 2019
    Kokstad
    Is the system pressurising at all? Seen a few that have leaked into the EGR system through the cooler on the side of the head. Could be worth a check as well as a last resort.
    Thanked: 228
    Quote Originally Posted by Jared Mk3 View Post
    Thank you
    Will have a look in to it thank you
    One life Live it
    Nov 2011
    Langebaanweg
    Thanked: 789
    Mine isn't an Isuzu but to show how easily a leak can be missed on a water pump, here's mine.
    I didn't see a loss in water but a change in water temperature.
    I had an idea something was wrong but only found it with a mirror. This was bearing seal failure.
    84' Land Rover Defender 110 V8 4-speed Hardtop (Meisiekind) Sold after 12 years of fun and hard work
    Thanked: 228
    I noticed a change in temp thats when I looked at the water and saw the plastick bottel gets low after every drive
    One life Live it
    Langs die rivier, op n berg
    Thanked: 2476
    Gekraakte top?
    Wat is rede dat vorige eienaar verkoop het?
    Thanked: 228
    Gekraakte top?
    Geen idiee hy antw my glad nie
    One life Live it
    Wilderness
    Thanked: 1079
    If the temperature is rising and losing water,(pressure loss) there is definitely a leak somewhere. Cracked head, check for air bubbles in the radiator and it can overflow into the reservoir/expansion tank.( only when hot) It also depends where the head is cracked. Could be into an exhaust port. But we are making a mountain of a molehill at the moment. Check the other things first.
    Thanked: 2476
    Quote Originally Posted by Haggy4x4Bedinges View Post
    Daarin lÍ dalk n antwoord...
    Thanked: 2476
    As jou pomp nie lek nie, en jou heater core in cab ook nie, is kans baie goed dit is of headgasket, of top wat gekraak is en na exhaust toe stoot. Nie terwyl jy ry nie, maar bietjies bietjies elke keer as jy kar afskakel. Dan verloor hy water na combustion chamber terug vanaf radiator
    Thanked: 2476
    Nie seker van isuzu, maar as hy n non pressurised expansion bottle het, trek pypie van radiator nek af, vervang met ander langer pypie wat jy in n glas bottel hoer as radiator laat staan, met pypie sumerged. Maak radiator tot bo vol, sit prop op, start bakkie. Nou wag jy vir borrels in bottel
    Nov 2017
    Thanked: 163
    If you have a mate with an exhaust gas analyser, remove radiator cap when not dangerously hot and check for any exhaust gas in radiator - you are looking for hc and/or co.
    Alternatively get a radiator company to do/use a combustion leak test - fluid will change colour.
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 754
    Vervang die hervulprop vanaf agente.
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
    Thanked: 228
    Kannie bakkie het n custom radiator in met n klein prop
    One life Live it
    Thanked: 2476
    Foto van radiator
    Queenstown
    Thanked: 24
    Hoeveel kpa of bar is die standaard d-teq prop? Ek sien sommige mense het 0.9bar en ander 1.1bar of 108kpa.. Sorry ek vra en Wil nie hijack nie.. Maak seker jou radiator is die regte een ander gaan hy verseker overheat..
    Thanked: 2476
    Al verder iets wys geword?
    Thanked: 228
    Quote Originally Posted by Kleintjie View Post
    Ek het geen idiee
    Goeie vraag laat my nogals ook wonder
    One life Live it
