2008 KB300 D teq inner CV Joint
Results 1 to 6 of 6
    Live : Bethal , Work : Saudi
    Thanked: 228
    Default 2008 KB300 D teq inner CV Joint
    Good day
    Can someone Help me my Beast has n broken driver side inner broken cv joint
    And I can't seem to find one here in Bethal
    And the stealers are stupid crazy with there price
    Thanks in advance
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
    Jul 2014
    Default Re: 2008 KB300 D teq inner CV Joint
    Do you have a CV shop in town?
    They will be able to assist.
    2004 Hilux 2700i 4x4 DC Raider
    2009 Terios 1500 4WD A/T
    Thanked: 228
    Quote Originally Posted by Whirly View Post
    No unfortunatly not
    But think there is one in Secunda
    One life Live it
    Jul 2014
    They will surely be able to assist, at a reasonable cost.
    Feb 2016
    Paarl
    Thanked: 588
    If you phone Johan at Autostation Bellville, I'm sure he can assist, maybe even post to you. I have yet to go to him with something he doesn't have...
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
    Thanked: 54
    I had to replace the outer shaft...left front on our 2010 KB5 KB300. A year or 2 ago. The small inner roller bearing had no lubrication and was so hungry that it ate it self and made pit marks on the drive shaft.
    Went to a CV joint workshop, they replaced the outer shaft with one that is for a KB4 and cut off the last section of the outer point....if that makes sense.
    Currently I am hearing a clicking/clapping noise when just reversing out of the garage or when I have stopped and need to sharply reverse...my suspicion is its the “new/repaired” CV joint left front.
    We went to Pilansberg this past weekend and activated 4H on one dirt road and deactivated it when we went onto tar again. Afterwards it started to make a sound that sounds like a piece of wire that could caught up on something that rotates...a scratching, screeching noise. Is it the small inner roller bearing again? CV joint? I will still open it up again and check as well.
    Does anyone have a name of a proven good quality replacement drive shaft... apart from the original from ISUZU directly?
    Anyone used www.bulksource.co.za.... how is their pricing, quality and service?
