Water pressure tester
Results 1 to 20 of 24
    Thanked: 99
    Default Water pressure tester
    Hi guys,
    I am trying to get my hands on a water pressure tester that can connect to normal threaded tap fittings.
    As usual they are prolific in the USA but I have not been able to find anything locally, does anyone have any idea where I might be able to buy one?
    Looking for something like the below,
    https://www.amazon.com/Rain-Bird-Pre.../dp/B00004RACK
    2009 Suzuki GV 3.2
    ex : 2010 Suzuki GV 2.4 M/T
    ex : 2007 Audi A4 2.0T - RS4 rear suspension 8)
    Thanked: 26
    Default Re: Water pressure tester
    I bought a gauge from Plumblink and built myself one that connects via gardena fittings.
    I'm trying to upload a photo but it refuses to load. Maybe due to "loadshedding".
    May 2013
    Thanked: 7
    Plumblink has a similar water pressure gauge.
    Genebre brand
    You will have to buy one brass fitting and then you can connect a piece oh hosepipe with a hose clamp and use hosepipe fittings on the other end.
    Will thread onto your garden tap and will also thread onto the male fitting of your water meter
    durban
    Thanked: 854
    Plumblink sells the whole thing ready built.
    Apr 2017
    Durban North
    Thanked: 989
    It actually comes with a flexi hose and a adapter that fits a 3/4 " male fitting, ie. A standard hose tap
    Thanked: 99
    thanks gents, will pop into plumblink tomorrow to take a look.
    2009 Suzuki GV 3.2
    Apr 2017
    Durban North
    Thanked: 989
    This is available at OnTap and Plumblink
    R350-400Name:  IMG_20200110_095156.jpg
    Thanked: 285
    Quote Originally Posted by Dudleytheplumber View Post
    This is available at OnTap and PlumblinkR350-400Name:  IMG_20200110_095156.jpg
    Eina… R350-R400 is a lot of money for a quick once off test....
    2017 Mitsubishi Triton 2.4 D/C 4X4 6 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
    Thanked: 26
    Quote Originally Posted by SinWolf View Post
    Thats why I bought an R80 rand gauge @ Plumblink (there wasn't one with tubing on it) and a brass fitting.
    Thanked: 99
    ya I stopped by this morning, was also put off by the price tag.
    2009 Suzuki GV 3.2
    durban
    Thanked: 854
    Quote Originally Posted by ColeGP View Post
    So then i guess you wouldnt be interested in the quality one i sell that is gel filled and comes in a wooden box and can do virtually every thread in plumbing that you can think of.
    Apr 2017
    Durban North
    Thanked: 989
    How much of monies
    Langs die rivier, op n berg
    Thanked: 2492
    R60 gauge, R5 galv reduce bush, R30 flexi 1/2” flexi braded hose
    Thanked: 99
    shucks I just want to check pressure before my PV and after it, not launch a space shuttle!
    2009 Suzuki GV 3.2
    Thanked: 107
    Got two from my local irrigation shop to put on my Azud filter, before and after, to check pressures, Gel filled nogals for around R65 a while ago, they had a few with varying ranges.
    This was from A&J plastics in Koedoespoort, SA Plastikor also had stock.
    Wynand
    2005 Discovery 3 HSE v8
    2002 Discovery II XS v8 (sold)
    1974 Chev K 25 (julle dink 'n v8 is dors)
    Land Rover - making mechanics from motorists since 1947 and electronic engineers since 1989!
    Apr 2017
    PUMULA
    Thanked: 291
    do the finger test.
    open tap wide - stop water with finger, if you can,,, pressure far too low.
    if you battle to stop water with finger, pressure ok.
    Current off-road vehicles: *** Great family accommodation. See Facebook, Google maps and airbnb. Wild Wind Ranch/Mkulu Kei
    * 1975/8 SHREK Land-Cruiser FJ40 DIESEL P/U, BFG 31x10.5 muds. 2 x 1.6 ton tirfor winchs
    * 1994 Land-Cruiser J70 DIESEL P/U, my truck recovery vehicle. 15000 warn winch. And 3.5ton tirfor winch. Back full of appropriate sized recovery gear. BFG31x10.5 muds
    * 2014 Land-Cruiser LX V8 76 DIESEL STATION WAGON, BFG's 285 all terrain.
    * 1988 HILUX TOYOTA 4x4 D/C.
    SOLD 2020 Jan.
    * 2011 HILUX 4X4 P/U, BFG 31x10.5 all terrain
    * 1999 PAJERO 3.5 V6 Mitsubishi (sorry not a Toyota), BFG 31x10.5 all terrain
    * 2006 FORD ranger 2.5 diesel. 4x4, (what was I thinking, also not a Toyota!) I have a spare 5000 warn winch I might fit.
    * 2011 Isuzu bakkie 4x4
    * FIONA - Rhino Yamaha 660 4x4. Warn winch. Mud tyres
    * 4x4 trailer, 1987, BFG all terrain
    * GSA 1200 BMW ADVENTURE LC 2018, the closest motorbike to a land cruiser
    * A Massey Fergusson 375 tractor. Not BFG's and not a 4x4
    Thanked: 99
    So I put together a tester, on my unregulated garden tap I get a whole 5 bar!!! (fantastic, supposed to be 8-10 I am told)
    I installed a new 400kpa pressure regulator and tested a tap on the line and I am getting only 2 bar.
    My question is, do pressure valves have an "effective range" that they need to have coming in, in order to output what they are set for?
    So is it possible that the 5 bar incoming is not enough to cause 4 bar of pressure to make it through the valve?
    We thought the valve itself was faulty so we changed it out but the new valve is also showing only 2 bar.
    Or is that not possible and I have some issue under ground between the unregulated tap and the feed to the regulator?
    2009 Suzuki GV 3.2
    Thanked: 26
    I am not an expert but I believe 8-10 Bar is too high. 5 Bar is more normal. Lets wait for the proffessionals to give their opinion (s).
    Thanked: 130
    I did a factory tour at on of the valve manufacturers and been told that you will seldom see more than 3.2 bar from a 400kPa valve.
    But why your only get 2 bar after the calve, I dunno. Maybe phone up the manufacturer and make it their problem?
    Si vis pacem, para bellum
    durban
    Thanked: 854
    If your incoming pressure is 5 bar which is very good then any pressure reading after the prv will be less than 4 bar. I forget what most 400 kpa prvs are set to. But I think its about 285 to 350 static.
