Discovery 4 D4 2011 Manifold Leak
Results 1 to 10 of 10
    Default D4 2011 Manifold Leak
    Hi All
    I have a blowing/hissing sound coming from the engine round about 2000RPM.....I was told that i have a manifold leak (not from the agents...). The good part to this is that the gaskets are cheap BUT they need to lift the body to replace and i'm in for about R30k. It is also due for timing belt replacement as i'm on 165000km.
    Any advice/comments/recommendations will be highly appreciated.
    Discovery 4 HSE 2011 165000km
    Discovery D4 HSE
    Thanked: 15148
    Default Re: D4 2011 Manifold Leak
    What engine?
    Thanked: 371
    Quote Originally Posted by Echo4 View Post
    Hi All
    Can also be a boost leak, on the pipes running to the intercooler and then to the IM
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
    What engine?
    It is the diesel.
    Discovery D4 HSE
    Sandton
    Thanked: 75
    Speak to Walter from LR Extreme.
    GASMAN
    Land Rover D3 TDV6 HSE 2007 - Goldilocks - Gone
    Land Rover D4 SDV6 HSE 2012 - Voeniks
    Ratel Bullbar
    Ratel Snorkel
    Ratel Rock Sliders
    Ratel Offroad Tow Hitch
    Melville & Moon Seat Covers
    TORQTUNE Map
    ORRA Z 173
    Thanked: 15148
    Boost pipe or cracked intercooler
    Jan 2020
    Paarl
    Hi All
    hi Echo4. I was interested in your outcome. I have just been told the same on the same vehicle at 190000km. was there any surprises, is it a patch job or a replacement part ... as you say the 30k is mostly going to what they say is 15h work. P.s this is from land rover themselves.
    thanks in advance for any input
    Thanked: 201
    Quote Originally Posted by DSH View Post
    Most likely exhaust manifolds gaskets leaking.
    If you get it done,either replace or skim the manifolds, and replace the studs and nuts holding it.
    I might be wrong but I think its possible to do driver side without taking the body off.
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1999 Land Rover Discovery 2 V8 (Another one)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2007 Subaru Forester XT 2.5T (The Daily)
    Ex.
    Discovery 1:TDI and a V8. Discovery 2 V8. Discovery 3 TDV6.
    Freelander 2 TD4
    Jul 2016
    Thanked: 523
    Usually on a D4 is the rear most manifold studs that break. Not body off job
    Jan 2020
    Paarl
    Thanks. Have booked it in for end of month. Will update resolution then.
