2014 Mitsubishi Pajero Sport (Challenger in NZ)
Catch me outside, how 'bout that?!?
2012 Touareg 4.2 V8 TDI (Air)
I like these sort of debates.
Let's go back the OP's question. Is the Kuga a 4x4.
Well, from a technical perspective I can't say, as I don't count myself qualified. But it does have a AWD system.
So, compared to a Ford Focus, yes, the Kuga is a 4x4. Compared to a Jeep Wrangler modified, lifted, and so forth, no, it is not a 4x4.
Now, I drive a FL2. For me it is a real 4x4, as it can go places where a 2wd car cannot go. Is it a rock climber? Hell no. Can it do trails, yes, to a degree.
Further more, you have different types of 4x4 vehicles.
Not all 4x4's are rock crawlers. Not all 4x4's are mud slingers. Not all 4x4's are sand drivers. And then, let's throw a spanner in the works. You have a Ripsaw EV2. Is that a 4x4? I can bet you it can go where most 4x4's go, but it is a tracked vehicle, so what is it technically?
So, in a nutshell. If you wan't to go a bit of the beaten track in your Kuga, and you wan't to try some trails, go for it. I'm sure the vehicle is capable of doing some stuff, and if you like that stuff, you can classify it as a 4x4 for your purpose.
Btw, I have seen places where some guys won't take their "real" 4x4's as it might cause damage, and that is the same reason I won't do some stuff with my FL2. I want to have fun, but I don't want to damage the car.
Anyway, this is my view on it. This is not a technical bulletin.
2011 Freelander 2 SE
Eish!
This is supposed to be the "go-to" 4x4 forum in SA, and the members fail to distinguish between
- Drivetrain configuration (refer my post #18)
- Offroad ability
The OP's question was"Does a Kuga count as a 4x4??"
Most of the answers are as if the OP's question was"Does a Kuga count as a proper off-roader?"
Another question could have been"Does a Kuga count as a rock-crawler?"
2003 Mitsubishi Pajero 3.2 Di-d LWB
Probably the most topical comment here and worth investigating. If the Kuga is indeed grouped together with the other vehicles above - and taking into consideration the pedigree and time line it may well be - lifting it by 20mm would be a formality. Another 10mm with one tyre size/profile increase and you should be good.
Hi Rojas - original poster, should someone care to know: I sympathize with you for stumbling across the "Green Kalahari Dune Bashing Community" , which then - as could be expected - went off into presenting theories, ideologies, definitions and finally veered completely off topic. In hindsight, the Softroader group might have been more capable to sensibly help. Also, perhaps avoid using the term "4x4" in a thread title when discussing SUVs ....
Shady will send you a PM - other than the general invitation on the forum - for the next Softroader outing, where you can evaluate the Kuga under expert guidance. If you don't like a specific obstacle, you skip it and learn from the others.
We have had two very successful/educational meetings. This is mostly because although we go a bit nuts, our balls are all about the same size.
PM me if you would be interested in lifting the Kuga, then I'll guide you where to look and take pics so it can be determined if it is just a straight Freelander 2 spacer installation.
I recommend you direct further questions to the Softroader section.
Johnie
Volvo XC60 T5
180kW/350Nm (1500 - 4800 rpm)
In my practical experience I have come to the following conclusion wrt the 2 vehicles we own:
Renault Duster 1.5 4wd
Our first off roader we bought and we took her out on a couple of trips and I was very impressed with her capability as we did Groenkloof mostly, I think we didn't do the Hippo hole and the climb just left of this obstacle.
It was according to me at that stage a very capable vehicle that suited us a couple for holidays especially the fuel consumption part.
Mitsubishi Triton 2.5 4x4 Super select
Totally different league to the Duster, low range and diff lock is just better especially technical obstacles.
So to answer your question wrt the Kuga capability I would answer that it depends on what your needs are?
I would find some open spaces with some ups and downs and see how it goes, maybe join a Fb group the Soft roader group for more advice.
Also maybe watch some YouTube videos on the Kuga and watch what the people are actually attempting in them.
You might strike a bit of a blank here. I had the same issue with the Volvo and earlier, the Tiguan.
The general - overseas - public does not regard that one should even try. "Offroad" to them is "unpaved" or potholed tar to us.The rare videos of showroom cars being taken up a rutted hill, did demonstrate though that in that condition it would not take long to suffer damage or become stuck, especially while you are still getting used to the car. But it is useful in sensitizing what the shortcomings are and where precautions should be taken. Also how little some salesmen know about offroad driving techniques.
So do not let the lack of content put you off.
Johnie
Volvo XC60 T5
https://www.youtube.com/watch?v=dJR5M7RvW5M
This is well worth a look...
I have Absolutely NO idea what she says but I believe her, Oh and there are some footage of the Kuga doing a bit of offroading as well...
That video pretty much shows what these crossover suvs can do.
I think the answer to the original question is a kuga a proper 4x4..NO
I think the criteria for good 4x4s are
ground Clearance
Low range gearing (or as the auto rok a low first...before i get taken down)
diff lock and or decent traction control
Proper offroad tyres
approach and departure angle
What else can one add?
No,it’s AWD.
For me a 4x4 has a low range transfer box.
The answer to the OP is simple. Of course it is a 4x4. Power to all 4 wheels is the definition.
Apply this scenario... my vehicle has a load bed of 3/4 ton. Is it a truck? Yes it is. It is not a 33 ton interlink but no less a truck.
Ask a road train truck driver if a 33 ton interlink is a truck, he will say a real truck can carry 120 tons.
So, if I want to take 500 pieces of braai wood with me on holiday, will I use the road train, the interlink or my truck?
Just like the OP, if he never does rock crawling, why would he want a rock crawler?
He's vehicle is no less 4x4 than the rock crawler, low range and transfer case or not.
Isuzu KB300 d-Teq with high range, low range and long range.
Isuzu KB280DT wif a front diff.
Mercedes W123 300D has been sold.
Bio Fuel and WVO on hold for now.
