General Grabber X3
Results 1 to 10 of 10
    Jul 2017
    Thanked: 103
    Default General Grabber X3
    So thought i would start a review on the above tyres. Just in case someone is looking into getting these. This is a 3ply Mud Terrain tyre, you will see that Shauno from 4wd Action runs them on his cars.
    I got my set from Segal at EFC 4wd for R2850 per tyre, 265/70/16. First impressions were that they are a fantastic looking tyre and on the drive home they are no more noisy than my old Hankook ATM's. Also no shuddering as the tyres balanced easily.
    Since then i have now done a trip from Cape Town to Calvinia, Williston, Sutherland, Lainsburg, Calitzdorp and then back to Cape Town. Thats a mixed amount of tar and gravel, including some emergency braking. I also threw in a trail in Bosch Luys Kloof reserve, nothing mental but lots of sharp rocks.
    On the tar i ran the tyres at 2.3 bar, and as per Johan at 1st Alignments recommendation on gravel i ran the tyre at 1.5 bar (The tyre at 1.5 bar doesnt look like its even that deflated). They performed exceptionally with loads of grip and very little road noise.
    I would recommend this for anyone wanting a MT but without the noise and balancing issues.
    Will post some pics later.
    2008 Ford Ranger 3.0 XLT 4x4
    Ruimsig
    Thanked: 4573
    Default Re: General Grabber X3
    I currently have the General AS (All Seasons) and will look at the Grabber X3 when these need replacing. I have been impressed with the performance on 4WD Action also.
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
    Thanked: 1334
    I see that 265/70/17 cost just under @ R4K at Errols... Dis n bietjie duur
    _______________________________________Dum vivimus, vivamus!With a mild case of "Camping Personality Disorder" or CPD I drive a five cylinder bakkie and tow an army inspired van.
    Jan 2019
    Hartbeespoort
    Thanked: 31
    Quote Originally Posted by Walnut View Post
    I got my set from Segal at EFC 4wd for R2850 per tyre. First impressions were that they are a fantastic looking tyre and on the drive home they are no more noisy than my old Hankook ATM's. Also no shuddering as the tyres balanced easily.
    100% agree with everything you have said. I have them in 235/85/16 and they are awesome! I've done about 20000km without any issues whatsoever 80% tar and 10% gravel roads 10% hard off-roading, rocks, sand and mud.
    I can also recommend them to anyone.
    Jul 2017
    Thanked: 103
ID:	553769Click image for larger version.
ID:	553770Click image for larger version.
    Langs die rivier, op n berg
    Thanked: 2493
    Ek het hulle nou die dag op my 4x2 bakkie gesit.
    235/75/15 @ R1600 incl en fitted per band.
    Wat n verskil. Ek het oorweeg om n 4x4 te koop as daily op plaas, nou nie meer nodig
    pta
    Thanked: 24
    On my list for replacements, had GG's before and they where great in all respects.
    I noticed the other day that Shauno is running different tyres now, Goodyears I believe. However, the GG's did get him through lots of s!!t with no problems, so definitely can be trusted IMHO
    Jul 2017
    Thanked: 103
    Ya on Sooty he runs the Goodyears but on his Landcruiser he still runs the Grabbers.
    Probably find the Goodyears are now sponsored.
    Apr 2018
    Thanked: 156
    Just a few questions, did you go from an A/T 265/70/R16, to these? Or was it a different size A/T?
    Was their any significant change in fuel consumption?
    2017 Isuzu KB 300 4X4 Auto (current)
    2008 Isuzu KB 300 4X4 manual (current)
    Jul 2017
    Thanked: 103
    Quote Originally Posted by A1ex View Post
    Originally i ran BFG 245/70/16. Then went to a A/T 265/70/16. Then i changed to 245/75/16 Dunlop MT2's (narrower tyre but same diameter as a 265/70/16), then back to 265/70/16 A/T. Now finally to the 265/70/16 GG X3.
    Honestly i couldnt tell a difference between the 265 and 245 All Terrains and i used to commute 1280km to work every month. Ever since i stopped using the bakkie to commute i no longer pay to much close attention to the fuel economy anymore. Way i figure if i want good fuel economy i shouldn't drive a 3.0 litre with front and rear off road bumpers and Mud Terrian tyres .
    I am sure though that they will have worse consumption than the All Terrains as they are 3 ply sidewalls and generally a heavier tyre.
