Snomaster 72l Dual F/F smelling, needs sealing
Results 1 to 14 of 14
    Thanked: 736
    Default Snomaster 72l Dual F/F smelling, needs sealing
    Hi,
    My Snomaster is of the older variety and has internal aluminium sides and bottom which are not sealed around the perimeter leaving a gap for liquid to seep out into the insulation which is exactly what happened.
    I had some poorly packed meat returning from a hunt which, with the weight of the other meat on top pressed out blood which stank to high heaven. After repeated washings and airings it has improved.
    So I wish to seal the bottom to avoid future potential occurrences, I am unsure if a Marine Grade Silcone will adhere to the alumimium adequately.
    Any suggestions?
    May 2011
    Thanked: 778
    Default Re: Snomaster 72l Dual F/F smelling, needs sealing
    Contact Pierre at Snomaster.
    May 2011
    Thanked: 778
    Contact Pierre Fourie at Snomaster H/O (Zero 6 two 4 2 one 4 2 nine 3) He s very knowledgeable and helpful. However not sure if they are open yet for 2020??
    Thanked: 736
    I contacted Snomaster this morning before posting. The service department told me that they could not assist in the cleaning as they would do exactly what I could do. Wash with with vinegar and then soapy warm water. I asked if they could replace the insulation and got a No.
    It was Pierre sold me the fridge some years ago, told me it was their last model with the Danfos compressor (which to me was a selling feature) .......... it does not have the Danfos.
    Not to sure that I would want his advice again but will reluctantly try him in the absence of other advise that may be forthcoming.
    Jan 2019
    Thanked: 134
    Can't offer any advice on the sealing, but I had the same problem with smell. Leave about half a cup of bi-carbonate of soda with a few drops of vanilla essence in the fridge to absorb the smell.
    Frank.
    My Blog
    YouTube Channel
    Ruimsig
    Thanked: 4386
    Quote Originally Posted by OffTheHamsterWheel View Post
    When will you update your blog?
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
    Jan 2019
    Thanked: 134
    Estee the next post will be published on Thursday. I decided to take a break during the holidays but will be trying to add weekly posts again as from Thursday.
    Frank.
    My Blog
    YouTube Channel
    Thanked: 886
    Sikaflex 221
    Just ma sure the area is clean and degreased
    Apr 2017
    Durban North
    Thanked: 960
    For smell you can also use
    Aniseed oil, my son used to wash his bait box with it.. That fish smell totally evaporated
    Thanked: 736
    Thanks all.
    Thanked: 114
    I also have one of the older type Camp Master fridge/freezer's with the aluminium pannels on the inside.
    One of the first thing I did on the fridge was to seal the corners and seams with clear silicone and it worked good enough so far.
    Thanked: 736
    Quote Originally Posted by Viertrek View Post
    Thanks,
    and the silicone does not look like peeling off?
    Did you especially prepare the ally with something?
    Thanked: 114
    No pealing so far.
    I have applied the silicone only as a thin seam, right inside the corners, covering about 3mm exposed surface. I also made sure to press it into the "crevaces" as best I could.
    Yes, I have just thoroughly cleaned the surfaces and made sure it was totally dry, before applying the silicone.
    Thanked: 736
    Thanks boet.
