How much lift a bigger tyre provides
Results 1 to 4 of 4
Hybrid View
    Dec 2019
    Thanked: 6
    Default How much lift a bigger tyre provides
    Hello all, can any of the tyre experts explain how to calculate the lift you get from fitting a bigger tyre, im sure its not as simple as 1 inch bigger tyre equals 1 inch lift....
    Jan 2017
    Thanked: 975
    Default Re: How much lift a bigger tyre provides
    1 inch bigger tire will give about 1/2 an inch lift. Give or take a 1/10th based on tire pressure and sidewall stiffness etc
    May 2014
    Tshwanetoria
    Thanked: 750
    Try this
    https://www.errolstyres.co.za/odcalculator
    Also others available on the Net
    Dec 2019
    Thanked: 6
    Ah i see, feel a bit stupid now haha ofcourse if you measure from end to end then its the total divided by 2.
    Thanks, appreciate it
