Liqui moly diesel purge in fuel - Amarok BiTdi
Results 1 to 14 of 14
    Jul 2017
    Default Liqui moly diesel purge in fuel - Amarok BiTdi
    Hi Guys
    Has anyone used this product by pouring it into fuel tank?
    Will it help as a maintenance step? Or should it only be done via the direct fuel feed method?
    Is an oil change required after using this product?
    Jul 2017
    Default Re: Liqui moly diesel purge in fuel - Amarok BiTdi
    Somebody?
    Jan 2007
    Thanked: 324
    I just gooi diesel.
    Thanked: 3638
    Not worth it. Just gooi diesel. If worried install a second diesel filter
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    do you have an actual issue ? if not then don't just put stuff in for incase.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
    Thanked: 1197
    I've used it, it's supposed to clean algae out of your tank.. Use it and change filter afterwards....
    No adverse effects in Kia 2.2, isuzu kb300 and lr td5...
    Thanked: 1112
    What this man said...
    1959 SII 88"
    197? RRC
    2002 Defender Td5 D/C
    Roodekrans
    Thanked: 141
    Quote Originally Posted by CTDi View Post
    Hi Guys
    Did my D4D last year, LM Diesel purge with approx 20L in the tank.
    ran it till almost empty
    Changed fuel filter
    Then filled up with diesel and added a bottle of Wurth injector cleaner
    results, responsive vehilce!
    I will certainly do it again! (using only the above products)
    Jul 2017
    Thanks for the feedback everyone, the problem I experience is that the bakkie runs slightly rough intermittently. Not fough enough to have an erratic idle but there is a grinding sensation felt through the steering. It also feels down on power as compared to the day's when its running smooth.
    Cape Town Southern Suburbs
    Thanked: 1123
    One thing it's supposed to do is bind with any water in the fuel tank and convert it into a compound that can safely be move through the fuel system and injectors and be burnt off in the combustion chamber. Perhaps a good thing to do once every so often to combat slightly dodgy fuel that you may unwittingly encounter.
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    If you have an algea problem then use the specific algea killer. Liqui Moly makes one.
    We find an amazing amount of cars with it in the bottom of the fuel filter and we add the bacterial killer. It works well.
    Look generally LM products are very good. If you have an issue like you describe then sure give it a shot which is why I asked if you are chasing a problem or 'just want to sommer add it'
    Jul 2017
    I don't know really know what the problem is but have the symptoms as I have described above. So this is more of a hit and hope method.
    Nov 2018
    Brakpan
    Thanked: 7
    Let us know if you notice any changes after you done it.
    VW Touareg - 2006 - R5 TDi
    Opportunity is missed by most people because it is dressed in overalls and looks like work - Thomas Edison
    Jul 2017
    Sure will do as soon as I find a moment to get it done
