Freelander II Petrol into a Diesel Freelander II
Results 1 to 20 of 35
    Sep 2018
    Default Petrol into a Diesel Freelander II
    Happy New Year to everyone!!!!
    Kindly provide an advise on whether I should be extremely worried on this case or not. I went to to filling station to fill up the Freelander II HSE TD4 for a R1000.00. The attendant mistakenly put in petrol work R389.00 about 26 litres before he discovers he's pouring incorrect fuel. Him and his colleagues convinced me it wont cause harm, he then proceeded to fill up with diesel worth R700.00 on top of the petrol. I then paid for the diesel only. I then drove for +- 20 KM's. Then went to the mall which is +- 5 KM's away but when I came out of the mall the car could not start but crank. Then went back to filling station and they owned up, and car got taken to Land Rover dealer yesterday for draining and to check for damages.
    Am now worried hence asking if the the damage could be massive.
    Thank you in advance.
    May 2010
    Ruimsig
    Thanked: 805
    Default Re: Petrol into a Diesel Freelander II
    Petrol in diesel car can be fatal!
    Diesel in petrol car is less risky.
    Drain all.
    Dash Fibre: Doing internet differently, drawing customers with best price, keeping customers with best service.
    Earth
    Thanked: 1935
    Problem here is the issue could be minor
    Or you could have done serious damage to the engine
    In between that it could cause issues with your fuel pump and injectors
    If someone puts wrong fuel into your car and then it comes out never ever let them convince you to drive off
    For him it is couple of hundred R and getting into ... with boss
    For you it could end up costing massive amounts and allot of fuel stations will point blank say you need to insure the right fuel in used
    good luck and hope it works out without costing you allot
    What you could have done is have them put pipe in before putting in Diesel and draining all the fuel out that is in the tank
    Then put in clean Diesel
    The 2 - 3% of Petrol that was left would have been very minor amount and then when you reached 50% of tank you could have gone fill up again to drop concentration even further
    2007 Subaru Forester 2.5XT
    (most people don't agree)
    Thanked: 26
    Hi Waboz,
    Really sorry to hear about your bad luck.
    In general this is not great news, but many people have had this happen and been OK.
    Interestingly (according to this article) petrol floats on top of diesel (https://www.telegraph.co.uk/motoring...iesel-car.html)
    As the engine cranks but does not start I would think that the fuel that made it to the injectors has been contaminated, best case I would think that Land Rover will drain and flush everything with fresh diesel and see what happens.
    In terms of long term damage this would largely be unknown - diesel is used as a lubricant in the fuel system but with the ratio described below and the above article is probably minimal.
    Probably not the answer you were after, but I hope it all works out!
    David
    Sep 2018
    Thank you guys, I think I was naive enough as well. The booking into Land Rover dealer is for the filling station account, the owner accepted liability. They also hired me a car meantime to remain mobile. But my worry is would this car be reliable after this incident or I might have continuous issues in the near future.
    Thanked: 894
    The high pressure fuel pump and injectors are very dependent on lubrication from the diesel fuel, so there may be slow onset damage to those that may not be evident at first. But LR would know this, and the typical approach with this type of scenario (if the vehicle was driven after), is to replace fuel tank, pumps, and injectors.
    Jul 2016
    Thanked: 473
    You need to have High pressure pump and injectors replaced. Might not be a problem now but they will soon die
    Forest Hills, KZN
    Thanked: 739
    I recall the FL2 having a device, it was yellow, inside the fuel cap that would bypass petrol if it was used instead of diesel. Something along the lines of a different shaped nozzle.
    Never had to use it so don't know...
    Added: ok, so it was a tool to reset the misfueling device if the incorrect fuel is used.
    https://rimmerbros.com/Item--i-LR014047
    2004 LR Discovery 2 Td5 GS - mods in thread en route. (Ingwe)
    Thanked: 1616
    Quote Originally Posted by OceanWanderer View Post
    Just like the different layers in a shot glass do when carefully poured by your barman, but if you stir it up by moving the vehicle, then you have a mess....
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Dec 2017
    Thanked: 14
    How does this happen? On mine the fuel cap is bright yellow with large black letters saying DIESEL.
    Thanked: 607
    Itís bad news to my knowledge, especially if the engine already wonít start. Complete fuel system replacement is the correct procedure. HPFP fails and sends metal shavings into the entire system.
    2007 Touareg 3.0 V6 TDI (Facelift, Air, Rear Diff Lock, Rear Mounted Spare)
    2008 Audi A4 B8 2.0 TDI (Multitronic)
    2009 KTM 990 Adventure (Weekend Fun)
    2012 Imagine Trailvan 4-Sleeper
    * consumption needs to be seen in the context that the vehicle is towing an Imagine Trailvan 30% of the time
    Malawi
    Thanked: 928
    Quote Originally Posted by Waboz View Post
    ...The attendant mistakenly put in petrol work R389.00 about 26 litres before he discovers he's pouring incorrect fuel. Him and his colleagues convinced me it wont cause harm...
    Shame because at this stage you could have saved it. If you don't start the car and call the AA or similar they come and for a fee they siphon everything out. It's actually quite a standard procedure.
    In UK the AA and RAC even list the cost of it in their service price list, which makes me think that it happens quite a lot.
    The attendants were at fault here I am sorry to say.
    Don't new cars come with a tank neck that can only fit the right nozzle, or something like that?
    May 2011
    Klipriver
    Thanked: 240
    I accidentally did this to my wifeís Fiesta, that was ten years ago, the car is still running. After it cut out on the highway we phoned Ford, they collected the vehicle, drained the tank and lines, replaced filter and that was all
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    May 2010
    Ruimsig
    Thanked: 805
    Quote Originally Posted by All -in -one View Post
    Alan was this petrol into a diesel Fiesta?
    Thanked: 894
    Older vehicles, but interesting
    https://m.youtube.com/watch?v=GL9-i9tcESU
    May 2011
    Klipriver
    Thanked: 240
    Quote Originally Posted by Mal Hannes View Post
    Yes
    Alan
    _________________
    Range Rover P38
    Thanked: 461
    Drain tank and replace filter and fill with diesel, bleed and let return line run into a separate container. Start and drive. You'll be fine.
    A bit of a mistake there from the attendant and the driver to accept the advice of the "other" person as well as not checking what fuel us going in.
    Rand for Rand gets 33Km/L
    Feb 2012
    Chintsa East
    Thanked: 417
    I am always on Swambo's back about getting out and checking that the attendant has the right nozzle.
    2013 Disco 4 XS Lifted
    Toyota Yaris, Swambo's shopping basket
    Jeep Wrangler Sahara 2006 the worsies car for the beach(what a car!! )
  19. #19
    Apr 2011
    Thanked: 1009
    After LR repaired all (IIRC LR replace all lines, pump, filter and injectors as standard practice when this happens) on the garageís account, your vehicle will be as good as new and back to its former glory.
    NO WORRIES!
  20. #20
    George
    Thanked: 1034
    Quote Originally Posted by Regard View Post
    NO WORRIES!
    That must cost an absolute mint at LR?
