Results 1 to 20 of 35
    Gauteng
    Thanked: 92
    Default Legend 35 (KZ-TE) with D4D transplant
    I have asked on this forum previously about replacing my Legend 35 Hilux KZ-TE engine with D4D engine and most of the advice was not to do it. Mostly because of the cost involved and also resale value as people generally dont like to buy 'half breeds'. I acknowledge those sentiments and advice.
    However, are there any technical limitations why it cannot be done? And if so what are those challenges I may face?
    Would an entire D4D engine fit in my engine bay, would I also have to use the D4D gearbox and transfer case, or will my gearbox and transfer case fit to the D4D engine ?
    What happens to all the electronics and cables - I presume my vehicle has far less electronics, cables, interfaces and sensors etc etc to what a D4D has.
    I know i would probably have to modify the bonnet to accommodate the intercooler intake.
    If anyone has done this please can they share their experiences or give me some advice.
    Kathu
    Thanked: 3741
    Default Re: Legend 35 (KZ-TE) with D4D transplant
    The biggest hurdle will be the standalone ECU to run the D4D. Standalone Diesel ECU's are in the region of R30k
    As far as I know the KZ uses the same R151 gearbox as the D4D. You will only need a bellhousing swap to D4D.
    Nigel
    Thanked: 2485
    The guys have that OEM ECU pretty taped. Thy wire it and start the car on the floor.
    This is one of my dream projects for myself.
    Uniglide
    +27 zero eight 2 four 95 9252
    Apr 2014
    Thanked: 134
    Gauteng
    Thanked: 92
    Ok so there is hope.
    I dont know where to start with this. I'm def going to look into this and see how far I can get. More questions to follow......
    Thanked: 1962
    I may be wrong, but I think the D4D used the same block as a KZ-TE. So the bell housing may even fit.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
    Thanked: 278
    The D4D drops straight into the Kz engine space. Gearbox, engine mounts, etc. is the same.
    Only challenge is the electronics but it has been done before and I know of at least 2 guys that got it sorted.
    You can install a front mount intercooler if you don't want to cut the bonnet.
    Si vis pacem, para bellum
    Kathu
    Thanked: 3741
    En daar leer ek weer iets
    Gauteng
    Thanked: 92
    The guy in this thread changed the speedo cluster.....is that necessary?
    The electronics, do they connect them to all the existing end points, such as engine faults, glo plug indicators. What's happens toball those things.....do they get them all working on the same instrument cluster or must it be changed?
    Jan 2009
    Thanked: 49
    Subscribed.
    The word Dzombo is derived from the Tsonga word Dzombolo meaning ‘to wait for something that is slow in coming.
    Named after one of the Magnificent Seven, sadly killed by a Poacher Oct 1995 @ 50 years old.
    Dzombo1 Ex Army LR TD upgraded to 200 Tdi
    Dzombo2 1997 Discovery 300Tdi man
    Dzombo3 2000 Jeep GC 3.0 Diesel a/t
    Dzombo4 2005 Hilux KZTE Legend 35
    Platkar 2017 VW Touareg.
    Camping in a Bokwa.
    joburg
    Thanked: 598
    Ive seen a converted KZTE 4x2 with a D4D in it, definitely not an easy drop in, yes the speedo clocks and ignition barrel and key was changed as well.
    Kathu
    Thanked: 3741
    I have seen a SFA Hilux with D4D engine they also changed the instrument cluster.
    Thanked: 278
    Quote Originally Posted by WayneMan View Post
    No, the guy in Delmas works on the D4D ecu that it only use what is needed. Afaik you use the Kz cluster and key.
    Cape Town Southern Suburbs
    Thanked: 1461
    You probably have to replace the cluster because I'm assuming the ecu supplies the cluster data and the old cluster won't work with the new D4D ecu, neither will the old key and barrel(with immobiliser transponders) work with the new ECU and hence must also be replaced.
    Aug 2018
    Ek het gehoor N4 Landcruiser 4x4 specialiste doen DvD ombouings. N Toyota werks winkel bestuurder het eenkeer vir my gese.... sit n intercooler op jou KZTE en hy maak n groot verskil... betroubaarheid en krag
    Sep 2010
    Kloof, Durban
    Thanked: 7
    Sad to see how many people comment for the sake of commenting with assumptions just to get a post count up.
    We've put a D4D into pretty much anything that can commercially move passengers, from Hiace's to Condors to Mercedes 515 minibuses to VW Crafter's, We started on the V8 lexus swap, great for noise, but not so great when you get your fuel bill at the end of the day. V8's got boring so we started putting KZTE's in, they're a good motor, but lack the grunt required to move a loaded bus with 32 passengers.
    so we moved on to D4D's. D4D's are great, because they've built a reputation for being reliable, they do drop straight into the KZTE space, they have a nice torque curve that makes them good for moving heavy loads.
    We now focus on the GD6's, the 2.4 has a better torque curve and consistently uses less fuel than all the above. 2.8's are hard to come by so we normally make use of whatever is available.
    1. Do we use the OEM ECU? - Yes for the D4D and GD6
    2. Do we need the cluster? - No - unless you really want RPM on your dash
    3. Do we need the original key ? No for the D4D, yes for the GD6
    4. Bell Housing for the KZTE/D4D/GD6 are all bolt on
    5. We take the original Loom from the donor and shave out what ever we do not need and build our own fuse/relay box
    6. Will I give you diagrams of the loom - No
  17. The Following User Says Thank You to Fray For This Useful Post:
  18. #17
    Nov 2014
    Quote Originally Posted by Fray View Post
    What kind of cost are we taking about if you do it? Where are you situated? I have a 90 Prado and will have to to motor anyway. Please advise
    Love change!
    Past:
    Isuzu 2.8 Single cab
    Land Rover Defender Tdi 110
    Mitsubishi Pajero 2800 LWB
    Land Rover Defender Tdi 90
    Toyota Hilux 2.7i
    Toyota Prado KZTE series 90
    What's next....?
  19. The Following User Says Thank You to PHS101 For This Useful Post:
  20. #18
    Sandton
    Thanked: 569
    Quote Originally Posted by PHS101 View Post
    And I have the KZTE Prado 120 - still purring like a kitten, but she would love a D4D.
    Gavin Pike
  21. #19
    Sep 2010
    Kloof, Durban
    Thanked: 7
    I'm situated in Durban, Conversion cost on the 90 Prado will be R115k all in.
  22. #20
    Thanked: 87
    Does that include the motor ?
    UZJ 42 LX: Olive (Sold and bought her Back !)
    HDJ 75 RV Troopy
