Wits engineers have built an affordable off the grid system
Results 1 to 15 of 15
    Friemersheim, Southern Cape
    Thanked: 2202
    Default Wits engineers have built an affordable off the grid system
    Dec 2017
    Thanked: 12
    Default Re: Wits engineers have built an affordable off the grid system
    The problem is that the system is 12V only, so you need all 12V appliances.
    Feb 2016
    Thanked: 607
    Saw this a few weeks ago in the media, very curious about the exact hardware they use. I think itís okay for a small system or rural settlement, but if you want to run your typical 4 person house thatís situated in a nice neighborhood with all the bells and whistles, then a proper big boy system will be a better solution. Or thatís what I suspect
    Oct 2008
    Thanked: 265
    Looks like a battery and some cigarette plugs?
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
    Plett/Paulshof
    Thanked: 792
    I asked for more info in Dec and got an info pack from them. The system is initially meant for 12v devices but can accept an inverter for 220V. More info from them to follow.
    2016 LC 200 VX, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
    Thanked: 1033
    But being a 12v system the inverter feasibly won't be able to run more than a few hundred watts at max?
    Plett/Paulshof
    Thanked: 792
    add batteries, modules etc. same as normal solar system.
    Thanked: 1033
    From what I have heard 12v systems dont handle high watt inverters very well due to the high draw on the 12v side, just 500W is going to be pulling 42A.
    PRETORIA
    Thanked: 41
    Here are the system that i build 3 years ago at my horse stables.
    1 x 80w solar panel, 1 x 100ah battery, 10 x 12v led strip lights etc, one energizer etc.
    Cheap and problem free.
ID:	555210   Click image for larger version.
    FOTON TUNLAND 4X4 LUX
    Thanked: 26
    No revelation in the Wits engineers design plan as far as i can see...
    Plug and play is practiced all over the country with the main difference being that the thieves are not putting anything back.
    I can't see this system being exempt from it.
    Jul 2016
    Kloof
    Thanked: 34
    Quote Originally Posted by kari View Post
    the problem is that the system is 12v only, so you need all 12v appliances.
    ******assuming all DC: tesla slowly rotates in his grave*********
    Apr 2016
    Thanked: 54
    Quote Originally Posted by deanMorris View Post
    Viva Edison!
    I bet that when you start your day the first time you switch on an AC device is when you get to the kitchen..
    Jan 2015
    Vredenburg
    Thanked: 935
    Thumbs up Re: Wits engineers have built an affordable off the grid system
    That just looks stolen from a camping trailer.
    Viva 33% pass rate.
    Thanked: 2202
    Agreed
    Ellisras
    Thanked: 445
    Yep Agree
    Much more innovation and versatility in my trailer self built electrickery setup
    Shocking actually.......
    2000 Patrol GU 4.2D(onkey) old and wise at 844 000 km
    2014 Patrol GU 3.0CRD reaching puberty at 103 000 km
