Cleaning a face brick wall
Results 1 to 6 of 6
    Default Cleaning a face brick wall
    Can someone please tell me what I can use to clean this wall? We removed dry walls and are left with these marks. I am not sure what caused it, most probably the material used for skimming the dry wall.
    We tried sugar soap, but I was thinking if swimming pool acid might not do the job?
    Any advice?
    Attached Files Attached Files
    Nigel
    Thanked: 2329
    Default Re: Cleaning a face brick wall
    Quote Originally Posted by avz10 View Post
    Any advice?
    Sprits of Salts.
    Uniglide
    +27 zero eight 2 four 95 9252
    Is it used undiluted, using a steel brush?
    Thanked: 1004
    I use a pressure washer to prepare any walls for painting... if that is not an interior wall with ceilings or wooden floors that can take a splash... I would go with a chemical and pressure washer on that rough surface if at all possible.
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
    Sep 2019
    Pretoria East
    Thanked: 293
    AVZ,
    Spirits of salt is hydrochloric acid. And so is pool acid.
    Apr 2017
    Durban North
    Thanked: 2297
    Plus goggles, mask and glo es
    A very good product
