SOS D4 suspension fault after water.
Results 1 to 4 of 4
    Sep 2018
    Default SOS D4 suspension fault after water.
    Good day gents, I'm sort of stuck at the moment, came to Loskop dam for the holidays, launched the boat, and held what do we have here.....suspension fault...so this has now turned critical as the suspension has sagged completely and I can not remove my boat from the water or go home for that matter. Please help!!!
    Thanked: 501
    Default Re: SOS D4 suspension fault after water.
    What error message comes up?
    Thanked: 34
    Hi, maybe when you pushed the boat into the water, the compressor got wet and blown the compressorís fuse? Check fuse/relay R7
ID:	551504   Click image for larger version.
    Jul 2018
    Kathu
    Thanked: 74
    Sorted?
