Defender LS2
Results 1 to 11 of 11
Thread: Defender LS2
    Sandton
    Thanked: 126
    Default Defender LS2
    Wanted to get some knowledge from fellow LR owners
    Anybody on here with a LS2 in a defender? reffering to the 6.0 liter V8
    Pros and cons?
    Would you own one or want to?
    Defender RAW Nara Bronze
    Series III 88
    VW Caravelle (wife)
    KX450F #78
    KX 65 # 10
    handmadeprojects.co.za
    Thanked: 719
    Default Re: Defender LS2
    There's one for sale at Auto Exellence Stellenbosch, the conversion was done by Burnco.
    Drives very nicely, it has an R380 gearbox with Disco 2 gear lever.
    It still has the Puma ECU, so everything works as original, the engine has its own ECU.
    Sandton
    Thanked: 126
    Orxy, how was the drive and fuel usage? Any negatives you could pick up? Isn't a d2 gear lever too short compared to the standard Puma lever?
    Series III 88
    VW Caravelle (wife)
    KX450F #78
    KX 65 # 10
    Sandton
    Thanked: 126
    Is burnco known for doing these rebuilds? Are they good at it?
    Series III 88
    VW Caravelle (wife)
    KX450F #78
    KX 65 # 10
    New Germany
    Thanked: 455
    If you are thinking about this also look at the LM7 5.4L as it a engine for low down torque came out the taho (Spelling) with 4L60e and LT230 1.22 ratio
    2005 Defender TD5
    Thanked: 719
    Quote Originally Posted by willemviljoen View Post
    Drove fine, like a normal Puma.
    They mounted the gear levers a bit higher, so it doesn't sit too much lower than the normal Puma gear lever.
    Well, if you are worrying about fuel consumption, then an LS2 is not for you
    Thanked: 2737
    Read clivemd's LM Defender built thread.
    One of the best and most professional builds done in SA
    New Germany
    Thanked: 455
    Thanks for that comment 👍 it is a LS1 in there if I had to do it again will go LM way, maybe next year will swop it out for a LM
    2005 Defender TD5
    Dec 2009
    Melkbosstrand
    Thanked: 427
    Yes, yes
    Rob
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Mar 2016
    Thanked: 2053
    Yes and very!
    Sandton
    Thanked: 126
    Must be a great combo giving best of both worlds, a defender that can go places a little faster?
    Series III 88
    VW Caravelle (wife)
    KX450F #78
    KX 65 # 10
