Power for a modem
Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 20 of 164
    Mar 2011
    Walker Bay
    Thanked: 1071
    Default Power for a router
    I need power for a router 12V 2 Amps.
    Any suggestions?
    How about this mini UPS I see it has a 18650 lithium ion battery. Lasts 5 hours.
    i
    https://www.geewiz.co.za/ups/68269-m...tv-router.html.
    Would a power bank ie Romoss etc handle it?
    Jun 2012
    Thanked: 1167
    Default Re: Power for a modem
    I need power for a modem 12V 2 Amps.
    Any suggestions?
    i
    Have a look at this: cheaper and double the capacity
    https://www.outdoorwarehouse.co.za/p...hoCQ3AQAvD_BwE
    I ran my ADSL modem like this for years
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Jul 2010
    Pinetown
    Thanked: 1477
    I am in no way technically knowledgeable - so take this from whence it comes:
    This morning with all the load shedding I turned on my UPS which had been switched off since about 4 pm the day before.
    Switched on the Internet WiFi router and started charging two tablets.
    Cell phones and tablets worked off that for an hour before the power came back on.
    Bear in mind also that the UPS is about 4 or 5 years old.
    1000 W unit.
    With computer and screen on though it only lats about 10 - 15 minutes before giving low warnings.
    This is just to give an indication of what kind of power is needed for different applications.
    So I am thinking that the modem does not need that much power ... ??
    ISUZU KB 280 DT LE NOW POWERED BY THIS AMAZING COMMUNITY
    Platkar = Chevy Spark 1.2
    Thanked: 127
    What he said
    Jan 2017
    JHB South
    Thanked: 65
    Excludes battery though, but this is pretty cool.
    Thanked: 127
    Quote Originally Posted by TimK View Post
    Totally overpriced though. If you could build it up yourself should not cost more than R100.
    Sep 2008
    Vanderbijlpark
    Thanked: 182
    Sorry, but that Lumeno one - no go. Bought one - the charger died within a year. Lumeno happily replaced it - charger died again. Soldering quality on the inside of the battery cover was terrible too. I'd also go the DIY route. Most alarm shops or electronics shops should have everything you need.
    ZS6VL
    Mar 2011
    Walker Bay
    Thanked: 1071
    Thanks! But I see it is 1.5 Amps. I need 2 Amps.
    Mar 2011
    Walker Bay
    Thanked: 1071
    Thanks!
    Quote Originally Posted by An3s View Post
    Mar 2011
    Walker Bay
    Thanked: 1071
    I would like a device which would run the modem for the extent of load shedding - say four hours.
    Had a ups years ago which performed well but took too long to recharge and there was a strong burning smell when the batteries were charging.
    I could run a cable from the deep cell fridge battery in the car but I would have preferred a standalone unit in the house.
    Quote Originally Posted by Peter1949 View Post
    1000 W unit.
    [REMOVED]
    Thanked: 262
    Just build your self a Load Shredder on wheels
    Attachment 550551
    I bet it will run your modem for more than a day. Last night I ran a steel fan for about 5 hours. I turned it off when I woke up this morning.
    To charge it I use an optimate smart charger.
    potchefstroom
    Thanked: 86
    Quote Originally Posted by SBSP View Post
    Attachment 550551
    Kan jy asb nog n paar pics opsit van ander rigtings?
    [REMOVED]
    Thanked: 262
    Quote Originally Posted by circe View Post
    Hier is nog n paar fotos fan ander rigtings.
    Attachment 550562
    Attachment 550563
    Attachment 550564
    Attachment 550565
    Attachment 550566
    Attachment 550567
    Attachment 550568
    Niks spesiaals nie . Sommer maar net n boer maak n plan situasie. Het nie baie tyd aan dit gespandeer nie. Ek het maar net n paar spaar planke aan mekaar gesit om die batery in te hou (102 Ah) "SuperPower" chinese cheapy battery. n bruggie gebou om die inverter op vas te sit. Met n DC volt meter en n skakelaar om die volt meter te kan aan en af sit. Die rooi houer vir die volt meter het ek sommer ge 3d print, maar jy kan dit ook uit hout uit bou. Die shunt om amps te meet is nie gekoppel nie. weet nie hoe om dit te doen nie.
    Ek rol hom in my sit kamer in en gebruik n oprol koord om watook al te kopel.
    Die inverter is wel 700Watt maar ek dink nie dit sal wys wees om 700watt te trek nie. Ek dink 10amps en minder van die battery af is veilig. (Ek reken 10% van die battery se Ah rating sal nie skade doen nie)
    Apr 2016
    Thanked: 63
    Any suggestions?
    i
    I have my doubts..
    Is this for your router and Wi-Fi? (I see the link doesn't work any more)
    I make a 7Ah battery unit (PUP) which will do both for 12 hours
    I will customise the voltage and plugs for your particular needs..
    Apr 2016
    Thanked: 63
    Sorry. Forgot the price: R750
    Jul 2014
    Thanked: 891
    I use a 7AH sealed lead acid battery (like the ones in gate motors or alarm backups) and connected a power socket to the battery and just plug it into the modem where the normal power supply goes in since its 12V anyways - seems a waste to invert 12v to 220v just to step it down to 12v again with the transformer that came with the modem.
    Assuming your modem has a regular socket like this
    Platkar - Haaihoendaai i20 1.4 SOLD
    Ex'es
    KIA Sorento 2.5 Crdi 4x4 (diesel guzzler of note)
    Nissan Terrano II 2.7
    Mazda Drifter DC 2.5 4x4
    Toyota 60 series 5.7 V8
    Daihatsu Rocky 2.8
    Hillcrest, Malaysia
    Thanked: 6511
    Any suggestions?
    i
    Look carefully. This unit is no good to you. It needs a 12V input to charge it. That is to say you still need to purchase a 12V supply/charger to make it work.
    Go for Richards PUP.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Jul 2014
    Thanked: 891
    And my setup easily runs 12+ hours on the wifi adsl modem. Although my new modem unlike the previous one runs off 9V soo I had to get a small buck regulator to step the 12v battery down to the 9v it requires.
    Ex'es
    Daihatsu Rocky 2.8
    Hillcrest, Malaysia
    Thanked: 6511
    You still need some way to charge the battery.
    ZS5KAD
    3 V8's
    Jul 2014
    Thanked: 891
    Easy, I just connect the regular car battery charger and charge it till full.
    OK granted its not an automatic solution, one still needs to plug and unplug the setup yourself but since I am still more or less not dead yet I can easily do it without working up a sweat
    Ex'es
    Daihatsu Rocky 2.8
