Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 161 to 180 of 181
  1. #161
    Mar 2011
    Walker Bay
    Thanked: 1393
    Default Re: Power for a modem
    Thanks - it looks interesting. Presume the battery would last for around 3 hours load shedding?
  2. #162
    Thanked: 1467
    I would go with one of these from the source you found... https://www.alarmtec.co.za/battery-c...-c-53_186.html There is a box/charger for a 7AH and an 18AH battery backup. The smaller one will do it, but I would go one size up to be safe.
    Original reply in post #120 and you will see that was a better deal.
    -Abraham Lincoln
  3. #163
    Apr 2012
    Thanked: 56
    Quote Originally Posted by MarcR View Post
    Post #122 is my setup with the 6.4A unit. Fiber, Router, Airtie Mesh Wifi, Raspberry Pi servers x2. Longest I went and still had battery left is a little over 5 hours.
    Sawyer Security is better priced.
    https://www.sawyersecurity.co.za/battery-backup-5v3a
    https://www.sawyersecurity.co.za/she...&category_id=0
  4. The Following User Says Thank You to MThompson For This Useful Post:
  5. #164
    Apr 2016
    Thanked: 110
    Here's a specific product for broadband internet backup (battery included!)
    Also comes with customised voltage/s and plugs for your setup: https://www.pupups.info/
  6. #165
    Aug 2019
    Kuilsrivier
    Thanked: 12
    Quote Originally Posted by MThompson View Post
    12V directly to the Fiber box thingy.
    12V directly to the Airtie (Wifi Access point)
    12V - 9V DC-DC regulator for Router
    8A (4 x USB) DC-DC regulator for the 2 x raspberry Pi's
    I used the cables that came with the devices, cut off the power supplies (left some cable for joining if ever needed). DC-DC for the router was moded inline and heat shrink wrapped.
    Voltage on battery after 2 hours loadshedding is @ 12.6V, so plenty left for longer outages.
    Attachment 553731
    Currently using of an old deep cycle for the ONT and 2 regulators for the router and voip base. But its too bulky.
    This looks like a great idea, especially the added usb ports.
    @MThompson
    Just looking at the photo I assume you have to run the USB regulator direct of the battery then? (looks like the rest is run of the supplies on the board)
    Yes, yes, too lazy to look for and download the manual
  7. #166
    Gqeberha
    Thanked: 5557
    I bought 3 of these.
    https://www.takealot.com/fibre-wifi-...h/PLID71640434
    1) Fiber ONT and Mikrotik router
    2) Mikrotik POE Wifi Access Point
    3) Additional wifi access point (old router) plus 8 port switch.
    I get between 5 and 6 hours of of these little devices.
Name:	s-zoom (1).file.jpg
ID:	618303   Click image for larger version.
  8. #167
    Nov 2016
    Thanked: 350
    Installed mine today.
    Took two minutes. Will report back on how it works tomorrow when we go down.
  9. #168
    Apr 2016
    Thanked: 110
    So you are using one mini UPS per device??
  10. #169
    Gqeberha
    Thanked: 5557
    Only for the one, the POE access point, the only reason I have 3 is because of my network layout at home that was done many years ago so I was forced to get 3 of these.
  11. #170
    Mar 2011
    Walker Bay
    Thanked: 1393
    What type of connections are these?
    Fibre / Wifi Router Backup Power / DC Mini UPS 8800mAh
    1 x DC output Cable with 2 ends.
  12. #171
    Garsfontein
    Thanked: 676
    The plus point is your can run each device for longer during any extended power failures.
  13. #172
    Garsfontein
    Thanked: 676
    Cheapest backup power options for load-shedding
    https://mybroadband.co.za/news/energ...-shedding.html
  14. #173
    Thanked: 1045
    The DC output cable plugs into the UPS and the other end into your router. The 2nd DC socket on some UPS is the input from the 220V charger. The larger DC plug goes into the UPS. One cannot connect the wrong plug into the wrong socket.
    Currently my best solution would be 4 x6Ah lithiums R260. 10A BMS R210. China 12V 5A power supply R250. DC sockets and plugs to suit and an enclosure to house the items. This can be good for 5 - 10 hours for a single router.
  15. The Following User Says Thank You to ekkekan For This Useful Post:
  16. #174
    Thanked: 1543
    Not directly linked to your reply but what do those Chinese mall 12V battery chargers look like again, the ones you recommending in the offgrid thread I think it was, do they have a make or model number?
    I want to get one to leave in the car in case I flatten my battery somwhere.
  17. #175
    Thanked: 1045
    This is the only picture I have at the moment. They come in a blue box and it just mentions Pulse Intelligent Charger. 12V 7A. Some boxes are wrongly printed as 7Ah instead of 7A.
    Just ensure you don't buy the type in a orange or black coloured plastic box with a fan on the one end. The one in the picture as well as the one that I don't like with the fan are both GAmistar make.
    I can still supply as it is such a cheap unit and mine is now in daily use for over 3 years charging my outdoor lights 100Ah battery. I belief it is the best way to part with R200.
  18. The Following User Says Thank You to ekkekan For This Useful Post:
  19. #176
    Thanked: 1543
    Many thanks, so the one in the pic is one of the ones to avoid?
  20. #177
    Thanked: 1045
    No the one in the pic you can buy. It is the one without the fan.
  21. The Following User Says Thank You to ekkekan For This Useful Post:
  22. #178
    Dec 2007
    Thanked: 200
    You can also order from here : https://www.electromannsa.com/search...ligent+Charger
    Store is legit - I ordered from them before.
    Metalian Maxi
  23. The Following User Says Thank You to 4x4 wannabie For This Useful Post:
  24. #179
    Thanked: 1543
    Quote Originally Posted by 4x4 wannabie View Post
    Just to confirm, this type of charger in theory should be safe to charge a vehicles battery in situ without disconnecting it?
  25. #180
    Thanked: 1045
    ThanksJust to confirm, this type of charger in theory should be safe to charge a vehicles battery in situ without disconnecting it?
    Not one of quite a lot reported any problems. It includes cars made in the last 3 years. Just connect on the battery 1st and then switch on the 220V AC
  26. The Following User Says Thank You to ekkekan For This Useful Post:
