Amarok Models and Auto with different fuse box
Results 1 to 18 of 18
    Thanked: 37
    Default Amarok Models and Auto with different fuse box
    So i recently discovered that the fuse box in my 2014 Auto and that of a friends 2014 Auto differs from the fuse box diagram that is readily available on this forum and the internet. Whereas the Fuse box that is depicted in the PDF files on the forum has all the narrow fuses grouped together and then all the wide fuses grouped next to them, ours have one row of narrow fuses followed by a row of wide fuses etc. I cant find a fuse box layout to match ours anywhere.
    Is there anyone on this forum who has a diagram or who has figured out the fuse layout of the newer models or autos?
    Thats what mine looks like.
    2017 VW Amarok V6 Extreme
  2. The Following User Says Thank You to PierreSN For This Useful Post:
  3. #2
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Default Re: Amarok Models and Auto with different fuse box
    There should be a description of what the fuses are on the cover for it or a diagram in your owners manual.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
    Thanked: 37
    Quote Originally Posted by Stephan van Tonder View Post
    Neither of the two has a cover. My previous amaroks also didnt have a cover. Neither of the owners manuals have a diagram. My previous amaroks also didnt have diagrams in the manuals.
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    That is pathetic from VW I am sorry to say .
    They always had a little card with the fuse layouts supplied. How on earth do you know what fuses to check?.
    Let me see if I can find anything from a friend at a dealership.
    Unfortunately I can't look your vehicle up on elsawin - mine stops 1 year ealier.
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Ok Guy at the dealership says it can literally change with each vin no so that is why no card.
    So if you Pm me a vin no He can look it up for you. What specifically would you want to know or just the whole list?
    Port Shepstone
    Thanked: 215
    It's a VW thing, every vehicle has unique fusebox layout and available on the VagCom (plugged into computer)
    What a life!
  8. The Following User Says Thank You to Quack For This Useful Post:
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Well then there is a feature I have not figured out yet. Can you tell me where to access that in vagcom.?
    Thanked: 37
    Thanks.
    Will send it this evening
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 89
    PierreSN,
    It seems that we have identical vehicles, and also the same year, and very similar Fuse Box layout,
    BUT, I have 6 more fuses than you, and on one fuse the value is different !!!
    Could you get a fuse list for your vehicle ?
    Herman Meyer.
    AG0017 ORRA AG38
    2014 Amarok DC 4Motion Auto ,
    2015-02-03: Bush Lapa Miskewer 394.
    Feb 2018
    Sarpsborg
    Thanked: 8
    Older post but, i would also really like that list... My 2014 has the same layout
  13. #11
    Thanked: 37
    No I havent been able to obtain it. Slipped my mind at the last service.
  14. #12
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    My friend at vw also never came back with it.
  15. #13
    Melkbosstrand
    Thanked: 186
    Quote Originally Posted by PierreSN View Post
    sorry to dig up an old post again.... but can anyone point out the lighter socket fuse for me?
    trying to piggy back on it for my dash cam.
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  16. #14
    Jun 2018
    Hi BobMabena.
    Not sure of this is what you’re after, but the 12V sockets actually have a fuse behind the panels at the side and bottom of the steering wheel. You lower the steering wheel control/extending lever and then pull the left top cover forward. You can then loosen the whole panel on left and similarly only right. The whole panel swivels on 2 hinges at the bottom. Make sure key is out of ignition.
    On the right, there Is a fuse strip and second from bottom is a 20A fuse for the 12V sockets.
    Not sure which one is the lighter fuse, sorry.
    This is on a 2017 auto, Argentina build.
    Hope it helps.
    2017 Amarok DC 4Motion
  17. #15
    Melkbosstrand
    Thanked: 186
    Quote Originally Posted by dfdekock View Post
    Hi BobMabena.
    Hope it helps.
    I'll take the 20A for the power sockets.
    Thanks very much
  18. #16
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 89
    According to a print-out I got long ago from VW:
    On your photo (my fuse lay-out is very similar):
    Top fuse (no. 43) (25A) in Third Vertical Row from Right, is for "Cigarette lighter -U1".
    (Fuse below this one is 20A)
    If you PM me, I can email you the documents from where I make this deduction.
    Herman Meyer.
    AG0017 ORRA AG38
  19. #17
    Melkbosstrand
    Thanked: 186
    Quote Originally Posted by hermanm10 View Post
    PM sent
  20. #18
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 89
    Sent you an email.
    Herman Meyer.
    AG0017 ORRA AG38
