And another 4.6 rebuild thread
Results 1 to 13 of 13
    Klipriver
    Default And another 4.6 rebuild thread
    As some of you may know by now, I had the misfortune of blowing my motor somewhere around the end of June, beginning of July. Due to various reasons the vehicle has basically just stood. Over the past month or two I have slowly started loosening and removing things so that I could pullout the motor and start the repair process.
    After seeing this thread, https://www.4x4community.co.za/forum...bly-of-4-6L-V8, I was green with envy (still am actually).
    So yesterday I got my arse into gear and removed the final bits and bobs. Today I pulled the motor, and this is where we are now.
    It seems as if the problem was caused by what seems to be a loose or broken camshaft, refer pic 3
Name:	Sale items, Fishing at Celeste, Rangy engine pull 062.jpg
ID:	550064   Click image for larger version.
Name:	Sale items, Fishing at Celeste, Rangy engine pull 063.jpg
ID:	550065   Click image for larger version.
Name:	Sale items, Fishing at Celeste, Rangy engine pull 065.jpg
ID:	550066   Click image for larger version.
Name:	Sale items, Fishing at Celeste, Rangy engine pull 066.jpg
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Klipriver
    Default Re: And another 4.6 rebuild thread
    Stripped the tappit covers and inlet manifold and this is what it looks like.
    Me thinks I need to find a complete sub assembly at least
Name:	Rangy engine 004.jpg
ID:	550104   Click image for larger version.
Name:	Rangy engine 007.jpg
ID:	550105   Click image for larger version.
Name:	Rangy engine 009.jpg
ID:	550106   Click image for larger version.
Name:	Rangy engine 011.jpg
ID:	550107   Click image for larger version.
Name:	Rangy engine 012.jpg
ID:	550108   Click image for larger version.
Name:	Rangy engine 013.jpg
ID:	550109   Click image for larger version.
Name:	Rangy engine 014.jpg
    Alan
    _________________
    Range Rover P38
    I'd say a 4.0 out of a D2.
    Jan 2016
    Golf Park
    Quote Originally Posted by All -in -one View Post
    Wow that is painful to look at... sorry to see whatís happened.
    glad to see my build got you moving though, have dropped you a wattsapp...
    Good thing I have a spare sub and heads coming out my disco, we can chat more about what all you need and looking at doing going forward
    Kathu
    Seems that the cam floated. Intake valve running on exhaust and exhaust running on intake cam profile. That explains the damage on the valve train. Valves collided with pistons. Eina.
    Klipriver
    Thanks JayB, have responded.
    Grips, the cam has snapped, if you look at where the broken lifter guides are you will see the one lifter lying where the cam is missing. Will take a picture of how far the cam is out the back of the motor
    Alan
    _________________
    Range Rover P38
    Klipriver
    Ouch this really hurts...........................
Name:	Rangy engine damage 005.jpg
ID:	550421   Click image for larger version.
Name:	Rangy engine damage 001.jpg
ID:	550422   Click image for larger version.
Name:	Rangy engine damage 002.jpg
ID:	550423   Click image for larger version.
Name:	Rangy engine damage 003.jpg
ID:	550424   Click image for larger version.
Name:	Rangy engine damage 006.jpg
ID:	550425   Click image for larger version.
Name:	Rangy engine damage 007.jpg
ID:	550426   Click image for larger version.
Name:	Rangy engine damage 008.jpg
ID:	550427   Click image for larger version.
Name:	Rangy engine damage 011.jpg
    Alan
    _________________
    Range Rover P38
    Jun 2016
    Randfontein
    Well uncle at least you found the problem
    2016 Audi A3 1.8 TFSI SE S-Tronic 3Dr
    Bethlehem
    Net 'n bottel Stop Smoke en hys reg..........
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
    Nov 2011
    Langebaanweg
    That's not very lekker. Los sommer 'n knop in die keel.
    84' Land Rover Defender 110 V8 4-speed Hardtop (Meisiekind) Sold after 12 years of fun and hard work
    Aug 2010
    "Me thinks I need to find a complete sub assembly at least" may just qualify as an understatement
    Good luck with the repairs.
    Always take the slow road.
    Feb 2014
    Sjo, I did not think this is possible. Was the motor under severe strain when it happened?
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
    I would say thatís moertoe!
